For reference only, all new posts and communications should be posted in the new forums at
 7age/9age 1900cc Group Buy!
339 posts [100%]
Natchez MS
 7age/9age 1900cc Group Buy! Reply  Edit
Just some info that I think ya'll might be interested in. At this link...
I "WAS" within minutes of ordering a Spool 1.9 kits until I found out their rod ratio was least than ideal, their's is 1.44 where the 7AFE stock ratio is 1.55. The target for the above kit. My understand is that below 1.5 is not good.
They also sell a modded crank timing gear what allows the keeping of the intake VVT pulley using a 16V timing 113 tooth belt with 4AGE oil pump and tensioner.
You will see that I am on the list and I didn't ask before I listed the link but just thought with all the threads about the 7AGE and above it was worth a post.
later wd
PS hope I haven't broken any rules by posting this? If so then I am sorry, just trying to help. I didn't ask the kit supplier before I posted but I will let him know about the post.
Modified by wrenchdad at 5:02 PM 9/3/2012
" Second place is just the first loser" the late Dale Earnhardt
2589 posts [100%]
Chattanooga TN
 Re: 7age/9age 1900cc Group Buy! (wrenchdad) » Reply  Edit
That works out to $2881.90 USD before shipping, for a custom spec billet crank, super rods and whatever pistons you could possibly want. Like just about everything else around here: if I only had the money......
49 posts [100%]
 Re: 7age/9age 1900cc Group Buy! (Eric'sFreeAE86) » Reply  Edit
These are the kits we are building.
With a rod/stroke ratio of 1.51:1
1988 Toyota Levin GTZ 7agte 20v 337kw@26psi 98 pump gas, 10.88 @ 209.57
Manon Racing Products: Fortune Auto Performance Coilovers|Quartermaster twinplates|Masterpower turbos|Wilwood brake kits
» Return to Engine - Other Toyota engines and off brand powerplants.
