Wheel bearings are one of those "everyone's time comes" type parts for these cars. To that end, we put together a kit that comes with everything you'll need to fully replace them for the front or rear of your Corolla. Everything comes with a 1 year no questions asked warranty as well (excludes shipping costs)
Yes, other places offer these, but if you compare our kits to the others out there (or the piecemeal way the dealer sells it) you'll find our kit is the most complete one because we literally include all the parts that should be changed, not just a single component.
Front Kit - this kit does BOTH front wheels for your SR5 or GTS. Includes inner and outer bearings, new seal, and Lubro Moly bearing grease - $79 SHIPPED in all 50 states
Rear Kit - again, this kit does BOTH rear wheels. Includes new bearing, new bearing retainer, new wheel seal. Ready to install. SR5: $110 SHIPPED in all 50 states, GTS $119 SHIPPED in all 50 states
Front AND Rear Set - includes all of the above: $179 SHIPPED in all 50 states for GTS, $168 SHIPPED in all 50 states for SR5
Got a different car you need this same type of kit for? No problem - let us know!
(picture is for illustrative purposes only and is not the Corolla specific kit, but components are from the same manufacturers listed, all of which are OE suppliers for Toyota, as well as all other Japanese manufacturers)
Thjis kit is for the 16 valve 4AGE Engine. We have not yet decided to put together a kit for other engines just yet but perhaps in the future.
As these cars age and accumulate miles, the belt stretches and performance and reliability can be compromised. Toyota suggests replacing the belt every 60,000 miles under normal use, and if your car is raced, even shorter intervals are suggested. For this reason, we have put together a comprehensive timing belt replacement kit that includes everything needed for a full, complete timing belt replacement job. Alot of times, people take shortcuts on this and only replace the belt itself. Then a few thousand miles down the road, they find some of the other components wearing, or leaking, or making noises that were not there before and are forced to do the whole job over again. Do it right the first time and don't be caught short.
Our kit contains the following:
Timing Belt
Tensioner
New Water Pump
New Water Pump Gasket
New Thermostat
New Thermostat Gasket
New Drive Belts for Alternator
Valvecover Gaskets with grommet/washer set
Priced @ $209 shipped in all 50 states
All components carry a 12 month, no hassle warranty as well (excludes shipping costs)
If there are additional components you would like to add to the above (new accessory idlers and accessory belts, for example), just let us know!
To order just give us a call at 631-863-3820, or email z1sales@z1auto.com. For some reason since they changed around the forum we can open pm's but can't reply. International shipping also available, please pm us your full, complete address (not just your country/postal code)
Thanks!
<br /><br />
Modified by Z1 Performance at 4:09 PM 1/1/2012<br /><br />
Modified by Z1 Performance at 3:46 PM 1/19/2012<br /><br />
Modified by Z1 Performance at 5:29 AM 2/17/2012<br /><br />
Modified by Z1 Performance at 6:14 AM 3/8/2012<br /><br />
Modified by Z1 Performance at 11:55 AM 3/28/2012<br /><br />
Modified by Z1 Performance at 8:09 AM 4/23/2012<br /><br />
Modified by Z1 Performance at 4:35 PM 6/29/2012<br /><br />
Modified by Z1 Performance at 8:16 AM 9/20/2012
Modified by Z1 Performance at 1:04 PM 12/27/2012
Z1 Performance
http://www.z1auto.com
631.863.3820
AIM: z1auto
cornerbalance.wordpress.com - the blog!
