 How To Get DLI on Stock 20V ECUFirst  < 18 19 20 21 22 >  Last
me2kimi
6 posts [100%]
Pj Selangor
I already have the service manual. Ok thanks for the reply.
My current timing is not at 10* BTDC, I've retarded as my engine pinging like crazy.
http://me2kimi.blogspot.com
jmtc1610
89 posts [100%]
Antipolo Rizal
 Re: (me2kimi) » Reply  Edit
Need help. Any one has wiring diagram using 1nzfe/2nzfe COPs on 4age 20v?
Duy-
40 posts [100%]
Vancouver BC
 Re: (70xin) » Reply  Edit
any update on this with the tacho booster? also can you clarify how you made an external tacho booster?
me2kimi
6 posts [100%]
Pj Selangor
hi, I've made my external tacho booster. just simply replace stock coil with a relay. Take 2 wire from coil and connect it to relay coil.
Relay will ticking and rpm are alive.
VitriumGTS
4730 posts [96%]
San Jose/San Diego CA
Smart idea, replacing a coil with a small relay. I imagine it will eventually wear out and stop making a clicking noise
AznTKDmstr
349 posts [100%]
TX
 Re: How To Get DLI on Stock 20V ECU (VitriumGTS) » Reply  Edit
Soooo in got my blacktop running on the cop's! The engine seems to rev freely all the way up to the higher rpm's!
I have both my stock ignitor and coil plugged in and attached to a metal bracket. But the bracket is not grounded to the chasis. If I bolt the bracket (with ignitor and oil attached) to the chasis, the car wont start. If its only my ignitor on the bracket (the coil lying on my carpet) the motor won't start either.
When I start the engine with the bracket on my carpet and then run a wire from the bracket to the chasis, the car turns off. Seems like I have a grounding issue?
Any ideas guys?
Thaison Nguyen
Duy-
40 posts [100%]
Vancouver BC
 Re: How To Get DLI on Stock 20V ECU (AznTKDmstr) » Reply  Edit
Try separating your coil from the bracket and bolt the bracket down to the chassis with the igniter, ground the coil somewhere else on the chassis.
Now as for my problem, not so much a problem as curious to what it means...
Basically when the stock coil fires (then grounds to chassis) the original grounding point that goes through the igniter is what gives the igniter the igf signal which it then sends to the tach ecu and tach right?
So what I'm not understanding is, I'm using d17a coil packs and they work without a problem, perfectly and fit with no modification what so ever.
Switched to 1zz, minor modification but works none the less
Switched to 1nz, more modification but fits beautifully under the valley cover
Alright so they ALL work fine... But while running the 1nz, at idle my tach needle would bounce all around the place. As soon as I rev the engine it goes back to where it's suppose to. My idle isn't changing but the tach is just bouncing.
The tach almost has nothing to do with the cop anymore from what I understand, so what would cause this? I remember reading someone else having the same issue but I can't seem to find it again
bbq_chickenwing
51 posts [100%]
Melbourne vic
signal noise, try a RC filter.
Duy-
40 posts [100%]
Vancouver BC
 Re: (bbq_chickenwing) » Reply  Edit
Ahh that's kinda simple, would hooking up an rf suppressor to my igniter do the trick or is the signal noise coming from the 1nz coil packs themselves
Reggae Rules...
4374 posts [96%]
Wellington, NZ
 Re: (VitriumGTS) » Reply  Edit
Quote, originally posted by VitriumGTS »
The moving parts of the relay are not required. You can remove them, or secure
them with a zip tie, to get rid of the buzzing noise.
jondee86 has been a member for 735,126 days.
bbq_chickenwing
51 posts [100%]
Melbourne vic
on tacho signal line/wire.
rollacpe
16 posts [100%]
Honesdale Pa
 Re: (all) » Reply  Edit
For anyone using D17 Honda COP's, the wiring order from left to right when looking at the COP from the top with the plug facing you is as follows:
Left pin - Signal
Center Pin - Ground
Right pin - Power
Garage Warrior
Jehuty77
238 posts [100%]
Hamilton Ontario
How do yo check ignition timing if your running COPs, with the stock setup we clip the timing light on the #1 spark plug wire, how on cops?
Here the first attempt video, revving up and down running like ass
http://www.youtube.com/watch?v=Q_ASYk7_GBo
1987 Corolla SR5
Contact Me/MSN Me at Solidsnake_xxx@hotmail.com
rollacpe
16 posts [100%]
Honesdale Pa
 Re: (Jehuty77) » Reply  Edit
Jehuty - Cut an old spark plug wire and stick the cut end in your COP and put the other end on the plug. Hook your timing light up to the plug wire and time it that way. make sure your connections are solid.
Garage Warrior
morgan
6446 posts [93%]
^ yup, on p.19 theres this pic...
Quote, originally posted by BKH808 »
Picture from balmos thread.
my 20v in an 86 swap guide
my mess of an 86...
*east coast toyotas forum*
rc.square24
326 posts [100%]
Vancouver BC
Try if the timing light picks up a signal by clipping the pickup directly over the COP harness. It worked for me and some others so no need for the spark plug wire extension.
RAVANA
4 posts [100%]
colombo batteramulla
Hi
Cant we get G1 and G2 signals from the distributor and use a signal booster and batch fire the COP on a 4AGE20?
RAVANA
4 posts [100%]
 Re: How To Get DLI on Stock 20V ECU (morgan) » Reply  Edit
Hi
ae86addict
83 posts [100%]
laval quebec
 Re: (jmtc1610) » Reply  Edit
anyone can provide me the 1nzfe COP pinout with wires colors !? thanks !!!
Sam_Q
579 posts [99%]
Australia vic
 Re: (ae86addict) » Reply  Edit
wire colours change, instead use what's on my site:
http://s-86.com/s-coilpacks.html
or buy the latest 86garage magazine
s-86.com
XiaoKanG
2 posts [100%]
kota kinabalu sabah
Hello all, I'm new to this forum.
I wanna ask can anyone provide or advice me where can i find those Ultra's MDI Direct Ignition System digital signal sensor (from hall effect shutter)? ASAP !!!
Thank you for helping....
ae86addict
83 posts [100%]
laval quebec
i have a little problem with my blacktop running on COP !! my engine have like a fuel cut at around 5000 rpm ...
my oem igniter is not pluged ..
i have a os sensor check engine
can it be cause by one of this ? or a faulty vvti switch ?
Sam_Q
579 posts [99%]
Australia vic
it can be caused by your OEM ignitor not being plugged in!
s-86.com
ae86addict
83 posts [100%]
laval quebec
 Re: (Sam_Q) » Reply  Edit
i can plug the ignitor but if i ground it the car stall ...
Jtek
10367 posts [100%]
Portland OR
what do you mean ground it...bolt it to the engine bay? It grounds that way.
ae86addict
83 posts [100%]
laval quebec
 Re: (Jtek) » Reply  Edit
the ignitor is grounded by the casing .... and if i bolt the ignittor to the car the engine stall ....
Sam_Q
579 posts [99%]
Australia vic
sounds like a wiring fault to me
s-86.com
Jtek
10367 posts [100%]
Portland OR
yea that's pretty odd. mine wouldn't run at all without that original (at least one like it) coil plugged in and zapping like crazy!
ae86addict
83 posts [100%]
laval quebec
cannot be cause by the 02 sensor check engine ? the ecu make the fuel cut at 5000rpm for protection ..??
Sam_Q
579 posts [99%]
Australia vic
well you could check your fault codes but once you fix your wiring fault
s-86.com
