 HELP: Need a picture of under the ITBs, VACUUMFirst  < 2 3 4   Last
lonewolf452
38 posts [100%]
Winnipeg Manitoba
Can someone tell me what this is? if i plug it off with my finger the engine wants to stall...
http://imageshack.us/photo/my-...1.jpg/
rc.square24
326 posts [100%]
Vancouver BC
 Re: (lonewolf452) » Reply  Edit
Check your link
JAVResistance
48 posts [100%]
Yeah your link aint working....
choyr
12 posts [100%]
Batangas Batangas
guys, can you just block all the vacuum lines and keep only the brake booster, ISCV, map sensor and FPR, if you don't have an A/C..
and what does the throttle opener exactly do? what will happen if you plug it.
rc.square24
326 posts [100%]
Vancouver BC
 Re: (choyr) » Reply  Edit
Yes you can block a/c if you don't need it.
Throttle opener I believe is a dashpot that just cushions the plate when they close so its not so abrupt of a deceleration. Should run if you remove it, if you have to?
 First  < 2 3 4   Last
