 How To Get DLI on Stock 20V ECUFirst  < 18 19 20 21 22   Last
ae86addict
83 posts [100%]
laval quebec
 Re: (Sam_Q) » Reply  Edit
fixed after reading pages 16 and 17 of this post !!
the trouble come from the fact that i didnt run the factory coil and igniter ... now all is ok and rev to 8k !!
i set my timing to 10 degrees but it run like crap ... back firing in exhaust on decompression ... and in the intake sometime ..
can anyone suggest me an other timing setting ??
morgan
6446 posts [93%]
 Re: (ae86addict) » Reply  Edit
Quote, originally posted by ae86addict »
see? i wasnt bs'ing you.
my coil is not pluged because i run on coil on plug !
and the igniter is pluged and bracket grounded but i dont really used them with the COP setup ..
Quote, originally posted by morgan »
so? you should still have the coil and ignitor plugged in, you need a tach signal and other stuff. which wiring thread did you use? check the one i wrote, links in my sig, to see how to wire the COPs up utilizing the ignitor and coil.
the coil needs to be plugged in too, and grounded. you dont use them but the ecu does.
as for timing, did you jump the diagnostic terminals E1 & TE1 before setting? jump them, then set to ~10 degrees. should be ~16 degrees un-jumped.
my 20v in an 86 swap guide
my mess of an 86...
*east coast toyotas forum*
AznTKDmstr
349 posts [100%]
TX
 Re: (morgan) » Reply  Edit
Got my dr tweak harness and I've grounded my ignitor and my coil. Engine cranks but doesn't fire up.
When I unground my coil and ignitor, the engine fires up and immediately dies and throws code 14. My guess is its because the ecu isn't getting the IGF signal (since the ignitor is ungrounded).
I tried this with two other workin ignitors and had the same issue with both.
So why does my engine fire up with the ignitor/coil ungrounded and doesn't when it's properly grounded?
Dr tweak 20v to gts harness with cop
1nz cops
Stock coil/ignitor
Thaison Nguyen
morgan
6446 posts [93%]
 Re: (AznTKDmstr) » Reply  Edit
i had the same problem, coil was faulty.
my mess of an 86...
AznTKDmstr
349 posts [100%]
TX
Tried a different coil and still no luck.
Thaison Nguyen
Dr Tweak
678 posts [100%]
Everyone I know using 1NZ coils has issues with them. Use 1ZZ coils instead.
-Dr Tweak, Toyota Engine Swap Wiring Expert Extraordinaire
Email us at sales@tweakdperformance.com or visit us at http://www.tweakdperformance.com/
AznTKDmstr
349 posts [100%]
TX
 Re: (Dr Tweak) » Reply  Edit
My problem was bc i was using cheap ebay taiwan/china cop's! DON'T DO IT! JUST GO TO THE JUNKYARD
Thaison Nguyen
$amuel.inc
11 posts [100%]
So Cali Cal
Hey guys,,,,,,ive been trying to get my car started for a few days now.....
Its starts up then shuts rite off.... and i keep burning coils( 3 allready). i need the coil wiring or idk..... and i grounded my power wire from coil by accident and it started arcing and trying to stay on.....???, my wiring all jacked up,,,, i need help pls... ill try another.... or is the tach booster print out available???
Bad grammer sorry
Life's a catch...........
My 20v Vids below: Diy harness, Honda cop, Sr5
_
https://www.youtube.com/watch?...elmfu
$amuel.inc
11 posts [100%]
So Cali Cal
 Re: ($amuel.inc) » Reply  Edit
Nvm.........
Did some more reading ,,, came across my wires being crossed.......fired up nice :0 :0 :0hhhhhhhh yeahhh revs high and sound good,,,,, need to work on vacuum n0w............Thanx for everything guys...This thread Rockz
_
dr.occa
2382 posts [93%]
The Lonestar State
I know autosportlabs is about to put out a new stand alone ignition system that does sequential ignition with COPs.
On a similar thread of thought, had anyone considered an EDIS-8 used for sequentially firing 4 Coil On Plugs?
Taken from my 86garage.com thread:
Quote, originally posted by "dr.occa" »
I've drawn up this diagram to illustrate what I'm proposing:
This uses a stand alone programmable ignition setup that incorporates the FORD EDIS modules where only the positive and negative portion of any coil on plug is necessary e.g. Megajolt Lite or Megasquirt.
These systems require a 36-1 trigger wheel and VR Sensor (pick up).
The detail I'm still unclear about is if the vr sensor would still need to be positioned 50 (5 teeth as per a V8) before the missing tooth of the trigger wheel or would it need to be 90 (9 teeth as per an I4).
86 Garage Magazine
"Strictly All Things 86"
Jtek
10367 posts [100%]
Portland OR
this is exactly why mine wouldn't run. That's where my 'zapping like crazy' post was meant for lol
Running FIVE coils hahahhah
BTW anyone need a coil/igniter+bracket for 20v? $60 shipped!
Jtek
10367 posts [100%]
Portland OR
It doesn't matter where you put the VR sensor. It finds the missing tooth and starts ignition then.
I've done EDIS and it's fantastically built and stupid easy to use, but spark advance is controlled by the ECU and I don't know if factory toyota ECU uses the same spark advance as ford and I hate megasquirt lol
dr.occa
2382 posts [93%]
The Lonestar State
 Re: (Jtek) » Reply  Edit
Quote, originally posted by Jtek »
It depends in regards to TDC that is.
EDIS is pretty solid. It'll even run with just the module, trigger wheel and vr sensor alone...but in 10 limp home mode
86 Garage Magazine
Jtek
10367 posts [100%]
Portland OR
forgot to mention that on mine the trigger wheel was adjustable.
