For reference only, all new posts and communications should be posted in the new forums at
 Big Port head O/S valves CNC [Archived]
30psi 4agte
35 posts [100%]
 Big Port head O/S valves CNC Reply  Edit
For sale 4age big port head. Fitted with over size valves 1mm on the inlet and 1.5mm on the exhaust. The head has been extensivley ported and polished, with extensive CNC work, conbustion chamber / valve seat and bowl work (evident by supplied pics)
The combustion chambers have been cc'd ,polished and valves deshrouded. The head is to be sold as a complete unit with big port cams, new valve stem seals and all valve clearances set - so its ready to bolt straight on.
All cam bucket hole have been polished to aid in smooth friction less opperation along with the cam journal clearance checked.
The head has std valve spring but they have been shimmed 1mm . This WILL NOT effect valve spring bind as the installed valve height was changed when on the CNC to allow for this modification. 8.5mm of lift is still safely attainable on this head with 1mm further lift untill full bind is reached.
I have tried to supply as many pics as possible throught out the rebuild, One for proof that the work mentioned has been carried out and two to show the quality of the work carried out. (you too often get items that claim this and that has been done only to find out they are not what they say)
Price $1000 firm.... or $900 with a good big port head as change over
Located In South Australia - Happy to post
PM Jordan
For more details
Newen CNC
Material removed for bigger valves
Spring shims
Head supplied complete with cams and valve clearance set
460 posts [100%]
Covington VA
 Re: Big Port head O/S valves CNC (30psi 4agte) » Reply  Edit
You have flow charts?
30psi 4agte
35 posts [100%]
 Re: Big Port head O/S valves CNC (miander) » Reply  Edit
Not for this particular head. Although i can tell you it is an exact copy of my current head.
Made 420hp at the wheels
8 posts [100%]
Riuty CA
Thank you for your post! Very interesting!
» Return to Parts and Accessories for Sale - Toyota, Lexus, Scion and other car
