 The How To 16V Water Pump Conversion On 20V EngineFirst  1 2 3 4 5 >  Last
mr john
3496 posts [100%]
san diego ca
 The How To 16V Waterpump Conversion On 20V Engine Reply  Edit
so it seems like alot of people want answers to this question. ive done this conversion about a dozen times now without any issues and have found that this is the cleanest and simplest way to do this. heres what ive got:
first step is to remove the head from the engine and clean all the oil residue off
then grab your handy dandy die grinder with alluminum bit and grind a passage between the two water ports
now block of the remaining ports, if you want to run factory sensors they can be mounted to these plates or upper radiator hose, you can also run heater lines here.
now reinstall the head using a 16v headgasket.
the 16v water pump has two extra passeges, one for the heater and one for the thermostat bypass. i always remove these by torching them and pulling them out. i then weld up the holes. you can leave the heater passage if you plan on keeping your heater.i also take the factory hard line from the 20v pump from the back of the pump to the cylinder head and cut the flange off, then weld the 90 degree end of it back on to make an upper hose:
to use the factory 16v crank pulley about 1/16 inch needs to be shaved off the back to allign with the 16v alternator and water pump.
thats about it. if you guys have any questions or need more details feel free to ask
Modified by mr john at 8:42 PM 1/15/2009
JSP http://www.jspfab.com
custom fabrication, custom tig welding applications
turbo manifolds, headers, exhaust systems
stand alone ecu wiring, custom wiring harnesses, and wire harness tucks
2588 progress st suite 3
vista ca, 92081 619-788-3415
by appointment only
m4nfred
490 posts [94%]
Miramar Fl
and if u use a 20v headgasket????
THE 86 LIFE!!!
mr john
3496 posts [100%]
san diego ca
 Re: (m4nfred) » Reply  Edit
Quote, originally posted by m4nfred »
it works fine too, ive used both but in theory the 16v gasket flows the correct direction. the holes for coolant passage are on the opposite side.
by appointment only
Point Dexter
1149 posts [100%]
Fantastic! Mr.John:1; relocation kit:0
Your friendly neighbourhood Machinist/Gas Turbine Engine Technician
trdslut
583 posts [96%]
 Re: THE HOW TO 16V WATER PUMP CONVERSION ON 20V ENGINE (mr john) » Reply  Edit
how much will you charge to do your cooling setup to my 20v.
w.tungsten
133 posts [100%]
Ann Arbor MI
are you putting your sensors in line to the radiator?
mr john
3496 posts [100%]
san diego ca
 Re: THE HOW TO 16V WATER PUMP CONVERSION ON 20V ENGINE (trdslut) » Reply  Edit
Quote, originally posted by trdslut »
i charge 300 bucks to do all of the work to the head if you bring in all the parts. machining the crank pulley is 60 bucks (thats what the machine shop charges me..i dont make money off this)
on my car i run the water temp sensors in the upper radiator hose neck
usually for customers that want to run the factory ecu and sensors i put them in the back of the head where they go from the factory. the fan switch, gauge cluster sensor, and standard coolant temp sensor all go in the back.
by appointment only
THE REDLINE 03
197 posts [100%]
Coral Springs FL
Once again Mr. John saves the day .
"Racing is Life! Anything that happens before or after is just waiting." - Steve McQueen
Barry
Moderator - 9,500RPM club
6232 posts [100%]
hellaNORCAL
FWD does not need to do this. Use the factory coolant flow for FWD.
-barry
9500RPM Club...4AGE
wtb: AE86 16v intake box and arm.
LOTS of parts for sale, tools, AE101, AE86, jubride, RSR, TRD:
http://forums.club4ag.com/zerothread?id=86969
trdslut
583 posts [96%]
wow thats cheap thank you i will see you soon thank you.
hahaboy
63 posts [100%]
mr.john, can i use back 20v waterpump and alternator ?
Point Dexter
1149 posts [100%]
This is off topic but I was meaning to ask you how your VR(?) sensor is hooked up? Or if it's not a sensor, wth is it?
jibber86
1377 posts [94%]
CA
nice write up.
m4nfred
490 posts [94%]
Miramar Fl
its a visual sensor i think, haltechish stuff
THE 86 LIFE!!!
me43
1002 posts [99%]
Honolulu hi
 Re: (Point Dexter) » Reply  Edit
Quote, originally posted by Point Dexter »
thats a hall effect sensor
Point Dexter
1149 posts [100%]
 Re: (me43) » Reply  Edit
Ah i see
Automotive ignition and fuel injection
If the magnetic field is provided by a rotating magnet resembling a toothed gear, an output pulse will be generated each time a tooth passes the sensor. This is used in modern automotive primary distributor ignition systems, replacing the earlier contact breaker ('points', which were prone to wear and required periodic adjustment and replacement). Similar sensor signals are used to control multi-port sequential fuel injection systems, where each cylinder's intake runner is fed fuel from an injector consisting of a spray valve regulated by a solenoid. The sequences are timed to match the intake valve openings and the duration of each sequence by the Engine Control Unit (computer).
Very cool Mr.John
m4nfred
490 posts [94%]
Miramar Fl
so know that ur not using that header.....HOW MUTCH??????????
THE 86 LIFE!!!
pinoy_dorifto
984 posts [96%]
Los Angeles CA
this is off topic..
mr.john, what kind of fan are you using???
-=[Dapat mabilis para hinde mahuli ng pulis]=-
-84' Toyota Corolla SR5 Hatch ST20V (Sold to K.C.)
-91' Toyota MR2 N/A Targa 5S (Sold)
-86' Toyota Corolla GT-S Hatch RT16V (My new baby)
m4nfred
490 posts [94%]
Miramar Fl
maybe a stock honda one in that pic........how bout that header...how mutch???lol
THE 86 LIFE!!!
mr john
3496 posts [100%]
san diego ca
haha, mild steel is 800, stainless is 1100
by appointment only
m4nfred
490 posts [94%]
Miramar Fl
u dont have one thats like....overly used lol
THE 86 LIFE!!!
fishtail
101 posts [100%]
hey john i'm currently using a 16v waterpump on my 20v, it didn't fit, but i managed to shave some metal off for it to fit. but my engine hasn't started yet, is it not possible to use a 16v pump, w/o ur mod?
mr john
3496 posts [100%]
san diego ca
 Re: (fishtail) » Reply  Edit
Quote, originally posted by fishtail »
yes but you have to find a way to connect the two rear water passages together so that water flows between them, kind of like the water line kits that are available, my way is just less expensive and allows you to use the 16v pump instead of the 20v one.
by appointment only
fishtail
101 posts [100%]
 Re: (mr john) » Reply  Edit
i did drill 3 pin sized holes in the rear to let water through like the post old post recommended. i think that should be sufficient
Hachi_Drifter
104 posts [100%]
Atlanta Ga
about your 16 valve water pump converson. i didnt see anywhere to connect the heater. what would u recommend me to do about the heater
m4nfred
490 posts [94%]
Miramar Fl
so no deal for the used header...damn
THE 86 LIFE!!!
hahaboy
63 posts [100%]
mr.john, which exhaust system best for low-mid rpm range, 4-2-1 or 4-1 ? or long length 4-2-1?
w.tungsten
133 posts [100%]
Ann Arbor MI
Can you post more pictures of the flange and neck that come out of the head. Following your instructions and reusing the 90degree bend, causes the pipe to not completely cover the hole. What did you use to fill the remaining gap?
mr john
3496 posts [100%]
san diego ca
 Re: (w.tungsten) » Reply  Edit
Quote, originally posted by w.tungsten »
the reamining gap is just filled when welding, you just have to make multiple passes.
as far as a heater, you can simply just not remove the heater line from the thermostat housing on the water pump and just plumb a return line for the heater into the back of the head into one of the blocked off passages.
Modified by mr john at 3:35 AM 5/20/2007
by appointment only
Navi
593 posts [99%]
might be a dumb question, but what is the adfvantage of using a 16v waterpump on a 20v!?
whats wrong with the stock one, i dont believe the 16v stock is so much better?
