 Cannot remove crank pulley (4AC) bolt is off. pulley wont budge.
DannyAE
43 posts [100%]
Pacific WA
 Cannot remove crank pulley (4AC) bolt is off. pulley wont budge. Reply  Edit
I need some help.
ive removed the 17mm crank pulley bolt. i have also removed the 4 12mm bolts holding on the outer pulley (accessory belt)
but for some reason i cannot get the pulley to budge.. its stuck.
i have been spraying WD40 and hitting it with a hammer. i cant seem to make this budge.
any advice?
Eric'sFreeAE86
2589 posts [100%]
Chattanooga TN
 Re: Cannot remove crank pulley (4AC) bolt is off. pulley wont budge. (DannyAE) » Reply  Edit
Hammer can eventually get it. A jaw type gear puller works if you don't mind possibly damaging the pulley. There are some threaded holes in the pulley that you can use somethin like a steering wheel puller, too.
Is the engine in or out of the car? Big pullers are hard to use still in the car, but there are lower profile joints that'll fit if it's still in.
Toy86
354 posts [100%]
Crestview FL
U can also rent a puller kit from Autozone or any autopart store that has a rent a tool program.
c99ae86
604 posts [100%]
SF Bay Area
 Re: Cannot remove crank pulley (Toy86) » Reply  Edit
http://forums.club4ag.com/zerothread?id=56536
this was a big help when i had to remove mine. broke numerous pullers, took days to get it off and thats after 2 weeks of prior soaking in pb blaster. hope this helps.
allencr
4088 posts [93%]
Tallahassee FL
 Re: Cannot remove crank pulley (c99ae86) » Reply  Edit
No access to a puller? Don't us anything with jaws, only bolts with a steering wheel or harmonic balancer puller.
Remove bolt, spray with penetrating oil(wd40 IS NOT penetratig oil!!), replace bolt & only tighten a bit 20-40ftlbs, belts, start engine, rev 3-5000 a few or 5 times, disassemble & it'll slide it off with a bit of luck.
» Return to General Technical Discussions
