MAIN PAGE
REFERENCE
PHOTOS
LINKS
FUN TALK
TECH TALK
CLASSIFIED
INTERNATIONAL
 DIY: MAXGRIP LSD kit install instructions
WeirPerformance
730 posts [100%]
American Canyon CA
 DIY: MAXGRIP LSD kit install instructions Reply  Edit
Finally! we have some numbers for you guys, before and after rebuilding the o.e.m. LSD with the MAXGRIP LSD kit. The LSD pictured in the instructions below is the actual LSD used in the following test resuls. We started with a zenki o.e.m. unit that was in good working order. The intital torque readings were taken before disassembly. We made special tooling, which allows one side gear to be held stationary, while the opposing side gear is rotated using a dial type torque wrench. The reading obtained is the actual torque value it takes to make the clutch plates slip within the LSD. Keep in mind, this is a static load test, there is no force being applied by the clutch members, also called pressure rings. Under dynamic loads (actual use in the car) the clutch members are forced apart, applying additional clamping force to the clutches. We are very excited about the final results and did not expect to get this high of an increase in torque.
Torque reading before rebuild @ 8 ft.lbs.
Torque reading after rebuild, with the MAXGRIP kit installed, just over 15 ft.lbs. That is an increase of 46% more torque!
Modified by DCPerformance at 8:52 PM 10/23/2008
Spence Weir
Weir Performance Engineering LLC
707-315-6638
spence_weir@sbcglobal.net
WeirPerformance
730 posts [100%]
American Canyon CA
2daToP
Spence Weir
707-315-6638
healtoeae86
2002 posts [100%]
 Re: (DCPerformance) » Reply  Edit
do you have these for supra 7.5 in rear ends?
please email me. I hardly check the forums
healtoeae86@gmail.com
WeirPerformance
730 posts [100%]
American Canyon CA
 Re: (healtoeae86) » Reply  Edit
Quote, originally posted by healtoeae86 »
YGM and we are developing a kit for this now and it should be ready before x-mas.
Spence Weir
707-315-6638
tchybrid
821 posts [91%]
323
awesome write up once again, i will definately be looking into purchasing a kit for my spare LSD and 3rd member. thanks for the great information!
Kenny
Drift Social Staff
WeirPerformance
730 posts [100%]
American Canyon CA
 Re: (tchybrid) » Reply  Edit
**2DaToP**
Spence Weir
707-315-6638
gtSr5
988 posts [89%]
Spartanburg SC
awesome write up spence... im anxiously waiting on a 7.5 setup for my cressida project...
now if u could just do a write up on how to setup a ring and pinion...haha.. i wouldnt have to take it to every shop on the east coast and to get someone competent enough to set it up out here..:D
WeirPerformance
730 posts [100%]
American Canyon CA
 Re: (gtSr5) » Reply  Edit
Quote, originally posted by gtSr5 »
The 7.5" MAXGRIP kit is coming very soon! I won't be doing a differential write up though. There is a ton of information on how to do it already out there Thanks!
Spence Weir
707-315-6638
WeirPerformance
730 posts [100%]
American Canyon CA
BumPeD
Spence Weir
707-315-6638
BKH808
552 posts [97%]
Honolulu HI
Does anyone know what the carrier bolts are suppose to be torqued at?
insane
214 posts [100%]
Farmington NM
 Re: (BKH808) » Reply  Edit
Do you mean the bolts that hold the top cover to the main case? If so 33 ft-lbs.
Glass stays crunchy in milk!
WeirPerformance
730 posts [100%]
American Canyon CA
 Re: (insane) » Reply  Edit
topper
Spence Weir
707-315-6638
BoRoYaSui
1544 posts [100%]
long beach ca
 Re: (WeirPerformance) » Reply  Edit
how does the initial torque of the stock lsd and maxgrip compare to an aftermarket lsd?
WeirPerformance
730 posts [100%]
American Canyon CA
 Re: (BoRoYaSui) » Reply  Edit
Quote, originally posted by BoRoYaSui »
Well, you honestly really cannot compare them. The O.E.M. LSD uses coil compression springs that push the clutch members apart, similar to a Cusco. Even with the oversize springs we use on our MAXGRIP kit, it still doesn't equal the amout of spring load in the aftermarket LSD units. Kaaz and Tomei LSD units use 2 spring washers which create upwards of 1k lbs. of force. The upside to this in the Kaaz and Tomei is a high initial torque. The downside to this with the Kaaz and Tomei is the clutch members have to compress the spring washers under load so in essence the LSD is fighting itself, springs push in the oppositte direction that the clutch members push.
The plus with the O.E.M. and Cusco is the springs push in the same direction as the clutch members. This puts all the forces working in the same direction to clamp the clutch plates.
The O.E.M. LSD with our MAXGRIP kit, on the bench, has an initial torque of 15 lbs. break away torque. The Kaaz and Tomei are around 55-75 lbs. of break away torque on the bench. I have checked one O.S. giken LSD and it was near 120 lbs. break away torque. TRD 55-65 lbs. break away torque.
One thing I did with the O.E.M. LSD was to wedge the upper clutch member with a screw driver while reading the torque. This simulates a load as the LSD would see while installed in the diff and the wheels on the ground. It easily reached 75 lbs. without prying very hard on the clutch member. In short there is no way to make the O.E.M. LSD have as much capacity as aftermarket from the simple fact that aftermarket LSD units have more clutches that are larger in diameter which equals more friction surface area.
Spence Weir
707-315-6638
WeirPerformance
730 posts [100%]
American Canyon CA
2DaTop
Spence Weir
707-315-6638
JDK
1 posts [100%]
Mississauga Ontario
Anything available for a 93-95 RX7? i also sent you a e-mail
WeirPerformance
730 posts [100%]
American Canyon CA
 Re: (JDK) » Reply  Edit
Quote, originally posted by JDK »
I believe the 93-95 rx7 used a torsen style LSD, we do not have a kit for that.
Spence Weir
707-315-6638
ichibandan
1884 posts [100%]
Right, OEM FD diff is Torsen type. S4 TII diff is clutch-type and will bolt into an FD. In fact, this is a common upgrade for folks making higher power (450hp and up I believe) and are breaking the Torsen units.
» Return to General Technical Discussions
ZeroForum ©2008 RelyNet, Inc.
