 RS-R USA is seeking volunteers to try out a product... Free Dyno Session.First  1 2 >  Last
Moto-P
Founder/Webmaster - wwwClub4ag.com
11371 posts [98%]
Southern California CA
 RS-R USA is seeking volunteers to try out a product... Free Dyno Session. Reply  Edit
Celebrating the opening of the brand new location RS-R USA Headquarters.
RS-R USA is promoting a new molecular level, engine oil additive that will reduce friction, resulting in cleaner engine, less heat buildup, and superb lubrication resulting in increased power output, and is seeking to prove it!
RAN✩UP
A New Generation Engine Optimizer
RAN✩UP enhances engine efficiency at the microscopic level. Utilizing key components that were developed for aerospace robotics, this specially formulated mixture of nano ceramics reduces friction throughout all oil-lubricated parts of the engine. RAN✩UP creates an environment where engine efficiency can reach its maximum potential.
RAN✩UP increases engine power, improves fuel efficiency and reduces engine vibration.
RAN✩UP’s nano technology makes the difference
Increased engine power and torque
Improved response and pickup
Reduced engine noise and vibration
Extended oil change Interval
Better fuel efficiency
RAN✩UP is unlike any other additive
RAN✩UP is unlike most oil additives in that RAN✩UP is not the oil itself, but rather a composite of materials originally developed for use in aerospace technology. Specially formulated for automotive use and processed into a top-quality (0W-20) 100% synthetic motor oil allows RAN✩UP to be easily transferred into the engine minimizing energy loss due to friction to allow for maximum engine performance.
The numbers don't lie...
RS-R’s RAN✩UP produces real dyno-proven power!
Anyone who wants to try this product, and see for yourself...
For a limited time only, RS-R USA will give your car a BEFORE/AFTER chassis dynamometer sessions and data sheets for YOUR CAR!
Valid for any gasoline powered, street legal or race only car.
Contact Ben at below:
They prefer email as calls may not be expedited quickly due to busy schedules in the garage area.
RS-R USA
1802 Carnegie Avenue
Santa Ana, CA 92705
T: 949-833-7718
E: info@rs-r.com
Facebook: rsrusa
Twitter: @rsrusa
Modified by Moto-P at 4:47 PM 1/7/2012
Moto Miwa
Founder/ Administrator Club4AG
moto@club4ag.com
Yosuke
1814 posts [100%]
The OC
 Re: RS-R USA is seeking volunteers to try out a product... F ... (Moto-P) » Reply  Edit
Just a bit more info on the product
http://octanereport.com/tech/p....html
http://www.importtuner.com/tec....html
JZA80 Supra
AE86 Levin
Moto-P
11371 posts [98%]
 Re: RS-R USA is seeking volunteers to try out a product... F ... (Yosuke) » Reply  Edit
Quote, originally posted by Yosuke »
11hp gain from a V8 Ford engine just from friction modifier agent...
That's pretty respectable... So on a smaller engine running higher tolerances and engine speeds, that figure would likely be similar, but with higher percentage of the total power too...
Moto Miwa
moto@club4ag.com
Yosuke
1814 posts [100%]
The OC
RSR's phones must be ringing off the hook by now lol... The word "FREE" is very dangerous
JZA80 Supra
AE86 Levin
zenkicoupe
3412 posts [77%]
dirty fontana so. cali.
if my car was running i would do it...i read about it a few months ago. sounds interesting.
http://zenkitrdcoupe.blogspot.com/
email grnrolla86 at yahoo dot com
assassin10000
Teq
4959 posts [100%]
Northern CA
If I was closer, and was able to talk with someone about what it actually contains I might consider it.
Andrew
CoRoLLiN
2256 posts [99%]
SoCal, South Bay Carson
damn if only my headgasket did now blow last week. I wanted to dyno the motor before I swap my new setup.
13133 posts [99%]
Portland
 Re: RS-R USA is seeking volunteers to try ... (assassin10000) » Reply  Edit
Quote, originally posted by assassin10000 »
Andrew
is this a similar product to Z-Max?
Maikeru5
7 posts [100%]
Chicago IL
I had heard of this but never looked into it. Our garage uses Eneos Oil with good affect. I'll have to try mixing this in.
Scholz17
194 posts [100%]
Tamassee SC
Too bad I live all the way in South Carolina
This would have been pretty cool
bigkahk
183 posts [100%]
Long Beach CA
argh..i need to put my fuel pump in first......
Moto-P
11371 posts [98%]
 Re: (bigkahk) » Reply  Edit
LS430_Dyno_Ran_Up_1 by Moto@Club4AG, on Flickr
AS you can see from my LS430 test...
Parameters using the same engine oil, with RSR Ran Up Additive.
The HP gain was mild but still notable at about 4-5 HP net gain, despite the higher ambient temperature and water temp, and consistent with character of the engine torque curve.
LS430_Dyno_Ran_Up_2 by Moto@Club4AG, on Flickr
What is more notable is the proof here that there is much less friction, as reflected in the greatly reduced oil temperature, despite the higher ambient temperature, while providing the extra HP.
Not shown objectively here, also, the idling of the engine had much less vibrations in the case of the LS430, and the throttle response on city driving seemed to improve noticeably, and I did gain a whopping 2 MPG average on the way back from Irvine, compared to on the way there with the plain engine oil.
. by Moto@Club4AG, on Flickr
Moto Miwa
moto@club4ag.com
Moto-P
11371 posts [98%]
 Re: (Moto-P) » Reply  Edit
They still want to collect data on the actual performance of different cars, so bring what you have, cars, trucks, go-karts...
Let's test them all... It's free during the campaign period!
Moto Miwa
moto@club4ag.com
Moto-P
11371 posts [98%]
 Re: RS-R USA is seeking volunteers to try ... (oldeskewltoy) » Reply  Edit
Quote, originally posted by oldeskewltoy »
It is a molecular level nano-ceramic particle that blends with oil until it coats your metal and alloy surfaces. The base material is used on spacecrafts and robotic/moving parts where they cannot use liquid lubricants. RSR has developed a way to suspend this in a oil-soluble matter that can be simply added to your engine oil in 350ml quantity that can treat most smaller engines. Of course, more is required for larger V8 and large sump engines.
So no...it's the same idea as some, but formula and base materials may be different. This is not an oil modifier, more than it is a metal surface treatment.
Moto Miwa
moto@club4ag.com
Red
9661 posts [78%]
So putting aside the fluff, is this product a ceramic particle additive, using ceramic particles instead of moly dust as a friction reducer? Ceramic particles of roughly a 1/10th micron size, so they'll flow through oil filters without being strained out?
Since shipping "chemicals" across state lines requires that a material safety data sheet (MSDS) be made readily available for them, how about a link to the MSDS which would tell us more about what's in the stuff?
RS-R USA is, I presume, doing what the major oil companies have done for many decades now, and offering an express warranty against engine failures caused by the use of their product? i.e. a lube oil failure related to the product use? Because Mobil will replace my engine if it fails from an engine oil problem--but not if I put in a bottle of other "stuff". (If RS-S isn't offering that, they might want to get on the bandwagon, it makes for good sales.)
And how many extra hp can we expect from a 112bhp engine that's already running a good 5w30 synthetic motor oil to start with?
I'm curious, and there's a dyno near me. But I'd like some more information on the steak, not just the sizzle.
--Original owner, '85 Corolla GTS. Will trade for a Cadillac-Gage V150, or a Ford GT, in similar condition.
Moto-P
11371 posts [98%]
 Re: RS-R USA is seeking volunteers to try out a product... F ... (Red) » Reply  Edit
Quote, originally posted by Red »
We've ran Yoshie's stock 4A-GE, and here's what Taka observed:
"After all, the RS-R Run UP oil additive gave us 6°C drop on oil temp and slight increase in hp. The over 150k mile 4AG is now idling smoother than ever and respond to my right foot quicker"
What I myself observed during the same session of the 4A-GE (16V stock, TVIS) is that the engine noise and vibrations were noticeably reduced, and idling was a bit smoother. Also a very sharp drop in oil temperature through out the range for successive pulls, despite the warmer water temps and intake air temp.
We didn't see much HP gains in this application but that just may be due to the engine's own capability being tapped out by some peripheral limitations like intake or exhaust efficiency more than the friction elements. I am thinking the reduction in friction and resulting lower temperatures is a merit alone in a 4AG, as oil temp is one of the most difficult to control element in a stock 4A-GE for use in extended track events.
Moto Miwa
moto@club4ag.com
Red
9661 posts [78%]
A drop in oil temp sounds good, that woudl confirm less friction inside. I wouldn't be surprised if a stock engine was air-starving or something else was limiting gain. Sounds interesting, ceramic dust instead of moly.
WHen you say slight increase in hp, what were you able to measure?
Moto-P
11371 posts [98%]
None in AE86 with a 4A-GE, but with huge drop in oil temp.
And in my LS430, it gained 3-5 HP all throughout the powerband with same drop in oil temp as well. :D
Moto Miwa
moto@club4ag.com
CoRoLLiN
2256 posts [99%]
is there a date when this ends? Maybe I can get my motor in and get it tested in time.
Moto-P
11371 posts [98%]
 Re: RS-R USA is seeking volunteers to try out a product... F ... (CoRoLLiN) » Reply  Edit
Quote, originally posted by CoRoLLiN »
Just call them and arrange it:D No definite date set...
Moto Miwa
moto@club4ag.com
Red
9661 posts [78%]
Darn, I was hoping for an extra 50hp.<VBG>
But cooler sounds good too!
13133 posts [99%]
Portland
Be VERY careful with using any friction modifiers in any engine with brand new rings.... You want to make absolutely sure the rings are bedded in BEFORE you use a product like this...
CoRoLLiN
2256 posts [99%]
 Re: RS-R USA is seeking volunteers to try out a product... F ... (oldeskewltoy) » Reply  Edit
^ will do, thanks for the heads up Dan!
kitsune
There is no charge for AWESOME
3808 posts [100%]
Seattle WA
Might stop by on my way home from picking up my ITR.
Getting a free dyno test be nice
Mike
Moto-P
11371 posts [98%]
LOL! No where on the bottle says "MAGIC" or "Sorcery & Witchcraft"
Moto Miwa
moto@club4ag.com
Slideumz909
639 posts [96%]
San Bern,Rialto,909 IE CA
Email sent! I want to try this..and plus dyno my car.
Gpheng86@gmail.com
Shop Link
http://www.facebook.com/pages/...98935
86_kid
37 posts [100%]
swift current sask
Mmm nutritious and it looks tastey
MStoving
41 posts [100%]
Redondo Beach CA
Got my car dyno'd by RS-R a little over a week ago. John of RS-R also gave me a vintage Hayashi Racing Sticker from the 80s!
2hp gain from RAN*UP for me.
Modified by MStoving at 10:50 PM 2/14/2012
Genki Group Gensokyo Gangsters
Moto-P
11371 posts [98%]
 Re: (MStoving) » Reply  Edit
Very nice, that John... (Mr.Masuda).
He's a great friend of the ol Mr.Hayashi of Hayashi Racing too. :D
Moto Miwa
moto@club4ag.com
Sbailey294
1735 posts [97%]
Philly PA
Any word on the expected MSRP of this product?
Steve
Esoteric Performance... don't compromise.
 First  1 2 >  Last
» Return to Club4AG - FUN TALK
