 What of the 20v parts will I be needing?
v33sonata
393 posts [99%]
Phoenix az
 What of the 20v parts will I be needing? Reply  Edit
So before I start parting out things I need to know what I need here is a list of the things I am not sure I need or not? Also am I able to use the 20v water pump and altanator?
20v starter
20v flywheel
20v clutch
Thx
Help me clean out the garage. Lots of 4age, 4agze, 20v and turbo parts for sale. Ask and I probably have :)
gaijin_rokurunner
1990 posts [100%]
UPPER MARLBORO MD
 Re: What of the 20v parts will I be needing? (v33sonata) » Reply  Edit
Im using the 20v starter, and alternator you can use the flywheel but you cant use the pressure plate it will hit inside the ae86 bell housing...
