 Lexus V8 Swap in AE86....
trdpow2
373 posts [100%]
Chicago IL
 Lexus V8 Swap in AE86.... Reply  Edit
What do you need for a Lexus V8 Swap for AE86....Just wanna know what manual transmission can be use for this swap too....Has anyone did the swap yet and possible post pics too...Thanks...
ae86cesar
251 posts [100%]
Vegas NV
before the not so friendly people get in and tell you to search...
im currently working on my bros ae86 he already bought a lexus 1uzfe motor the main options for trans are the w58 and the r154, either way the 1uz did not come in 5speed so you will need adapter plate, im leaning towards quantom-auto.com they sell a complete kit
________________________________
rz86 swap in the works-- http://forums.club4ag.com/zerothread?id=90283
TOYOTA- KEEP MOVING SIDEWAYS
ae86cesar
251 posts [100%]
Vegas NV
what i found with a quick search
http://forums.club4ag.com/zero...age=1
trdpow2
373 posts [100%]
Chicago IL
 Re: (ae86cesar) » Reply  Edit
Thanks for the info.....
Gyvven
30 posts [100%]
Golden Valley MN
 Re: (trdpow2) » Reply  Edit
There are several sites dedicated to this motor and various swaps, Lextreme.com has a lot of good info as well as v-eight.com. My brother-in-law and I are in the beginning stages of this build and a few of the things to take into account, along with your budget, are your ultimate goal, part availability, desired HP... and whatever else you can think of.
Our build plan so far includes:
1UZFE
Stock ECU, but may go Megasquirt
W58 tranny and adapter plate to the 1UZ bellhousing
3VZ flywheel, but a 3sgte is probably better
Chevy T56 hydraulic clutch slave
bigger fuel pump
Some of the things we may change later:
Ford Explorer 8.8 rear (disc brakes and LSD)
one-piece drive shaft
turbo
S13/14 front spindles w/ Q45 brakes
5x114.3 wheels (Starion wheels, maybe?)
You can see our build here: http://forums.club4ag.com/zerothread?id=102033
We're not very far along the build process but we do have a lot of the components, everything except the clutch stuff.
87 MR2 4AGE, Racecar!
87 MR2, donor
91 MR2 3SGTE, it'll run someday
85 AE86 1UZFE, project car
88 FX16 GTS (x2), I have no idea what I'm doing with these cars
trdpow2
373 posts [100%]
Chicago IL
 Re: (Gyvven) » Reply  Edit
» Return to Engine - Other Toyota engines and off brand powerplants.
