 Silvertop 20 RPM limiter
VrolixD
4 posts [100%]
Pelt Limburg
 Silvertop 20 RPM limiter Reply  Edit
Hello,
I have an original silvertop 20v in my car with a close ratio TRD gearbox . My topspeed is not high enough with the gearbox . No i want to remove , or change the RPM limiter . Is that possible with an original ECU ?
Thank you !
morgan
6446 posts [93%]
 Re: Silvertop 20 RPM limiter (VrolixD) » Reply  Edit
No
Try searching limiter for more answers, the search button is your best
friend
my 20v in an 86 swap guide
my mess of an 86...
*east coast toyotas forum*
gaijin_rokurunner
1990 posts [100%]
UPPER MARLBORO MD
You might want to try changing your final gear to something lower for a higher mph...you dont want to go increasing your rev limit without the proper modifications to your engine to support higher revs or your top mph will be zero with a blown engine.
170bhp
393 posts [99%]
 Re: Silvertop 20 RPM limiter (gaijin_rokurunner) » Reply  Edit
Yes, it is possible to change the rpm limit of the standard ecu! overclock the ecu by changing the crystal, this is an easy job to do but you will have to do some experimentation with the crystal. If you increase the Mhz of the crystal it will INCREASE the rpm limit BUT it retards timing across the range and leans the air/fuel mixture.
If you don't get too greedy with the crystal you put in, the air/fuel won't be too lean and an adjustable fuel pressure reg might get you back on the money. Adj the timing is easy as the 20v has a distributor just adj the base timing. The vvt point will be altered higher in the rpm range but if your engine has cams this may or may not be beneficial.
We have had a BT std ecu rev limiting at OVER 9000rpm, I wanted an easy way of adj air/fuel and cheap so got hold of a Powercommander to suit a 2009 CBR600RR(it has the same injector plugs as 20v) this allows adjustability of the air/fuel, adj timing and sweet as.
This method of over clocking can also be used on a 16v ecu if you are chasing more rpm if you engine has cams etc.
