 Work Equip 03
Drifter86_Trueno
179 posts [100%]
Hesperia CA
 Work Equip 03 Reply  Edit
Hey guys I got a question and need help quick. I'm looking to buy some work equip 03's. Here's the size and pattern:
Front 4x114.3 offset +22
Rear 4x114.3 offset +10
Will this work?
daurigon
422 posts [100%]
Richardson Tx
 Re: Work Equip 03 (Drifter86_Trueno) » Reply  Edit
Stock on the corolla's are +20 offset if I am not mistaken, do you have the actual size and width? It would be more helpful. It should be fine, but the width might cause some issues. Also, what disk type are they? These specs are for A disk.
http://workwheelsusa.com/media...4.pdf
15 X 5.0 or 14 X 5.0 +10
15 X 6.0 or 14 X 6.0 +22 or +10
15 X 7.0 or 14 X 7.0 +22 or +10
15 X 8.0 or 14 X 8.0 +22 or +10
15 X 9.0 or 14 X 9.0 +22 or +10
15 X 10.0 or 14 X 10.0 +22 or +10
15 X 11.0 or 14 X 11.0 +10
Drifter86_Trueno
179 posts [100%]
Hesperia CA
 Re: Work Equip 03 (daurigon) » Reply  Edit
I put them on today to test them out and they seem to work well. Only problem i had was that the lugs wouldn't work on the rear as they were too thin. I sat down on it and if I hit a bump they my scrape a bit.
» Return to Parts - Tires and Wheels
