 20v Engine Harness HELP!
stagga
20 posts [100%]
saint albans New York
 20v Engine Harness HELP! Reply  Edit
if i have an 20v silvetrop engine would i need to buy a 20v harness and get it converted or i need to send my 7a engine harness and a 20v harness for it to be converted?
soulshadow
120 posts [100%]
Fayetteville AR
 Re: 20v Engine Harness HELP! (stagga) » Reply  Edit
You would need the 20V harness, because the 7A motor (I assume you have a 6 Generation Celica) runs on a Map sensor. The silvertop has a MAF sensor and some other sensors that needs to be converted in order to work on the 7A chasis. The swap is not that hard, I did it before on my 7A motor. I don't suggest you to do a Silvertop Swap if you can stick with a 4agze, parts are easier to come by and that supercharger is way better, plus it can handle the boost if you decide to go turbo.
stagga
20 posts [100%]
 Re: 20v Engine Harness HELP! (soulshadow) » Reply  Edit
oh ok thanks but i have a corolla 7 gen and is going from a 7afe to a 4age 20v
soulshadow
120 posts [100%]
Fayetteville AR
Same motor same parts, all the stuff are identical straight down to the motor mounts and drive axles and tranny. Wiring is a little different but still the same concept.
