 4age check engine light at steady rpm
smerph42
3 posts [100%]
las vegas nv
 4age check engine light at steady rpm Reply  Edit
My check engine light comes on during steady rpm like freeway driving but then goes away when I speed up or slow down but if I stay steady on the throttle the check engine light will come on. Anyone know any reason why this might happen? I have a standard 4age large port tvis motor all stock if this helps.
Thanks in advance.
Reggae Rules...
4374 posts [96%]
Wellington, NZ
 Re: 4age check engine light at steady rpm (smerph42) » Reply  Edit
Check for fault codes. If the check engine light has been on, the ECU should have
latched a fault code.
jondee86 has been a member for 735,126 days.
smerph42
3 posts [100%]
las vegas nv
 Re: 4age check engine light at steady rpm (jondee86) » Reply  Edit
No fault code the light comes on and then goes out when I'm in regular traffic
85zenki
811 posts [100%]
kissimmee, FL.
replace the o2 sensor.
PLEASE,ANY REPLIES OR RESPOND TO:
my e-mail and paypal is:
jfc.06@hotmail.com
text or calls #407-738-3686
May the force of 4age be with you
Long life to the AE86
UTOTMO
5130 posts [100%]
reseda ranch ca
the fault code will tell u why ur check engine light turns on to pin point the problem. If u have fsm on hand u will jump the ecu the check engine light will blink (count how many times) this will lead to the part or electrical that needs repair or need to be replaced. Does ur car runs ok when ur at complete stop and check engine is on as well? once u move forward goes away and at freeway speed it disappears at 4500 rpm's above. I do not want to guess if u answer yes to all its ur tps sensor but have someone totally diagnose it before u spend money on brand new tps sensor.
KNUK KNUK GARAGE..
Russ
758 posts [100%]
Lawrenceville GA
My car has done the same thing. After about 2 months I finally was able to get the ECU to give me a code. I don't remember the code number, but it was the fault code for "air entering system after air meter", or basically a vacuum leak.
» Return to Cars - RWD - (AE86, TE, KP, RA, TA)
