 Electrical Fault Finding 03 - DRY JOINT in Soldered Connections
Reggae Rules...
4374 posts [96%]
Wellington, NZ
 Electrical Fault Finding 03 - DRY JOINT in Soldered Connections Reply  Edit
The problem of DRY JOINTS in soldered connections, particularly on PCB's, is
well known in the electronics and electrical industries. This fault is responsible
for a lot of the "Car starts and runs fine, but randomly shuts down, and won't
start until it has sat for 10 minute... " problems.
This pic is lifted from a good article on a Honda site, but what is written applies
equally to pretty much any older car that uses electro-mechanical relays. No need
to read the whole thing as the first paragraph describes the problem in detail.
http://www.tegger.com/hondafaq....html
So before you go spending your hard earned cash on new relays, take a look
inside and see if it has a dry joint. If it has, any electronics repair shop should be
able to fix it for a couple of bucks.
jondee86 has been a member for 735,126 days.
VitriumGTS
4730 posts [96%]
San Jose/San Diego CA
Oh man! I've been wondering whats been causing my very random and unreproducible engine cutting out issues.
I suspected something in the wiring or the relays too so i went a little overboard and decided to touch up my blacktop engine harness wiring (shortening, lengthening, and getting rid of the bulk). The only thing I found was my junction block ground point bolt was a little loose. But even tightening that didn't solve the instantaneous/random loss and recovery of ECU power while the engine is running.
Good stuff. I was about to make a thread about it too
MisterJerk
283 posts [100%]
Springfield VA
 Re: (VitriumGTS) » Reply  Edit
I had the same strange cut off and die when she warms up. after testing everything and trying everything it turned out to be the Autozone dizzy i had to buy when i couldnt find a used one. Luckily my buddy had one with destroyed wiring, a little cut and paste and she was good to go with a 30 year old dizzy and rigged wiring.
Jerk Racing!
ジャークレーシング
Jeonsah
1814 posts [95%]
Co
The main relay in my honda crx had this problem. Everytime I would attempt to start the car after 2-10minutes of it just running, it would be a pita. So I just took it out myself and soldered the joints. Works like a charm now ^_~
Great tip Jondee!
WTB AE86 Best Motoring International Vol. 42. Pm if you have it!
Red
9661 posts [78%]
 Re: Electrical Fault Finding 03 - DRY JOINT in Soldered Connections (jondee86) » Reply  Edit
In the States we're more likely to call that a "cold solder joint" meaning the solder was never originally heated up enough to properly flow and fill. They seem to become more of a problem as circuits age though, which is why it always pays to look very closely at "bad" electronics.
A $5-10 basic pencil soldering iron kit from Radio Shack or any big box store can fix that, instructions for basic soldering are all over online. If you can melt a pat of butter in a pan, you can do this repair. Usually it just needs to be reheated and allowed to cool properly, adding a touch of new solder if the original was skimpy.
Practice on something dead and junked if you're at all worried. $30 should buy to a really good soldering gun (i.e. Weller) and a larger roll of solder.
--Original owner, '85 Corolla GTS. Will trade for a Cadillac-Gage V150, or a Ford GT, in similar condition.
VitriumGTS
4730 posts [96%]
I found a spare circuit opening relay that I can open up and compare to the one in my car. Hopefully I can get to the bottom of this!
Red
9661 posts [78%]
Bravo. And having done that, I should warn you that the wires are DELICATE and the wire that leads to the middle (second) coil position especially delicate. Poke around gently.
kunfuzion
793 posts [100%]
Ca
Great info. Thanks!
....just a slow red car and a crippled hatch....
» Return to General Technical Discussions
