 Damaged Dizzy? Help. Running out of ideas.
scotttombaugh
14 posts [100%]
Venice Fl
 Damaged Dizzy? Help. Running out of ideas. Reply  Edit
Good day all,
I have my ST running on BT electronics started and idling rough but it dies at the instant throttle is applied.
Initially I was getting a code 12.
When I got the motor the distributor had been hit pretty hard and the sensor wheel was pushed up against the pickup coils.
When I couldn't get the proper gap I persuaded the sensor wheel (whacked the shaft with with a hammer) into the correct position.
Now the code is cleared and I get the correct gap and ohms but I think it may be moving.
Has anyone else had an issue with ether a silver or blacktop dizzy exhibiting this behavior?
I have no CEL codes.
I have 40 PSI at the fuel rail. (Checked with fuel meter).
I have checked all the ECU pin outs to the BGB and they test good for voltage, ground and/or ohms.
I have good voltage at the Water Temp, ISCV and AIT sensors and the sensors themselves ohm out to the BGB.
The TPS ohms out good to the BGB.
I have new distributor cap, rotor and plug wires.
I have a new battery.
I have swapped out the coil and igniter.
The vacuum hoses under the throttle bodies are all attached and in good condition.
Thanks,
Scott
Reggae Rules...
4374 posts [96%]
Wellington, NZ
 Re: Damaged Dizzy? Help. Running out of ideas. (scotttombaugh) » Reply  Edit
Have you checked the ignition timing ??
jondee86 has been a member for 735,126 days.
scotttombaugh
14 posts [100%]
Venice Fl
 Re: Damaged Dizzy? Help. Running out of ideas. (jondee86) » Reply  Edit
Thanks Jondee86,
With #1 cylinder at TDC, and rotor pointing to #1 plug wire the intake cam timing mark hits the mark on the valve cover, approx 12 o'clock and the 2nd timing mark is at 3 o'clock. The exhaust cam timing mark hits the mark on the valve cover, approx 12 o'clock and the 2nd timing mark is at 9 o'clock. This makes the 2nd timing marks on the intake and exhaust face each other.
Reggae Rules...
4374 posts [96%]
Wellington, NZ
I was thinking more of checking the spark timing with a timing light.
Short TE1 and E1 in the check connector/diagnostic box. With the engine idling
you should read 8-12 deg of timing advance on the crank pulley mark against
the timing scale on the lower cam belt cover.
morgan
6446 posts [93%]
There's a few screws, 2 iirc, that keep the sponsors on place. Loosen the to set the ap, then tighten back up. No need to adjust the shaft.
my 20v in an 86 swap guide
my mess of an 86...
*east coast toyotas forum*
scotttombaugh
14 posts [100%]
Venice Fl
Looks like I need to hunt down an Open Circuit relay problem. Runs with FP to B+ jumper-ed in the diagnostic terminal.
Any advice?
scotttombaugh
14 posts [100%]
Venice Fl
I checked the Open Circuit Relay to the BGB and it ohms good and when I apply voltage to either STA and E1 or B and FC I can hear the contact close.
When I get voltage at Fp when cranking but not when started.
With the key on I get 12V at FC.
Is this then an ECU issue?
Reggae Rules...
4374 posts [96%]
Wellington, NZ
Just a random suggestion (since I don't have a 20V myself), but I have seen this
come up a few times before when 20V's don't run well. Have you got the STA wire
hooked up to the ECU ? Don't even know for sure what it does, only it has cured a
few weird problems for other folk, so worth checking
98AE111
103 posts [100%]
Are you using the BT Harness?
scotttombaugh
14 posts [100%]
Venice Fl
Thanks for the suggestion.
The STA is hooked up.
scotttombaugh
14 posts [100%]
Venice Fl
 Re: Damaged Dizzy? Help. Running out of ideas. (98AE111) » Reply  Edit
I am using a combination of the Blacktop engine harness and original body harness prepared by MR220V.
98AE111
103 posts [100%]
swapped out distributor
Reggae Rules...
4374 posts [96%]
Wellington, NZ
Gonna assume that you are using the AE111 (BT) 4-pin Circuit Opening Relay.
If so, the logic appears to be that the ECU sees 12V on the STA pin when the key
is in the CRANK position, and then supplies a ground on the FC pin to close the COR.
That is, the operation of the COR is totally controlled by the ECU. Since you don't
have an AFM to act as a safety cutoff in the event of "engine stopped, ignition on"
situation, the ECU will use some other input to decide that the FP should be off.
Shorting B+ and FP bypasses the COR and puts 12V directly on the FP.
From what you have said, the engine starts and idles, but dies with throttle.
However, if you short B+ and FP the engine runs normally. Is this correct ??
scotttombaugh
14 posts [100%]
Venice Fl
Correct. It runs with B+ and Fp shorted
scotttombaugh
14 posts [100%]
Venice Fl
I am running the original 5 pin relay.
Reggae Rules...
4374 posts [96%]
Wellington, NZ
With the original AE86 5-pin relay, it should work like this...
1. Turn the key ON and you should get 12V at pin 2.
2. Pin 1 is connected to the Fuel Pump.
3. Pin 4 connects to FC on the ECU.
4. Pin 3 receives 12V when the key is in the CRANK position.
5. Pin 5 is connected to chassis ground.
So the sequence is... the COR is energised by 12V from the START circuit for as
long as the key is in the CRANK position. The ECU also receives 12V on the STA
pin. This tells it to fire the injectors with extra enrichment for starting.
When the ECU decides the engine is running, it provides a ground on the FC pin
and energises the COR via the second coil. This will happen quickly enough to
make sure that the second coil is energised before the "START" coil is de-energised.
If your engine starts and idles, all this must be happening. But if you don't get a
good 12V supply to the FP from the COR while the engine is running, it suggests
you have a poor connection on the supply side of pin 2. I'd try testing that supply
with a 24 Watt incandescent bulb, or maybe run a temporary test lead direct from
the battery to pin 2, and see if it makes a difference.
HASportAE86
IE Gutter Trash
4096 posts [84%]
Loma Linda CA
The FC wire isn't hooked up right on the 20v ecu. FC pin needs to go to the green/red wire of the circuit open relay. You have fuel for the cranking but the relay will not stay on in the RUN position. Your engine is running off the initial fuel prime for cranking, then runs out of fuel and dies because the relay isn't staying on. Cut the green/red wire at the COR and connect to pin FC, so that you have a wire running from the COR to the ECU.
This was why my first 20v swap wouldn't start. Ohhhh memories <3
Side note: Jondee is an ocean away and is always on the same page tech wise as me. Dope Cheers my kiwi friend
Email/Paypal "heyvanilladan@hotmail.com"
SwangBiz Chassis Products
http://forums.club4ag.com/zero...age=1
MFactory Longer T50 5th Gear Group Buy
http://forums.club4ag.com/zerothread?id=113077
Loud Pipes Save Lives -Swangbiz
Honda Master Technician/ASE Master Technician
Reggae Rules...
4374 posts [96%]
Wellington, NZ
 Re: Damaged Dizzy? Help. Running out of ideas. (HASportAE86) » Reply  Edit
Hey Dan... you do good work Hope you had a good year, and that
2013 will be even better. Happy New Year to you, and all club4AG members
And remember... don't and drive !!
