Pictures at link under list of parts available
I'm selling a variety of performance parts that will fit on the chasis/motor of the GTS Ae92, or motor (4age) of the Ae86 GTS , and motor of the Aw11 MR2. Serious buyers please PM me for prices
-Willing to barterWill ship to continental USA and Canada
Prices in CAD
Prefer to use paypal
Email to haugie_87@hotmail.com for prices
Cheers
(2) JVC 5 way 420 watt max power speakers 6x9
(2) Rockford 2 way 60 watt max power 4 inch
Mocal Oil Cooler (235 Matrix, 19 Row) with thermostatic sandwhich plate with lines and fittings set up for ae92 gts
(4) RC injectors 270cc (high impedance) with denso adapter clips
Cosmo Intake with MAF adaptor and cone air filter
Cosmo Adjustable fuel Pressure regulator with fuel rail adapter
MSD 6a Box with 8910eis tach adapter
Whiteline 3 point adjustable rear swaybar
Custom brake master cylinder stopper
Almost Brand new Yokohama Avid H4S tires on factory aluminium rims (4x100mm)
Modded AFM for megasquirt
TRD radiator cap
HKS oil pressure up
Crank Scraper
TOGA high volume oil pump
Speed source Stainless steel clutch line (Ae92 GTS 1989-1991)
Leather shift boot
Speedsource extended slave cylinder push rod
Pascetter header (heat wrapped) (Ae92 GTS)
Magnaflow muffler with chrome tip
Factory replaced 02 sensor
Clear front turn signal lights with orange bulbs
Sunroof visor
(2)Nighthawk Headlights (1) Silverstar Headlight
Bosch Starter under 5000kms
New positive cable
Factory ECU/ Ignitor
Largeport Head (dismantled but fully shimmed -just needs valve seals)
3 angle valve job (ABS competition)
Polish intake ports and port match exhaust ports (ABS competition)
Fully shimmed
Bronze valve guides
Newer OEM springs
Deshrouded valves
Red Powder Coated Valve covers (shaved)
.015 shaved off head
Cometic head gasket
Oil passages polished for better flow to pan
Aluminium oil cap
Widened injector recess
Degree wheel for degreeing cams
Rebuilt and modded distributor for ARP head studs
Extra shims
Block
Block shaved .002-.003 (ABS competition)
Rods,(balanced at ABS competition)
Rods Shotpeened and installed ARP bolts
ARP head and main studs
Ground block to accept ARP rod bolts
42mm Balanced Crankshaft SOLD!
TRD short shift kit with TRD knob (Ae92 GTS 1989-1991) SOLD!
Speed source Shifter cable and base bushings (Ae92 GTS 1989-1991) SOLD!
Web 577 Camshafts (252 duration, 8.38mm lift)SOLD!
NST power Steering Pulley SOLD!
Fidanza 8 pound aluminium flywheel with ARP flywheel bolts SOLD!!
SOLD!
DIYPNP megasquirt ecu, , Idle up Valve, cable, AEM wide band O2 sensor with gauge
TRD ignition wires SOLD!
SOLD!
Custom speed source polyurethane front and rear engine mounts AE92
SOLD!
Techno Toy Tuning Crank lightweight double row pulley with Techno Toy
Tuning Crank Trigger Wheel
Techno Toy Tuning lightweight water pump pulley
Fensport lightweight alternator pulley
Techno Toy Tuning Adjustable cam gears
120A high output alternator SOLD!!
Aluminum valley cover SOLD!!
PICTURES HERE!!
http://imageupper.com/g/?S0200...14580
Modified by Ae92 corolla at 4:02 PM 5/5/2012<br /><br />
Modified by Ae92 corolla at 4:05 PM 5/5/2012<br /><br />
Modified by Ae92 corolla at 4:14 PM 5/5/2012<br /><br />
Modified by Ae92 corolla at 12:25 AM 5/6/2012<br /><br />
Modified by Ae92 corolla at 12:36 AM 5/6/2012<br /><br />
Modified by Ae92 corolla at 2:17 AM 5/6/2012<br /><br />
Modified by Ae92 corolla at 12:56 AM 5/10/2012<br /><br />
Modified by Ae92 corolla at 5:02 AM 5/11/2012<br /><br />
Modified by Ae92 corolla at 2:08 AM 5/12/2012<br /><br />
Modified by Ae92 corolla at 2:11 AM 5/12/2012<br /><br />
Modified by Ae92 corolla at 12:11 AM 5/13/2012<br /><br />
Modified by Ae92 corolla at 12:12 AM 5/13/2012<br /><br />
Modified by Ae92 corolla at 12:14 AM 5/13/2012<br /><br />
Modified by Ae92 corolla at 4:16 AM 5/15/2012<br /><br />
Modified by Ae92 corolla at 5:49 AM 5/16/2012<br /><br />
Modified by Ae92 corolla at 11:56 PM 5/19/2012<br /><br />
Modified by Ae92 corolla at 11:24 PM 5/23/2012<br /><br />
Modified by Ae92 corolla at 9:14 PM 6/8/2012<br /><br />
Modified by Ae92 corolla at 6:25 PM 6/9/2012<br /><br />
Modified by Ae92 corolla at 8:05 PM 6/9/2012<br /><br />
Modified by Ae92 corolla at 11:05 PM 6/10/2012<br /><br />
Modified by Ae92 corolla at 4:02 AM 6/18/2012<br /><br />
Modified by Ae92 corolla at 2:23 AM 7/11/2012<br /><br />
Modified by Ae92 corolla at 2:50 AM 7/11/2012<br /><br />
Modified by Ae92 corolla at 6:19 PM 7/20/2012<br /><br />
Modified by Ae92 corolla at 9:46 PM 9/27/2012<br /><br />
Modified by Ae92 corolla at 9:49 PM 9/27/2012<br /><br />
Modified by Ae92 corolla at 5:59 PM 10/13/2012<br /><br />
Modified by Ae92 corolla at 3:56 AM 10/30/2012<br /><br />
Modified by Ae92 corolla at 4:16 AM 11/6/2012<br /><br />
Modified by Ae92 corolla at 4:17 AM 11/6/2012<br /><br />
Modified by Ae92 corolla at 6:22 PM 11/10/2012<br /><br />
Modified by Ae92 corolla at 2:16 AM 12/6/2012<br /><br />
Modified by Ae92 corolla at 8:47 PM 12/9/2012
Modified by Ae92 corolla at 10:12 PM 12/31/2012
