 Hasselgren Formula Atlantic 4age [Archived]First  1 2 >  Last
Billy_Andrea
1321 posts [100%]
San Francisco CA
 Hasselgren Formula Atlantic 4age Reply  Edit
If you know anything about what it costs to build one of these engines you will know that this is a steal at this price!!!
** $10,000 **
Head
TRD Atlantic Cams
Custom Hasselgren valves
Atlantic valve springs
Shim under bucket valve train
Multi Angel valve seats ( Newen CNC seats )
Top spec port work with over sized intake & exhaust ports
TRD Atlantic 4 throttle intake
TRD Atlantic fuel rail ( injectors & TPS included )
Custom carbon trumpets & intake plate included
Custom Formula Atlantic Cam Cover with cam position sensor
Block
TRD Crank
TRD / Carillo Rods
TRD / Carillo Pistons
Custom Dry Sump Pan
Block has been strapped for main cap strength
Hot honed
Custom billet front oil pump delete cover
Dry sump pump
Custom front pulleys
Alternator
Custom crank trigger & sensor
12.5:1 compression & will make approx. 247bhp at 10,000 rpm
This is a brand new build, just complete & has not been used since assembled. Comes exactly as pictured
Okie86
89 posts [100%]
Tulsa OK
A steal at what price?
Billy_Andrea
1321 posts [100%]
San Francisco CA
 Re: (Okie86) » Reply  Edit
Forgot the most important part.
$10,000
Edited post
scels86
869 posts [100%]
ontario ca
 Re: (Billy_Andrea) » Reply  Edit
Billy Seriously who are you ????
U have the craziest stuff
AsianChopSticks
38 posts [100%]
Long Beach CA
 Re: Hasselgren Formula Atlantic 4age (Billy_Andrea) » Reply  Edit
Dude your just wow.. you deserve a slow clap for having such.. I cant even explain it, words aren't enough.
Prolly the second thing on my lifetime wish list.
wait so it already comes with the dry sump system? or you still have to get them your self?
- Dan
Because racecar
Reply about the topic ae86 F20c/F22C swap.
"It costs alot.
It's very fast.
Don't do it if you drive at an amatuer level. Honestly. You'll just suck...or crash...or suck and crash."
~HASportAE86~
Billy_Andrea
1321 posts [100%]
San Francisco CA
 Re: Hasselgren Formula Atlantic 4age (AsianChopSticks) » Reply  Edit
It comes with the dry sump pan, front cover & pump. The buyer just needs a tank & lines. Easy(ish)
Eric'sFreeAE86
2589 posts [100%]
Chattanooga TN
That's in the neighborhood of 30 G's sitting on that workbench, not including the loose change in the second pic. Machine work costs more than parts, kids.
No1SleepInTokyo
111 posts [100%]
Danvile Va
$,$ That's insanely low priced! BUMP for a sweet low priced engine!
JDM-Newbie
4216 posts [100%]
LA CA
Does it take 87 octane and what is the mpg?
Neutron Pixie
13 posts [100%]
New Orleans Louisiana
do you still have it?
Neutron Pixie
13 posts [100%]
and if not can you get/build another
Billy_Andrea
1321 posts [100%]
San Francisco CA
 Re: (JDM-Newbie) » Reply  Edit
Really?
Billy_Andrea
1321 posts [100%]
San Francisco CA
 Re: Hasselgren Formula Atlantic 4age (Neutron Pixie) » Reply  Edit
This one is now sold. An identical one can be built for the same price though
Neutron Pixie
13 posts [100%]
yes i'm serious. if you can build another i'll come see you in person when my schedule is clear (as i work and i'm in new orleans) to prove that i've got the $$$ and then i guess you build the engine at your leisure and i'll come back to pay for and take possession the beast
Neutron Pixie
13 posts [100%]
and can you also do the rebuild for when it's necessary... and it will be necessary after a relatively short while.
Billy_Andrea
1321 posts [100%]
San Francisco CA
My "really" comment was direct at the mpg / 87 Octane question, not yours.
Yes, it is possible to build another identical engine but it would more than likely not be for the same price. This was for sale for this price because it was already built & needed to be sold. To build one in this exact spec would be closer to $13,000.00.
With regards to the rebuild needs of these engines, it's a myth. if your not driving in a single seater at 10,000rpm everywhere, every day there's no reason that they can't do very high mileage. A friend of mine has had on in his car with 15:1 compression for over 4 years ! It's been services a couple of times & that's it. Never gave any trouble etc...
Neutron Pixie
13 posts [100%]
really... i didn't realize it had that long of a life. how many race miles do you think it'll do before a rebuild
SuperWakos
87 posts [100%]
San Diego CA
EPIC! o_0
Automatic Thirty G's w/o blinking
Billy_Andrea
1321 posts [100%]
San Francisco CA
Taka ran his 1st na for 2 full seasons before it started to blow a little smoke.
In a car like a Corolla, it's hard to say but it's not like it would need new rods, pistons & a crank like the Formula cars do. More than likely you would be doing head seals & rings, then throw it back in the car & go.
When an engine is built with nothing but the very best parts by one of the best builders they tend to last quite a while....
Neutron Pixie
13 posts [100%]
JDM-newbie i would think the engine would need at least 105 to run properly but thats just a guess
AsianChopSticks
38 posts [100%]
Long Beach CA
Just passing by and saw this..
so you mean i.e. like this one http://hasselgren.com/engines-for-sale/ the 4ag found there when dropped in right can last for a while if almost not driven roughly daily with just doing the regular maintenance and such?
- Dan
Because racecar
"It costs alot.
It's very fast.
~HASportAE86~
Billy_Andrea
1321 posts [100%]
San Francisco CA
 Re: (Billy_Andrea) (AsianChopSticks) » Reply  Edit
If you use the engine in the link & drop it in a Corolla, as long as you are using 105-110 fuel, changing the oil every 2-3k miles & also doing plugs at the same time there's no reason it can't last just as long as a stock 4age. It's prolonged periods of 10,000rpm in a formula chassis that causes the damage
Taka
275 posts [100%]
 Re: (Billy_Andrea) (Billy_Andrea) » Reply  Edit
I agree with Billy about engine life. I run NA Hasselgren only 1 season, but turboed 4AG from 2008 to end of 2011.
Here is what I had to do.
2008 and 2009 seasn: Atlantic Head/block modified stock crank/ GZE pistons
oil / spark plugs change every FD event ( c16 effect on plug). Kept the rev limit at 8500 rpm.
Total number of event : 14 FD event, 12-16 practice event.
2010-2011 season: Atlantic Head/block/crank/Wiseco pistons:
oil / spark plugs change every FD event ( c16 effect on plug). Rev limit 9800 rpm.
Total number of event the engine ran: 14 FD event, 20-26 demo/practice.
As long as you have good tuning, reasonable rev limit rpm, and take standard steps for dry sump engine start procedure, Hasselgren 4AG will last at least 2 seasons or more .
Taka
http://blog.driftpro.com
Team Driftpro
http://www.Driftpro.com
Neutron Pixie
13 posts [100%]
i'm really glad about that it makes me more comfortable with the idea of spending 13k on an engine
Billy_Andrea
1321 posts [100%]
San Francisco CA
 Re: (Billy_Andrea) (Taka) » Reply  Edit
Taka,
Thanks for your input. If anyone knows how much abuse a 4age can put up with, you do !
UltimX
496 posts [98%]
ba ca
Wouldn't the tune depict the kind of gas used? I mean u wouldn't make the max power on a lower octane of gas but you would still be able to use the lower octane.
Billy_Andrea
1321 posts [100%]
San Francisco CA
 Re: (Billy_Andrea) (UltimX) » Reply  Edit
Not necessarily because with the compression ratio being between 12:1 & 13:1 for the base engines and up to 15:1 for the top level engines none of them will run on pump fuel. It's not all about the map...
UltimX
496 posts [98%]
ba ca
I figured they were all 12.5, but yeah I wouldnt run anything but race gas in 12.5+ comp.
Ae86MAC
238 posts [100%]
San fernando Ca
Bump for a killer
AE85MAC
AE85MyAE86Corolla
Billy_Andrea
1321 posts [100%]
San Francisco CA
 Re: Sold » Reply  Edit
Sold!!!
 First  1 2 >  Last
» Return to Parts and Accessories for Sale - Toyota, Lexus, Scion and other car
