 Easy pnp megasquirt ecu?
GTS-COUPE
162 posts [100%]
Lancaster PA
 Easy pnp megasquirt ecu? Reply  Edit
I was doing some research on jumper ecu harnesses, and found that the 3sgte and 4age 20v use the same jumper. I also found there are many pnp ecu's for the 3sgte. So I began checking out pinouts for our ecu and comparing them to see how closely they are. To my surprise they are very very similar indeed!!! Has anyone thought of doing this? I understand that the base maps will be completely different, but ill post pictures of the comparison when photobucket app is done downloading!
GTS-COUPE
162 posts [100%]
Lancaster PA
 Re: Easy pnp megasquirt ecu? (GTS-COUPE) » Reply  Edit
mr220v
1246 posts [100%]
Atlanta GA
I made an adapter like this for a microsquirt once. Seemed to work well.
Email questions to mr220v@gmail.com
GTS-COUPE
162 posts [100%]
Lancaster PA
 Re: (mr220v) » Reply  Edit
My only concern is lack of vvt on the PNP ecu.
98AE111
103 posts [100%]
 Re: (Gts-Coupe) » Reply  Edit
Just get the diypnp nippon denso 76pin kit for $425. if you need help email me.
GTS-COUPE
162 posts [100%]
Lancaster PA
 Re: (98AE111) » Reply  Edit
It won't be for a couple months but I have no experience in soldering that kind of stuff. I can do wires but boards and stuff scares me lol
mr220v
1246 posts [100%]
Atlanta GA
We had working idlecontrol and vvt.
Let me know if you want one of these.
Modified by mr220v at 10:58 PM 11/29/2012
GTS-COUPE
162 posts [100%]
Lancaster PA
How much would you charge email me at coupeae86@yahoo.com
