 HELP: Need a picture of under the ITBs, VACUUMFirst  < 2 3 4 >  Last
titus86
336 posts [100%]
spartanburg sc
 Re: (Mikare) » Reply  Edit
Where can I get an adjustable valve for the iscv? Mines runs roughly around 1500 rpms. Havnt tried cleaning it though.
car: 1984 ae86 hatch
model: sr5 with gts full conversion
engine: ae111 "blacktop" 4age (in the works)
suspension: D2 sports 36way adjustable
Candunguito
124 posts [100%]
Chicago IL
 94 rolla » Reply  Edit
How should I run this hoses for my 94 Rolla?
Drivers Side.
Pink/to Intake.
Red/ Fuel Return (FPR) (my 94 rolla has 2 return gas line)
Blue/To Charcoal Canister
Green/To Power Steering ( no other hose to
Passenger Side
Blue/to Brake Booster (Both lines
beyjer
526 posts [99%]
San Gabriel Valley Ca
 Re: 94 rolla (Candunguito) » Reply  Edit
anyone notice the difference here?
revive your plastic trim/lights: http://forums.club4ag.com/zerothread?id=81335
titus86
336 posts [100%]
spartanburg sc
 Re: 94 rolla (beyjer) » Reply  Edit
Hey beyjer u said yours ran better running your lines this way?
beyjer
526 posts [99%]
 Re: 94 rolla (titus86) » Reply  Edit
Quote, originally posted by titus86 »
yup, although i haven't been able to get it to run right, i think i may have a wiring or timing issue at this point...
titus86
336 posts [100%]
spartanburg sc
Oh ok cool imma have to try that out cause mines still runs like crap... I never had time to mess with it much cause it's getting cold here in south Carolina.
beyjer
526 posts [99%]
what are your symptoms?
titus86
336 posts [100%]
spartanburg sc
Well it runs like it's too lean or something.. In 1st gear it feels normal but then 2nd gear and on when you floor it, it sputters and feels like has no power or something with little sputtering involved after 3500 rpms, And I "think" I got my high idle to go away. I changed out my antifreeze and blead the air out so hope it's ok for now idleing around 800-900 rpms. I'm gonna warm the car up again tomorrow and see if it stays at idle again just to make sure. Other than that, that's the only symptoms I'm having. Ohhhh and I have a check engine light but can't tell what code it is cause I can't find my Diagnostic plug on my harness made from dr.tweak.
beyjer
526 posts [99%]
kinda sounds like what i'm having, except it's in all gears. going uphil it bogs like crazy until about 5k, idle's at about 1500 - 2000 after warm too.
I've done the following, resetting the ecu after each one w/no change:
1. swaped iscv with a known working unit, no change
2. replaced ecu water temp sensor w/new unit, no change
3. replaced knock sensor w/new unit, no change
4. made sure i was running the correct thermostat and that it's functional, no change
5. swapped map sensor w/known working unit, no change
6. set idle at 800rpm using timing, ran even worse! reset back to 10dbtc
7. adjusted tps, no change
8. changed distributor wires, no change
9. changed air temp sensor w/new oem unit, no change
10. swapped ecu w/known working unit, no change
11. checked all vacuum hoses w/vacuum tester, they all hold pressure and don't leak
The only thing i had left to try was swapping coil/igniter w/known working units, or even swapping wire harness w/known working units.
I sent it over to my mechanic and after about a week, he's still diagnosing...we'll see i guess. at first he though thought it might be the wiring but before that i think he's making sure itb's are synchronized, timing is spot on and all sensors/parts are functional.
i can't wait to get it running correctly, i really hope he finds out what's going on.
wrenchdad
339 posts [100%]
Natchez MS
Have you tried unplugging the VVT solenoid and driving the car to see if that makes any difference? Just thinking it might be in VVT mode when it should not be?
just a thought, wd
" Second place is just the first loser" the late Dale Earnhardt
beyjer
526 posts [99%]
 Re: 94 rolla (wrenchdad) » Reply  Edit
Quote, originally posted by wrenchdad »
just a thought, wd
that's a great idea, i was thinking about VVT as well. I'm going to see what the tech says and if he runs out of idea's, maybe i'll toss that around with him.
titus86
336 posts [100%]
spartanburg sc
Hey guys where's the vvt solenoid located at? I might just have to try that out also to see if my bogging stops cause I also relize that the car runs smoothly after 5500 rpms too.
Modified by titus86 at 11:05 PM 12/13/2010
beyjer
526 posts [99%]
if you're looking at the engine, it's a 2 wire connector on the exhaust side right at the top front of the engine. here's a pic i found online:
titus86
336 posts [100%]
spartanburg sc
Ahh ok so this is what activates vvt? I'll try drivin the car with this unplugged and see what happens. Ill update u on my part about this.
beyjer
526 posts [99%]
you might also want to check the fuel pressure regulator, if that's not operating correctly then it may give you the same symptoms.
i've yet to check mine, just throwing the idea out there
Modified by beyjer at 3:25 PM 12/18/2010
titus86
336 posts [100%]
spartanburg sc
 Re: (beyjer) » Reply  Edit
Ohh good idea I forgot about that one. Good thing I have another motor to steal parts from lol.
beyjer
526 posts [99%]
this thread also seems relevant:
http://forums.club4ag.com/zero...93597
these are the exact symptoms my car has, i'll be testing this if my mechanic can't figure out what the issue is
titus86
336 posts [100%]
spartanburg sc
Yeah I have similar symtoms like that too. I might have to get a hold of a pump and try it out, but it's too cold outside right now where I stay lol. Try the fuel pump and let me know. It's just kinda weird that when I had my bluetop in there the pump was working great.
titus86
336 posts [100%]
spartanburg sc
 Re: (titus86) » Reply  Edit
Ok update, I unplugged the vvt and it runs smoother now. But all of a sudden the idle can't stay consistant. It'll idle at 700rpm but when the check engine light comes on the idle climbs. I think my check engine light is due to no o2 sensor. The sputtering did go away though with vvt unplugged, bad vvt solenoid?
beyjer
526 posts [99%]
bad vvt solenoid?
sounds like it could be the culprit, are you able to get your hands on a new one to test before you buy? if you can't find one locally, then i'd call up simon at pass racing...they can usually source blacktop parts.
still no updates on mine, waiting on this rain to stop
titus86
336 posts [100%]
spartanburg sc
Naw I don't have access to a blacktop one but I do hve a silvertop one. I don't think it's interchangable though. What could cause a solenoid to go bad?
beyjer
526 posts [99%]
i'm not sure, wear and tear maybe or damage during shipping? so many variables...how well did it drive with out it plugged?
titus86
336 posts [100%]
spartanburg sc
It seemed like there was no more sputtering at all. I'm thinkin either it might have stayed in vvt mode the whole time or vvt is bad. Imma search how u can tell if vvt would cause this problem.
beyjer
526 posts [99%]
I just got my car back and did the following:
1. checked sta wire w/test light, got power during cranking
2. swaped fuel pressure regulators, this made a difference in that the car didn't hesitate as much when i stabbed the throttle around 3k - 4k, but it still hesitated a bit.
3. cleaned my o2 and moved it from the downpipe to before the collector, no difference at all.
4. unplugged the vvt solenoid, reset the ecu and tested it...no sputtering at all, smooth powerband all the way to redline and no check engine lights. applied direct current to the solenoid and could not hear any clicking, confirmed the circuit completed as my test light did turn on...i'm thinking this guy needs to be replaced...
i still have a high idle though, about 1300 rpm but the driveability is a lot better. there seems to be no hesitation when i stab the throttle, the ecu just adjusts fuel and the car goes. the itb's sound a lot cleaner now.
I was talking to a friend who advised vvt engages based on load, speed, tps and rpm. still a few more things to check out...
EDIT:
took apart my iscv and cleaned it, no difference.
took out the vvt solenoid and confirmed it's not stuck, when i apply power & ground to the 2 pins, nothing happens with the spring...i used a test light so i know circuit is completing, i think it's just simply dead. ordered a new one from pass should be here in the next two weeks.
Modified by beyjer at 10:02 AM 12/29/2010
titus86
336 posts [100%]
spartanburg sc
Cool sounds awsome! Let me know how it goes when it comes in. Kinda lazy to check but how much do they go for at pass racing?
beyjer
526 posts [99%]
he hasn't given me a price yet, probably somewhere around $100 i'm guessing? i remember cabe selling them a while back for $98
beyjer
526 posts [99%]
finally able to get another vvt solenoid and it made a world of difference, no hesitation/bogging, smooth power band all the way to redline w/vvt working as well.
titus86
336 posts [100%]
spartanburg sc
awsome!!! imma have to get me a new one too i guess. sucks cause i gotta drive my car with no high in power for right now.
chronic
28 posts [100%]
Quezon City Metro Manila
 Re: (jspexae102) » Reply  Edit
@jspexae102 i noticed your picture for the heater lines says don't loop but your image has the heater lines looped. should it be looped or not? if not, what's the reason for not looping? TIA!
JAVResistance
48 posts [100%]
 Re: (chronic) » Reply  Edit
Does somebody has done a turbo setup with this engine? I need a guide on routing the vacuum lines for a turbo setup and with a Microtech ECU. If someone has done it, can you please share it with me? Thanks in advance for your help.
