 20v head with carbs?
davidb
11 posts [100%]
effort PA
 20v head with carbs? Reply  Edit
i have been wondering this for some time now and i can't find anything out. i'm almost positive it can't be done but a friend of mine thinks otherwise. could you put a twin carb intake on a 20v head? help me settle this argument
morgan
6446 posts [93%]
 Re: 20v head with carbs? (davidb) » Reply  Edit
yes, theres a bunch of threads on this forum regarding it, with pics. search harder.
my 20v in an 86 swap guide
my mess of an 86...
*east coast toyotas forum*
286 posts [100%]
Carbondale Co
You could with the right adapter plate but why?
It would be like putting horseshoes on your tires.
http://matrixgarage.com/
AW11
E51
Blacktop, all stock internals
4AGZE ECU, 3SGTE AFM, 4runner coil, DSM T25, 1JZ 380CC injectors, W2A IC
morgan
6446 posts [93%]
 Re: 20v head with carbs? (yoshimitsuspeed) » Reply  Edit
i said the same thing a while back, but the guy that did it made some impressive #'s with the carbed 20v, as archaic as it was.
my mess of an 86...
286 posts [100%]
Carbondale Co
 Re: 20v head with carbs? (morgan) » Reply  Edit
Quote, originally posted by morgan »
You might be able to tune a carbed motor to come close to rivaling EFI but the real problem is that if you change the barometric pressure or altitude slightly, even changes in humidity, temp or weather conditions and suddenly the carbed motor will start falling much shorter.
AW11
E51
gaijin_rokurunner
1990 posts [100%]
UPPER MARLBORO MD
sure it can be done...the 20v is like any other engine out there you just need the proper intake manifold
