 FS: AE86 and 4AGE parts... list and prices [Archived]
Dragontamer
145 posts [100%]
Montreal QC
 FS: AE86 and 4AGE parts... list and prices Reply  Edit
I can provide some pictures upon request. Shipping is not included in the prices below. Just let me know your location and zip for a shipping quote. I'm in Montreal, Canada, so shipping can be a bit higher and longer depending of your location. Send me a message if you have any question.
Luc
e-mail/paypal ljcouture27@videotron.ca
Engine and transmission
throttle cable GTS $30/ SR5 $20
T50 shifter $25
shifter inner boot with holding bracket $10
T50 transmission mount, complete $35
T50 transmission mount, rubber part only $20
SR5 air filter assembly $20
SR5 charcoal canister $10
SR5 alternator $25
clutch master cylinder $15
clutch slave cylinder $10
cooling fan $10
4age water pump housing $15
4age thermostst housing $10
4age coolant outlet, the one with 3 sensors $25
4age coolant outlet, the one with 2 blue vacuum sensors $20
injector rail with regulator and hose $10
injector set $20
4age coolant bottle with holding bracket $30
speed control actuator $20
pump vacuum speed control $15
4age front cover set $10/separate parts $5 each
4age charcoal canister $15
4age crankshaft pulley $25
4age alternator, water pump or ps pump pulley $10 each
plastic air inlet tube $10
4age oil pump housing $20
4age valley cover $10
4age end plate, tranny side $10
4age front plate $10
4age camshaft or crankshaft gears $5 each
4age rear seal housing $15
oil cap $5
engine mount $20 each
alternator bracket, complete $20/slotted part only $10
ECU 89661-12090, 89661-12091, 89661-12092 $50 each
fuse box engine bay $25/interior $15
egr set-up $20
throttle body $30
tps $20
4age distributor $30
4age coil $20
4age coil + igniter assembly $50
injection resistor $10
afm assembly with air box $40
afm $30
rubber tube between afm and throttle body $10
4age engine harness $100
4age dash and interior harness $100
4age engine bay harness $75
power steering pump assembly $40
power steering pump $20
power steering bracket $10
power steering tank $5
power steering belt tightning device $15
tvis plate $10
Interior
black dash excellent condition $250
center console, black $60/blue/brown or grey $40
radio console, black $50/grey $35
radio console,black with enlarged radio opening (about 1/8 each side) $25
under radio comparment box with brackets $15
dash block $10
clock trim (cracked and has been glued) $10
shifter console with boot, black $45, other color $30
shifter boot on console $15
GTS cluster 1986-87, perfect condition 148 000 km $60
SR5 cluster 1984-85, glass has small cracks on the bottom 251 000 km $30
cluster surround $20
headlight switch $20
wiper switch $15
ignition switch with key $15
both door switches and a key $20
switch set including ignition, both boors and a key $35
complete switch set including ignition, both boors, trunk and a key $50
owner's manual pouch red or grey $5
multi-switch (the one with flasher arm) $25
GTS arm rest black, pair $30
handbrake handle $10
steering column cover, black $10
heater console with ashtray $20
rear view mirror, black $10
kick panel, black $20 each/other color $15 each
trunk, gas door or hood cables $10 each
opening lever assembly for gas door /trunk $20
lower dash panel, black $25/other color $15
glove box door, black $35/other color $20
rear deck panel coupe, black $20
steering column bearing housing with switch and key $20
roof light $15
roof light lense $10
sunroof switch assembly $15
rear courtesy light $5
dash vent, double $15/other $7.50 each
mirror switch $10
defogger switch $5
rear wiper switch $5
gas pedal $10
rear seat belt set, black $35/blue $25
front seat belt driver side, black $50/blue $40
front seat belt passenger side, black $40/blue $30
sun visors set $40
rear seat brackets $5 each
steering column lower boot with metal retaining bracket $10
steering column $30
power steering rack $50
heater control assembly with perfect condition face plate $60
heater control assembly with cracked face plate $30
int. door handle $10
rear seat cushion GTS, $75
various panels, covers, trim parts, hooks, brackets etc. in different colors, ask for availability and price
Exterior
headlight assembly complete and fully fonctional $100 each
headlight main frame $20
headlight cover (no eye brow) $10
headlight plastic surround $10
quarter window trim clip set hatch or coupe $20 each side
tail light coupe 1986-87 $30 each
tail light coupe center part $15
tail light hatch 1986-87 $30 each SOLD
tail light center part hatch $15
tail light harness hatch or coupe $5 each
rear marker light $5 each
back-up light $5 each
front bumper flasher, right side (studs missing) $10
3rd brake light, coupe with cover $15/hatchback no cover $10
corner light 1986-87 left side $20
corner light 1984-85 right side $20
power mirrors $30 each
wiper motor 1984-85 or 1986-87 (not the same plug) $20
wiper splindle assembly $20
wiper arms $5 each
bumper corners, front and rear $15 each
rubbers, door or hatch $20 each
coupe rear window seal $30
side windows $30 each
quarter window trim set, coupe or hatch $20 each
door window trim set $20
windshield trim set (3 parts) $30
hood latch $15
hood latch holding bracket $10
coupe trunk trim $30
tail gate latch, body side or door side $10 each
hood hinge set $10
gas door, red $10
door handle $15 each
door opening vent grill $5
door opening belt retract lever $5
door latch (on door) $15
door holding hook $5
door opening switch with boot $5
door window inside guide $5 each
bumper cover, front or rear $50
front lip GTS $60/SR5 $40
GTS grill, white or blue $35
trunk, black no rust with trim $50
underbody plastics, ask for the one you need
Suspension and brakes
lower arms $30 each
knuckle arms $25 each
rear spings $30
master cylinder $20
booster $20
master and booster assembly $35
handbrake cable, long $25 each /short $15
brake divider $5
caliper brackets $15 each
panhard rod $50
diff holding bars, set of 4 $100
front wheel hub $20
strut rod assembly left or right $30
front sway bar $30
engine crossmember $30
tie rods with part connecting to steering rack and boot $15
Relays
light retractor control 85963-14011 $15
headlamp retainer 85961-24010 $15
retractor relay 85964-12010 $15
buzzer 85991-12050 $5
flasher 81980-16010 $5
circuit open 85910-30050 $10
starter 28300-16010 $10
blower 85913-30020 $10
speed control 88240-12101 $10
heater
heater coolant valve $10
ducts $5 each
core $20
blower assembly $30
Miscellaneous
window regulator left $25, right $15
windshield washer tank with 1 or 2 pumps for coupe or hatch $25
fuel tank metal holding straps $30 for both
fuel tank metal holding straps rubbers $20 for both
speedo cable $15
<br /><br />
Modified by Dragontamer at 2:36 PM 12/31/2011<br /><br />
Modified by Dragontamer at 2:57 PM 12/31/2011<br /><br />
Modified by Dragontamer at 2:58 PM 12/31/2011<br /><br />
Modified by Dragontamer at 2:59 PM 12/31/2011<br /><br />
Modified by Dragontamer at 2:50 AM 1/2/2012<br /><br />
Modified by Dragontamer at 1:07 PM 1/3/2012<br /><br />
Modified by Dragontamer at 7:53 PM 1/3/2012<br /><br />
Modified by Dragontamer at 11:10 PM 1/3/2012<br /><br />
Modified by Dragontamer at 11:37 PM 1/3/2012
Modified by Dragontamer at 4:14 AM 4/18/2012
e-mail/Paypal ljcouture27@videotron.ca
Alexwaltman850
384 posts [99%]
Brookings South Dakota
 Re: FS: AE86 and 4AGE parts... list and prices (Dragontamer) » Reply  Edit
one hell of a list man, too bad you don't have what i need. Best of luck!
Add me on Facebook (Alex Waltman), follow me on twitter (TheCreepyJesus), and take care to spike your hair! Woo Woo Woo, you know it!
2001 Pontiac Grand Prix: Crappy daily driver
1985 Corolla GTSR5: Swap in progress
2007 K2 Attack 2.0: My bike i ride everywhere., "Can't Stop! Let's go!"
Parts for sale: http://forums.club4ag.com/zeropost?id=23&cmd=fshow
joe4ag
1178 posts [100%]
email sent.
That1hachi
45 posts [100%]
coral springs florida
email sent
'96 vdub gti 2.0
'86 BMW E30
'86 AE86 GT-S coupe (Dori Dori machine)
sanchez650
74 posts [100%]
Redwood City CA
why are the blue rear seat belts more expensive than the black ones ? and how much to ship to 94061 really interested
Dragontamer
145 posts [100%]
Montreal QC
 Re: FS: AE86 and 4AGE parts... list and prices (sanchez650) » Reply  Edit
The blue ones are cheaper because harder to sell. Price for shipping to your location is $24.
sanchez650
74 posts [100%]
Redwood City CA
would they bolt straight into my hatchback ?
and by any chance do you have a back seat for a hatchback ?
Dragontamer
145 posts [100%]
Montreal QC
absolutely.
I don't have a back seat, sorry
bestae
34 posts [100%]
Ankara Ankara
are u send turkey ?
dareupgang
8 posts [100%]
Jamaica NY
Hello I was interested in the engine bay harness for 75
Dragontamer
145 posts [100%]
Montreal QC
 Re: (bestae) » Reply  Edit
private message sent
dareupgang
8 posts [100%]
Jamaica NY
can you send me a picture of the engine harness and dash harness you advertise for 100 dollars each.my engine is the 20valve 4age black top
user86
19 posts [100%]
las vegas nv
how much for the black rear deck panel (coupe) shipped to 89145 and also does it come with the rear speaker covers?
ae86luis
724 posts [100%]
Garfield nj
 Re: FS: AE86 and 4AGE parts... list and prices (Alexwaltman850) » Reply  Edit
pics on this ^^^
hybridsk8r
128 posts [100%]
kings mtn nc
Ordered taillights, window trim, and headlight switch. And they were delivered within 4 days to NC!!! Quality parts shipped fast at a great price! Thanks Luc!
The 86 life is hard and never ending. Hate to love the AE86...
Billman71
64 posts [100%]
Fresno CA
Luc-
I sent you an email reagarding the intake hose between the AFM and manifold. Need that!
Bill Bailey
joel23
185 posts [100%]
 Re: FS: AE86 and 4AGE parts... list and prices (Billman71) » Reply  Edit
Pm sent
iamjapanman
146 posts [100%]
Irvine CA
email sent
» Return to Parts and Accessories for Sale - Toyota, Lexus, Scion and other car
