 4AGE AE92, AE86, AW11 parts....only the delicious ones...no door handles [Archived]First  1 2 >  Last
Ae92 corolla
262 posts [100%]
Regina SK
 AE92/ 4AGE performance Parts....EVERYTHING MUST GO!! NewPictures Reply  Edit
Pictures at link under list of parts available
I'm selling a variety of performance parts that will fit on the chasis/motor of the GTS Ae92, or motor (4age) of the Ae86 GTS , and motor of the Aw11 MR2. Serious buyers please PM me for prices
-Willing to barter
Will ship to continental USA and Canada
Prices in CAD
Prefer to use paypal
Email to haugie_87@hotmail.com for prices
Cheers
(2) JVC 5 way 420 watt max power speakers 6x9
(2) Rockford 2 way 60 watt max power 4 inch
Mocal Oil Cooler (235 Matrix, 19 Row) with thermostatic sandwhich plate with lines and fittings set up for ae92 gts
(4) RC injectors 270cc (high impedance) with denso adapter clips
Cosmo Intake with MAF adaptor and cone air filter
Cosmo Adjustable fuel Pressure regulator with fuel rail adapter
MSD 6a Box with 8910eis tach adapter
Whiteline 3 point adjustable rear swaybar
Custom brake master cylinder stopper
Almost Brand new Yokohama Avid H4S tires on factory aluminium rims (4x100mm)
Modded AFM for megasquirt
TRD radiator cap
HKS oil pressure up
Crank Scraper
TOGA high volume oil pump
Speed source Stainless steel clutch line (Ae92 GTS 1989-1991)
Leather shift boot
Speedsource extended slave cylinder push rod
Pascetter header (heat wrapped) (Ae92 GTS)
Magnaflow muffler with chrome tip
Factory replaced 02 sensor
Clear front turn signal lights with orange bulbs
Sunroof visor
(2)Nighthawk Headlights (1) Silverstar Headlight
Bosch Starter under 5000kms
New positive cable
Factory ECU/ Ignitor
Largeport Head (dismantled but fully shimmed -just needs valve seals)
3 angle valve job (ABS competition)
Polish intake ports and port match exhaust ports (ABS competition)
Fully shimmed
Bronze valve guides
Newer OEM springs
Deshrouded valves
Red Powder Coated Valve covers (shaved)
.015 shaved off head
Cometic head gasket
Oil passages polished for better flow to pan
Aluminium oil cap
Widened injector recess
Degree wheel for degreeing cams
Rebuilt and modded distributor for ARP head studs
Extra shims
Block
Block shaved .002-.003 (ABS competition)
Rods,(balanced at ABS competition)
Rods Shotpeened and installed ARP bolts
ARP head and main studs
Ground block to accept ARP rod bolts
42mm Balanced Crankshaft SOLD!
TRD short shift kit with TRD knob (Ae92 GTS 1989-1991) SOLD!
Speed source Shifter cable and base bushings (Ae92 GTS 1989-1991) SOLD!
Web 577 Camshafts (252 duration, 8.38mm lift)SOLD!
NST power Steering Pulley SOLD!
Fidanza 8 pound aluminium flywheel with ARP flywheel bolts SOLD!!
SOLD!
DIYPNP megasquirt ecu, , Idle up Valve, cable, AEM wide band O2 sensor with gauge
TRD ignition wires SOLD!
SOLD!
Custom speed source polyurethane front and rear engine mounts AE92
SOLD!
Techno Toy Tuning Crank lightweight double row pulley with Techno Toy
Tuning Crank Trigger Wheel
Techno Toy Tuning lightweight water pump pulley
Fensport lightweight alternator pulley
Techno Toy Tuning Adjustable cam gears
120A high output alternator SOLD!!
Aluminum valley cover SOLD!!
PICTURES HERE!!
http://imageupper.com/g/?S0200...14580
Modified by Ae92 corolla at 4:02 PM 5/5/2012<br /><br />
Modified by Ae92 corolla at 4:05 PM 5/5/2012<br /><br />
Modified by Ae92 corolla at 4:14 PM 5/5/2012<br /><br />
Modified by Ae92 corolla at 12:25 AM 5/6/2012<br /><br />
Modified by Ae92 corolla at 12:36 AM 5/6/2012<br /><br />
Modified by Ae92 corolla at 2:17 AM 5/6/2012<br /><br />
Modified by Ae92 corolla at 12:56 AM 5/10/2012<br /><br />
Modified by Ae92 corolla at 5:02 AM 5/11/2012<br /><br />
Modified by Ae92 corolla at 2:08 AM 5/12/2012<br /><br />
Modified by Ae92 corolla at 2:11 AM 5/12/2012<br /><br />
Modified by Ae92 corolla at 12:11 AM 5/13/2012<br /><br />
Modified by Ae92 corolla at 12:12 AM 5/13/2012<br /><br />
Modified by Ae92 corolla at 12:14 AM 5/13/2012<br /><br />
Modified by Ae92 corolla at 4:16 AM 5/15/2012<br /><br />
Modified by Ae92 corolla at 5:49 AM 5/16/2012<br /><br />
Modified by Ae92 corolla at 11:56 PM 5/19/2012<br /><br />
Modified by Ae92 corolla at 11:24 PM 5/23/2012<br /><br />
Modified by Ae92 corolla at 9:14 PM 6/8/2012<br /><br />
Modified by Ae92 corolla at 6:25 PM 6/9/2012<br /><br />
Modified by Ae92 corolla at 8:05 PM 6/9/2012<br /><br />
Modified by Ae92 corolla at 11:05 PM 6/10/2012<br /><br />
Modified by Ae92 corolla at 4:02 AM 6/18/2012<br /><br />
Modified by Ae92 corolla at 2:23 AM 7/11/2012<br /><br />
Modified by Ae92 corolla at 2:50 AM 7/11/2012<br /><br />
Modified by Ae92 corolla at 6:19 PM 7/20/2012<br /><br />
Modified by Ae92 corolla at 9:46 PM 9/27/2012<br /><br />
Modified by Ae92 corolla at 9:49 PM 9/27/2012<br /><br />
Modified by Ae92 corolla at 5:59 PM 10/13/2012<br /><br />
Modified by Ae92 corolla at 3:56 AM 10/30/2012<br /><br />
Modified by Ae92 corolla at 4:16 AM 11/6/2012<br /><br />
Modified by Ae92 corolla at 4:17 AM 11/6/2012<br /><br />
Modified by Ae92 corolla at 6:22 PM 11/10/2012<br /><br />
Modified by Ae92 corolla at 2:16 AM 12/6/2012<br /><br />
Modified by Ae92 corolla at 8:47 PM 12/9/2012
Modified by Ae92 corolla at 10:12 PM 12/31/2012
TCTAE86
59 posts [100%]
FL
 Re: 4AGE AE92, AE86, AW11 parts....only the delicious ... (Ae92 corolla) » Reply  Edit
I'm interesting in the pulley set, how much shipped to CA 90240-3804 United States
jorec99@yahoo.com
Ae92 corolla
262 posts [100%]
Regina SK
 Re: 4AGE AE92, AE86, AW11 parts....only the delicious ... (TCTAE86) » Reply  Edit
Right now Im trying to sell items in the different categories tranmission, head, block. This will be easier to clear out all these items. All prices will include shipping as I dont want to be going to the post office everyday to check what it would cost
elnitro
547 posts [100%]
how much for the cranks pulley and the ae92 mounts can you post pics of the mounts.thanks
Ae92 corolla
262 posts [100%]
Regina SK
 Re: (elnitro) » Reply  Edit
Ok i think I have it set up the way I want to sell it now..take a look and see if you are interested
verevo
2269 posts [100%]
 Re: (Ae92 corolla) » Reply  Edit
Interested in your Ignition stuff. How much shipped to San Jose, CA 95110?
shoot me an email at: hadesomega@gmail.com
http://www.hadesomega.info
biggchoo
51 posts [100%]
victorville ca
How much for the TRD short shifter ?
Ae92 corolla
262 posts [100%]
Regina SK
 Re: 4AGE AE92, AE86, AW11 parts....only the delicious ... (biggchoo) » Reply  Edit
post updated check for prices
DocAvoido
89 posts [100%]
Colorado Springs Colorado
Interested in MSPNP but kinda confused by the setup. Please let me know what you were running, thanks
Ae92 corolla
262 posts [100%]
Regina SK
 Re: 4AGE AE92, AE86, AW11 parts....only the delicious ... (DocAvoido) » Reply  Edit
The set up that i was running was the diypnp with a afm that has been gutted and with the gm IAT installed and wired for the fuel pump. So no cutting wires and still gives that stock look just plug in the arm plug. The flapper door is gone too. Used the wideband and gauge to check my mixture and i was going to add the bosch iacv to help regulate my idle a bit better cause i had such low rotating mass that my factory tiny air idle up wasn't doing the trick.
Ae92 corolla
262 posts [100%]
Regina SK
Let me know if you think my prices are crazy. All prices are under 50% of what they would cost new. Willing to barter a bit
DocAvoido
89 posts [100%]
so were you running the onboard map map sensor and factory ignition?
Ae92 corolla
262 posts [100%]
Regina SK
yes
elnitro
547 posts [100%]
do you want $60 for the mounts.
Ae92 corolla
262 posts [100%]
Regina SK
 Re: 4AGE AE92, AE86, AW11 parts....only the delicious ... (elnitro) » Reply  Edit
yah i would take 60 send me an email to haugen2g@uregina.ca
APO6
22 posts [100%]
Honolulu HI
is the pulley set still available?
Ae92 corolla
262 posts [100%]
Regina SK
 Re: 4AGE AE92, AE86, AW11 parts....only the delicious ... (APO6) » Reply  Edit
Yes send an email to haugen2g@uregina.ca
APO6
22 posts [100%]
Honolulu HI
Email sent.
Ae92 corolla
262 posts [100%]
Regina SK
Anything else I can tell you about the DIYPNP?? Currently its wired as per the diypnp website
Ae92 corolla
262 posts [100%]
Regina SK
bump
zapatito82
126 posts [100%]
gardena ca
Can you send a pic of the trd shifter of the base from the top? Email is zapatito82@yahoo.com
Thanks
Ae92 corolla
262 posts [100%]
Regina SK
 Re: 4AGE AE92, AE86, AW11 parts....only the delicious ... (zapatito82) » Reply  Edit
email sent
Kilo
58 posts [100%]
Vancouver BC
Got money ready...
I'm interested in the following:
TOGA high volume oil pump (Do you mean "Toda" instead? I know Toda sells a 4AG Heavy Duty Oil Pump Gear, but not the whole pump itself. More pictures of this, please?)
Engine Mounts 75 shipped SOLD! (If I am to order from Speed-Source did you order the 93-97 Corolla mounts from them?)
Please e-mail temporarykilo@hotmail.com for quotes/prices SHIPPED.
Located in Vancouver, BC, V5R 3V6.
Ae92 corolla
262 posts [100%]
Regina SK
 Re: 4AGE AE92, AE86, AW11 parts....only the delicious ... (Kilo) » Reply  Edit
Ok change of plans....Ill part anything out and prices will still include shipping and just be adjusted accordingly
roach_84
28 posts [100%]
Misawa Japan
what is the pin count for the mega squirt and how much???
Ae92 corolla
262 posts [100%]
Regina SK
 Re: (roach_84) » Reply  Edit
Its the denso 42 pin as seen here. Fully assembled and wired as per directions. It also has an addition 4 ignition drivers that dont normally come with the kit and a board for sequential injection
http://www.diyautotune.com/cat....html
And would you want the Wideband (which u will need for tuning) and the set up gutted afm with the fuel pump and IAT wired in so you dont have to cut any wires and still look stock if you are worried about smog
Ae92 corolla
262 posts [100%]
Regina SK
Ok sorry for changing my mind a million times. I think I have it set up the way I want it now. I will sell all items listed, items grouped are still to be bought as groups. Individual items can be bought separately.
roach_84
28 posts [100%]
Misawa Japan
not really wanting the rest but if you want it to stay together send the price to roach_84@hotmail.com
Ae92 corolla
262 posts [100%]
Regina SK
I dismanted a few of a packages and will sell most items separately
Ae92 corolla
262 posts [100%]
Regina SK
EVERTHING MUST GO!!! Make me some decent offers
 First  1 2 >  Last
» Return to Parts and Accessories for Sale - Toyota, Lexus, Scion and other car
