 ?spring rates for TRD springs
rocksteadyracer
59 posts [100%]
racine wi
 ?spring rates for TRD springs Reply  Edit
I have a set but I'm wondering what the front and rear rates are, did they make more than one set for 87 GTS?
ga_goosh
2498 posts [100%]
far enough to require shipping HTX
 Re: ?spring rates for TRD springs (rocksteadyracer) » Reply  Edit
Are your springs lowering springs or race springs? TRD used a color code to determine the spring rates for there race springs and are found HERE
i believe this applies to the light blue trd springs
I <3 my AE86
Kouki 86-87 Service Manual
4AGE Diagnostic Manual
Toyota Wiring Repair Manual
20V Blacktop fsm
.......USE THEM!!!.......
TEXAS 86 Forum
http://www.86garage.com
rocksteadyracer
59 posts [100%]
racine wi
 Re: ?spring rates for TRD springs (ga_goosh) » Reply  Edit
These are the black ones
ga_goosh
2498 posts [100%]
those are just drop springs. spring rate is probably around 1.9 to 2.5 lb/in or so blue and light blue are the ones with higher spring rates. the TRD race springs are apparently made by eibach for TRD so you will save monies if you buy eibachs
http://www.nengun.com/trd/lowering-springs
I know the ae86 springs ar not listed in this link but it does show the black drop springs for other toyota cars
I <3 my AE86
20V Blacktop fsm
TEXAS 86 Forum
rocksteadyracer
59 posts [100%]
racine wi
thanks man
Jeff Lange
3143 posts [99%]
Quote, originally posted by ga_goosh »
There are 4 main types of TRD spring for the AE86.
TRD Japan Race Springs (Come in various spring rates)
TRD Japan Rally Springs (Come in various spring rates)
TRD Japan Lowering Springs (Front = 2.8kgf/mm, Rear = 2.7kgf/mm)
TRD USA Lowering Springs (Exact spring rate unknown)
TRD USA lowering springs are the only ones made by Eibach USA. TRD Japan (including race) springs are not made by Eibach.
Jeff
ga_goosh
2498 posts [100%]
 Re: ?spring rates for TRD springs (Jeff Lange) » Reply  Edit
Quote, originally posted by Jeff Lange »
Jeff
ah wasnt sure
I <3 my AE86
20V Blacktop fsm
TEXAS 86 Forum
» Return to Cars - RWD - (AE86, TE, KP, RA, TA)
