 HELP: Need a picture of under the ITBs, VACUUMFirst  1 2 3 4 >  Last
Plex
3761 posts [89%]
Suisun City CA
 HELP: Need a picture of under the ITBs, VACUUM Reply  Edit
Hey all, I forgot how the vacuum lines are hooked up on my blacktop, I took them all off to clean up the ITBs... lol I SHOULD have taken pictures.
Pics from under the ITBs would be awesome, I dont remember how the dashpot goes, or any of that...
Summa Cum Laude Graduate, AE86 University Class of '02
ae924afdx
2319 posts [98%]
Somewhere NC
 Re: HELP: Need a picture of under the ITBs, VACUUM (Plex) » Reply  Edit
i can get you pics tonight.. i'll be on msn. I want to get rid of all inncesesary parts.. even the pipes//. etc etc.. to make it look clean.
talk to you later..
Email: jose_centeno_perez(AT symbol)hotmail.com
supra_750
325 posts [100%]
Victoria texas
any pics greatful i need this as well
MY fully built 20v n/a build thread:
http://forums.club4ag.com/zerothread?id=74394
http://www.facebook.com/supra750
Flowisode_Zero
2784 posts [99%]
Glendale AZ
I would love some pics of a cleaner setup. PLEASE post pics of how you routed everything and what can be removed.
Why do noobs call their hatch a HATCHI, but no one calls their coupe a COUCHI?
marvinng
201 posts [100%]
Richmond BC
domi
mod
1129 posts [100%]
St. Ann MO
STICKY THIS!!!
Msglength, since the forum doesn't like caps abuse.
GeneralPostingPolicy:
...if it sounds sarcastic - don't take seriously,
if it sounds dangerous - do not try this at home, or at all...
and if it offends you - just don't listen to it!
supra_750
325 posts [100%]
Victoria texas
omg thank you marvinng
VitriumGTS
4730 posts [96%]
San Jose/San Diego CA
strange, when I picked up my blacktop the purge and dashpot lines were in the opposite positions so i kept it that way for my 20v
marvinng-
i talked to you before about the itg filter and I'm running one now with a 3/8 spacer adapter:
hows that tom's FPR? i'm looking for one myself
Flowisode_Zero
2784 posts [99%]
Glendale AZ
Can you take some better pics of how you routed your catch can? Ive seen it mounted so many different ways and I would like to know whats right.
VitriumGTS
4730 posts [96%]
 Re: (Flowisode_Zero) » Reply  Edit
flowisode-
for my catch can, I have one line at the back of the valve cover, and the other? goes down to the open ground hahaha I need to dive back into my box of unused ae111 engine parts and grab the unused booster line of throttle body of cylinder 1. If I plug other end of the catch can hose into that, it'll be a sealed system allowing only blowby to be reburnt.
marvinng-
heres what I was talking about:
note the throttle body of cylinder 4 vacuum fitting goes to filter 1 of the throttle opener (dashpot) and the other one is evap purge line
I'm sure swapping those will have no ill effects on the engine...
Modified by VitriumGTS at 7:02 AM 4/15/2008
Modified by VitriumGTS at 7:26 AM 4/15/2008
Flowisode_Zero
2784 posts [99%]
Glendale AZ
Thank you for the pics, that how I have mine routed also, but this thread said different http://forums.club4ag.com/zerothread?id=2084 and there are so many damn vacuum lines on the 20V I wanted to see how you did it.
TheDingo8mybaby
Hesketh Racing
701 posts [100%]
Sunnyvale CA
 Re: (marvinng) » Reply  Edit
Stickied because this is a common problem for people doing the swap.
VitriumGTS
4730 posts [96%]
flowisode-
More about the catch can: we know the 20v has a pcv valve that leads directly into a vacuum block on the ITBs...So I just assumed the opening on the back of the valve cover was just another outlet into the stock plenum. I'm also basing mine on this Japanese setup:
picture side note: yet another 20v running an MDI DLI system
VitriumGTS
4730 posts [96%]
then again, I also have this japanese setup pic with a plugged vacuum block:
Modified by VitriumGTS at 8:19 AM 4/15/2008
mr.icetdizzle
493 posts [96%]
ms
awesomeness. so needed the vaccumm pics
1985 toyota corolla gts coupe silvertop
tuan_n_pham@yahoo.com
ae924afdx
2319 posts [98%]
Somewhere NC
 Re: (mr.icetdizzle) » Reply  Edit
so the only important one is the map sensor.. which is around the fuel pressure regulator.. the rest i guess is going to be capped off. Also the brake booster, idle valve and pcv ones i am going to keep them.. the rest.. Gone.
I was wondering.. what the "vacuum solenoid that is hooked up with the "diagphram" connected to the throtle when is closed {i dont know if you guys get it..} .. I want to know what is that for.. and if is really needed. I think is the evap one but not sure.
Thanks a lot.
KID
135 posts [100%]
Frankfurt
this is what hlped me
marvinng
201 posts [100%]
Richmond BC
 Re: () » Reply  Edit
ae924afdx - the big diaphragm thing is the throttle opener. i'm pretty sure it's needed.
VitriumGTS - i think you're correct. i swapped both "A" & " B" lines last night and worked just fine. btw, do you get much blowby in the oil catch tank?
right now i have a k&n crankcase filter (see 1st pic) for the breather hole behind valve cover, which seems to work so far. i have an oil catch tank from the old 16v setup which i may put back in, but i am planning install the crankcase filter on the other end of the catch tank (if it fits ... lol) instead of closing the loop.
marvin
jspexae102
1141 posts [91%]
Union City CA
while on the subject, what do you guys do with the 2 brake booster vacumm lines? just plug one of them up or T them together @ the brake booster?
Memoryfab.com
M-F 10A - 6P PST
Sat by appt. only
510.489.5866
joel23
185 posts [100%]
 Re: (jspexae102) » Reply  Edit
great stuff and pics lots of help....
VitriumGTS
4730 posts [96%]
jspexae102
you can plug up the cylinder 1 booster line with a bolt (w/teflon tape) and use cylinder 4's. I bent mine with a metal pipe and aimed it upward to where its nearly straight and connected a spare sr5 booster line to it
ae924afdx
2319 posts [98%]
Somewhere NC
 Re: (VitriumGTS) » Reply  Edit
I was going to ask the brake booster question right know.. hehehe. today i took all the lines out and took a good look at it.
I took the cyl 1 brake booster banjo pipe and bolt it on cyl 4.. that way it aims upwards..making it easy to hook it up to the rest of the line going to the booster. I am going to plug cylinder number 1 with a bolt and hopefully it'll work fine.
Any feedback on how it works? Is it just fine by using cyl#4 for the booster?
Thanks.
marvinng
201 posts [100%]
Richmond BC
 Re: (ae924afdx) » Reply  Edit
Quote, originally posted by ae924afdx »
Thanks.
yup that's how it works.
marvin
jspexae102
1141 posts [91%]
Union City CA
couple more pictures (not mines but i'm hosting them)
Memoryfab.com
M-F 10A - 6P PST
Sat by appt. only
510.489.5866
KID
135 posts [100%]
Frankfurt
can somebody tell me were this line goes to???
marvinng
201 posts [100%]
Richmond BC
 Re: (KID) » Reply  Edit
air intake for ISCV. on a stock 20v it goes to the intake plenum (i.e. filtered air).
i put a K&N crankcase filter over it.
marvin
teamkunimitsu
350 posts [100%]
Fukuoka / O.C. ca
pics are a great help guys! thanks to you guys got it running smooth except one thing, idle is way too high... where is the idle adjustment? or ami gona have to recalibrate?
sunami02
871 posts [100%]
Griffin GA
 Re: HELP: Need a picture of under the ITBs, VACUUM (teamkunimitsu) » Reply  Edit
Man mine is too does your stay up at 5K......
teamkunimitsu
350 posts [100%]
Fukuoka / O.C. ca
it doesnt idle at 5k though... geez thats kind of high. it actually idles at 2500. Im looking around for the adjuster for idle without messing with calibration of throttle bodies. if anybody knows please let us know. as for sunami02 i think ur set screw is mis adjusted or something causing ur throttle plate to stay slightly open OR maybe a big leak in intake side manifold vacuum etc...
rhymz
474 posts [95%]
Georgetown
mine is idling at around 1.5k - 2k...with the price for gas these days that idle sucks...i was told its the coolant temp sender being a big b!tch...
as for the 5k idle...u definitely got ur idle control hooked up wrong...check all ur hoses...mainly the iscv, and the 2 idle up valves...
