 20v rings different than 16
whitespartian
978 posts [97%]
 20v rings different than 16 Reply  Edit
go I'm going to assemble this bt bottom end I have (spun a rod bearing) and went to put on some 16v rings and the 1st compression ring on the 20v piston is smaller that the 16v. very interesting. I didn't know this, what are you guys using for rings in your 20v's (stateside). I decided just to use my old rings as the engine had good compression and was just honed, but I'm missing one I only have 3. so if anyone has a std bt ring they wanna part with Lmk. if not. where are tall getting yours in the states
will trade roll cage work for overfenders, flares, carbon/fiberglass hood,
give me a call, or text is best
drift warrior fabrication, clarksville Tn
Carl -(909)435-8206
Crownvicman289
1984 posts [58%]
Colorado Springs CO
Some smallport rings should do the trick, upper compression ring is 1.2mm and lower is 1.5mm IIRC.
