 intercooler for aw11 4agze swap.
dabay209
769 posts [99%]
lodi ca
 intercooler for aw11 4agze swap. Reply  Edit
i was doing some research and was trying to find out what oil cooler i would need. im sure the gts one is not good enough and i looked at some online but was told that if i go too big that my engine will never reach the optimal operating temperature (180) like if i used the FC oil cooler it would only reach 140. any help or confirmation would be great. thank you.
Evo_lucian
1584 posts [95%]
Saint Lucia, West Indies
 Re: intercooler for aw11 4agze swap. (dabay209) » Reply  Edit
Just get one of 9x5 eBay coolers. Its probably bigger than most stock oil coolers and works fine for most applications.
Dwight
(\__/)
(")_(")
A$s¤hoŁ€ since 1986.
The only thing in life worse than being talked about is not being talked about
my site
http://budgetracer.webs.com
Toyoloog
37 posts [100%]
Purmerend N/H
Why wouldn't the stock cooler work? The JDM AE92 GTZ didn't even had an oil cooler!
On the GT-S, only a small part of the oil is actually cooled (there's a pressure sensitive valve wich only let's a small part of the oil throught the cooler if there's enough pressure) so If you need more cooling, I would route the oil so that is always went through the cooler or, even better, use a thermostatic valve instead of a pressure sensitive valve.
Coffee is what makes life possible in these demanding times...
dabay209
769 posts [99%]
lodi ca
 Re: intercooler for aw11 4agze swap. (Evo_lucian) » Reply  Edit
Quote, originally posted by Evo_lucian »
that wouldnt be too big and cool too much? and would that be the 9 row one?
dabay209
769 posts [99%]
lodi ca
 Re: intercooler for aw11 4agze swap. (Toyoloog) » Reply  Edit
Quote, originally posted by Toyoloog »
hmm i wasnt aware of this fact. i was thinking of getting a fc oil cooler today. but i guess i wont lol ill just wait. i just dont want it to cool too much and my engine run at cold temperatures constantly.
Evo_lucian
1584 posts [95%]
Quote, originally posted by dabay209 »
Yeah 9 row . Think its 13 x 3.5 x 2 inches , that's about the smallest I see on sale on eBay. If you don't have high oil temps to begin with, any oil cooler will do just fine.
FYI , my ae92 gt apex levin didn't have an oil cooler, neither do the local ae101 and 111 levins.
Dwight
(\__/)
(")_(")
my site
dabay209
769 posts [99%]
lodi ca
the aw11 do though correct? im just going to use my factory gts one then.
Evo_lucian
1584 posts [95%]
Not sure about the aw11 but I highly doubt it. Stock one will be just fine for most applications.
Dwight
(\__/)
(")_(")
my site
MazterDizazter
259 posts [100%]
Marshfield MA
The AW11 MR2 has a liquid cooled oil cooler that runs the oil lines parallel to the coolant hose. Looks like this:
Your stock oil cooler should be just fine unless you're going to be endurance racing or something.
1987 Toyota MR2 hardtop
20v blacktop 4A-GE
Ground control, Koni, Cusco, ST
XXR, Toyo, Wilwood, EBC, Odyssey
Recaro, MOMO, Fidanza, SPEC
» Return to Engine - 4A-GZE, and Supercharger/Turbocharger Projects
