 Staggered wheel effect?
Finch17
270 posts [99%]
Central Valley CA
 Staggered wheel effect? Reply  Edit
Ok. From what I've read staggered wheels will lead to more understeer. Is this true if the same size tire is run on all wheels? (17x7.5 front/17x8.5 rear with 225s all around)
I'm looking into wheels for the FR-S. I am not a skilled enough driver to mess with rims for track purposes, this is for DD and looks. I will be using stock wheels and using other things to tweak handling (tires, camber, etc) for weekend fun. With that said I would just go square setup if it really affects handling.
'85 20V AW11 Hatch(in progress)
'05 WRB STi (Sold)
'13 Whiteout FR-S
86_life@earthlink.net
RoKnROLLeR
17 posts [100%]
Gloucestershire
 Re: Staggered wheel effect? (Finch17) » Reply  Edit
Yes & no, staggered wheels will lead to more understeer as its assumed the tires are staggered too, if in fact the tire widths are the same then the contact with road is the same an the slip angle of the tire is the same, the grip is the same, the car will handle the same lol
» Return to Parts - Tires and Wheels
