 Real quick anyone know what this vacuum line went to?
ddxxe
22 posts [100%]
Corvallis Oregon
 Real quick anyone know what this vacuum line went to? Reply  Edit
Just wondering what this went to because I'd like to know if it is causing any sort of damage with it having been plugged off the way it is. (I want to strangle the previous owner.)
PM me @ ddxxe@hotmail.com
apsogosgti
179 posts [100%]
athens
 Re: Real quick anyone know what this vacuum line went to? (ddxxe) » Reply  Edit
can u take a photo on the start of the vacuum?
DRIFTER
389 posts [100%]
It would have gone to a 2 pronged switch that is attached to your power steering pump.
taroroot
3167 posts [100%]
 Power Steering idle up » Reply  Edit
Yup, what he said, its the power steering idle up lines. Car should run fine as long as it's plugged securely. If you're running without it, it would be nicer to cap the two lines at the intake origin end. Find some nice vynl vacuum caps and get rid of all the lines going to the pump valve. It'll clean things up and make it not so ghetto.
It's function is to up the idle slightly when the p/s is under high load.
ddxxe
22 posts [100%]
Corvallis Oregon
 Re: Power Steering idle up (taroroot) » Reply  Edit
Oh whoa. That's pretty cool. Smart thinking there toyota. Some of the features I stumble across this car for how old it is amaze me
Thank you guys!!! :D :D :D
apsogosgti
179 posts [100%]
athens
 Re: Power Steering idle up (ddxxe) » Reply  Edit
idle up lines for power steering?what version/year is your this engine ?
» Return to Engine - 4A-GE 16V
