 clutch master/slave woes PLEASE HELP
AE ALL DAY
116 posts [99%]
miami fl
 clutch master/slave woes PLEASE HELP Reply  Edit
88 corolla wagon swapped with 91 smallport 4age
new master/slave cylinder clutch line had a rubber hose and was replaced with hardline.
i keep losing pressure every two days i bleed it regain pressure and then it slowly loses pressure absolutely no visible fluid loss like i said new master and slave this is my daily and i need to figure this out ASAP any insight will help thanks
:thumbup: PaSaNdO rOlO
Reggae Rules...
4374 posts [96%]
Wellington, NZ
 Re: clutch master/slave woes PLEASE HELP (AE ALL DAY) » Reply  Edit
Pedal height from floor adjusted correctly ? You should have about 1/8" of freeplay
(measured from pedal fully up) before the pedal actually starts to move the master
cylinder pushrod. And about 3/4" of pedal movement before you start to feel resistance
from the clutch.
Ha Just remembered you have a transplant. So what I said above relates to RWD,
but I am pretty sure the same setup applies to FWD and most old Corollas. I'd have
to reasearch, but you can do that. Main thing is to make sure that the pedal has
freeplay, and the piston is allowed to move all the way back in the master cylinder.
jondee86 has been a member for 735,126 days.
AE ALL DAY
116 posts [99%]
miami fl
it does have freeplay when its fully bled the pressure feel amazing after a day or two it get sluggish hard to put in reverse all until it gets to the point where theres no pressure
Reggae Rules...
4374 posts [96%]
Wellington, NZ
 Re: Clutching at straws.... » Reply  Edit
If you bleed the system, and it works fine. Then it gets soft and spongy, so you
bleed it again, and you get air out, it means that air is leaking INTO the system.
There is no sign of fluid leakage/loss of fluid (did you check for any fluid on the
carpet under the clutch pedal ?). So where does air get in that fluid can't get out ??
About the only place I can think of would be thru the slave cylinder piston seals.
There are (should be) two seals on the piston. One designed to keep the fluid in,
and one designed to keep air/water/crud out. If the seal nearest the outside air
was accidentally installed the wrong way round, there is a chance that air could
get drawn in if the fluid pressure went negative.
I don't actually know if it goes negative (below atmospheric), but I guess it could
happen when you release the clutch. Other than that, I'm out of ideas So if
nothing else helps, it might be worth taking the slave apart and checking the seals.
» Return to Cars - FWD (AE, EP, etc...)
