 My 20v project (7age 20v)
v33sonata
393 posts [99%]
Phoenix az
 My 20v project (7age 20v) Reply  Edit
And so it starts!
Phase 1 get the 4age 20v working in my AE86.
Phase 2 new pistons in my forged 7a block to work with the 20v head.
Phase 3 Nitrous
Help me clean out the garage. Lots of 4age, 4agze, 20v and turbo parts for sale. Ask and I probably have :)
MoonGT
29 posts [100%]
Sylhet
 Re: My 20v project (v33sonata) » Reply  Edit
Hi!!! Have you started the 7AGE Project? If so would you mind sharing the info and all the pros and cons while doing the project. It'd be apprecaited.
With Regards,
Munawar Helal Chowdhury
v33sonata
393 posts [99%]
Phoenix az
 Re: My 20v project (MoonGT) » Reply  Edit
I have already done a 7ag(T)e just converting to the 20v none turbo. Is there something specific?
GTS-COUPE
162 posts [100%]
Lancaster PA
wouldn't you want stronger rods for the 7a bottom end? I thought i read their not good for anything above 7500 rpm, seeing as the blacktop head see's most of its power up high in the rev range the 7agte would be better for a 16v head.
gaijin_rokurunner
1990 posts [100%]
UPPER MARLBORO MD
Yeah if you want any reliable revability I would invest in some good forged rods...the stock are long and skinny...meaning if you ever over rev them they could snap ....look at some blacktop rods they are shorter and skinny but over reved they will snap...secondly I would invest in custom pistons dont just throw some 4ag pistons in there...send a 20v piston and a 7a piston to CP and have them make a 7a piston with a 20v crown....
v33sonata
393 posts [99%]
Phoenix az
I laready havea fully forged 7a block sitting in the garage H beam rods and Weisco pistions. Pistons will have to be changed out tho
wrenchdad
339 posts [100%]
Natchez MS
 Re: (v33sonata) » Reply  Edit
My 9AGE stroker project is well under way, going with custom crank, rods and pistons from here (running Megasquirt 3 for ECU)
http://www.mrpltd.co.nz/produc....html
Only thing that hasn't come in yet are the rods, block should be ready this week.
The above site also has a modded crank timing gear that will allow both of the stock VVT intake and the exhaust cam gears to be used when using a BT/ST head on a 7AFE block with a 16v timing belt, all the timing marks line up correctly.
just some FYI
later wd
" Second place is just the first loser" the late Dale Earnhardt
v33sonata
393 posts [99%]
Phoenix az
 Re: (wrenchdad) » Reply  Edit
very useful thanks!
MoonGT
29 posts [100%]
Sylhet
The information was very useful. Thanks for sharing the info. Let us know the outcome of the project...
With Regards,
Crownvicman289
1984 posts [58%]
Colorado Springs CO
V33 if you bring the car here I'll tune it for that C56 in your garage. Then the thing will actually run right, you don't know what you're missing.
v33sonata
393 posts [99%]
Phoenix az
 Re: (Crownvicman289) » Reply  Edit
c56?
Crownvicman289
1984 posts [58%]
Colorado Springs CO
The transmission that came with your blacktop.
v33sonata
393 posts [99%]
Phoenix az
dont think thats gonna work being its a fwd tranny and i have a rwd car.
Crownvicman289
1984 posts [58%]
Colorado Springs CO
But I have a FWD and can tune. . .
v33sonata
393 posts [99%]
Phoenix az
well I got a tranny LOL
Crownvicman289
1984 posts [58%]
Colorado Springs CO
I think we're on to something. . . I tune your car and help you clean out your garage. Win win.
Sam_Q
579 posts [99%]
Australia vic
If you need some rwd conversion parts for your 20v then let me know.
s-86.com
v33sonata
393 posts [99%]
Phoenix az
 Re: (Sam_Q) » Reply  Edit
i've already been talking with ya
