For reference only, all new posts and communications should be posted in the new forums at
 4AGE redtop???
91 posts [100%]
Atlanta GA
 4AGE redtop??? Reply  Edit
I just installed a JDM redtop motor in my 86, and it doesnt feel like it was as quick as it was before with my bluetop, I am using the bluetop ecu and was wondering if thats my problem? If anyone has any ideas please help, thanks!!
Road Race!!!! Supercharged F22C 86
914 posts [90%]
boro boro style
i been wondering the samething
anyone got an answer?
AE86 Nights
geo metro(4agte)
kia sepia(b16)
volvo s60 wagon(2jgte)
toyota tercel(1zzfe)
nissan maxima(sr0det)
mitsubishi mirage(4g63)
AE86(1UZ-FE) :P
TE 4 Door(4age)
1377 posts [94%]
IF you run redtop everything, (efi, injectors, ecu etc.) you get 140 crank hp (whats that +10 from the stock bluetop?). since you are using bluetop EFI, most likely bluetop IM w/ adapter. the only real difference that might be felt is that the redtop is probably less "tired" (has less miles) then your stock bluetop.
i did my hicomp swap a year ago, it feels sluggish under 4K, because 1) no more tvis, 2) heavier internals but once you get past that, it pulls a lot harder than the bluetop that it replaced. im using IK20 denso plugs, hicomp fuel rail, hicomp fpr, hicomp injectors (resistor bypass), bluetop efi and bluetop IM w/ adapter.
also, redtop motors have less lift on both in/ex cams. and the motor is designed to be used with the redtop IM that doesnt use tvis. you go and stick the tvis IM and im sure it messes sh!t up
» Return to Cars - RWD - (AE86, TE, KP, RA, TA)
