 Toyota Part Numbers for 20v'sFirst  1 2 3 >  Last
HASportAE86
IE Gutter Trash
4096 posts [84%]
Loma Linda CA
 Toyota Part Numbers for 20v's Reply  Edit
Link to 20v part numbers---->
http://www.filmantravel.com/20vparts_files/<br /><br />
Modified by HASportAE86 at 8:14 PM 6/13/2012
Silvertop TPS sensor: 89452-12080 or 89452-22080 same p/n as 2JZGTE, 3RZFE, 2RZFE, 5VZFE Blacktop TPS sensor: 89452-12090
Silvertop IACV (idle control valve): 22270-16030 Blacktop IACV: 22270-16070
Blacktop Electric Fan Water Temp Sensor (the white one):89428-12160 Silvertop Electric Fan Water Temp Sensor : *unknown*
Blacktop Oil Pressure Sensor: 83520-35030 Silvertop Oil Pressure Sensor: 83520-35030
Blacktop Knock Sensor: 89615-22050 Silvertop Knock Sensor: *unknown*
Blacktop O2 Sensor: 89465-19685 Silvertop O2 Sensor: 89465-19495 or 89465-12290
Blacktop Water Temp Sensor for Gauge Cluster :83420-20040 Silvertop Water Temp Sensor : *unknown*
Blacktop MAP sensor: 89420-12070 Silvertop Air Flow Meter: 22250-16110
Blacktop Igniter: 89621-12050? Silvertop Igniter: 89621-12050? same as SW20 MR2?
Blacktop Ignition Coil: 90919-02197 Silvertop Ignition Coil: 90919-02197 same as 3SFE, 2JZGE?
Blacktop VVT Solenoid: 15330-16020 Silvertop VVT Solenoid: 15330-16010 or 15330-16020
*****MAINTANENCE******* Blacktop "Gasket Overhaul kit": 04111-16210 Silvertop "Gasket Overhaul kit:: 04111-16330
Blacktop Timing Belt: 13568-19185 Silvertop Timing Belt: 13568-19035
Blacktop Alternator Belt: 99365-80840 Silvertop Alternator Belt: *unknown*
Blacktop Timing Belt Pulley: 13505-16030 Tensioner for Pulley: 13540-16010 Silvertop Timing Belt Pulley: 13505-16021 or 13505-16030 Tensioner for Pulley: 13540-16010
Blacktop Thermostat: 90916-03075 Silvertop Thermostat: 90916-03060
Blacktop Distributor Cap: 19101-16010 Rotor: 19102-74040 Silvertop Distributor Cap: 19101-16010?
Plugwire Set: 90919-21520
Oil Filler Cap: 12180-46010 same as 2JZ
Valve Clearance Adjusting Shim: 13751-16020
PCV valve: 12204-11050
Spark Plug Hole Gasket: 11193-16010
*****ENGINE MECHANICAL******
Blacktop Distributor Assembly: 19100-16270? Silvertop Distributor Assembly: 19100-16270?
Blacktop Oil Pump: 15100-19045 Silvertop Oil Pump: 15100-19036
Blacktop Water Pump: 16100-19285? Silvertop Water Pump: 16100-19245?
Blacktop Valve Cover: 11201-16030 Silvertop Valve Cover: 11201-16020 or 11201-16030
Blacktop Oil Pan: 12101-16100 Silvertop Oil Pan: 12101-16100 same as 5AFE and 4AFE?
Blacktop Oil Pump Pickup Tube: 15104-15090 same as 5AFE? Silvertop Oil Pump Pickup Tube: 15104-15090
Modified by HASportAE86 at 8:40 PM 6/13/2012
Email/Paypal "heyvanilladan@hotmail.com"
SwangBiz Chassis Products
http://forums.club4ag.com/zero...age=1
MFactory Longer T50 5th Gear Group Buy
http://forums.club4ag.com/zerothread?id=113077
Loud Pipes Save Lives -Swangbiz
Honda Master Technician/ASE Master Technician
jspexae102
1141 posts [91%]
Union City CA
hmm.. oilpan cross referenced with 4AFE
Memoryfab.com
M-F 10A - 6P PST
Sat by appt. only
510.489.5866
HASportAE86
IE Gutter Trash
4096 posts [84%]
Loma Linda CA
 Re: (jspexae102) » Reply  Edit
cool beans been corrected
benny_toe
224 posts [99%]
Seattle WA
 Re: Toyota Part Numbers for 20v's (HASportAE86) » Reply  Edit
Dr. Hess posted this on the Locost list regarding ISC valve:
Toyota part numbers:
Buld Date Part Number
9106-9505 22270-16030
9605- 22270-16070
The first one is the silvertop. They appear to be 20v specific. You
could try some of the Toyota dealers and see if they can order you
one. I hear some dealers can get JDM stuff if you have the part number
Larry
mbnlwj3@gmail.com
karate_crimson
8227 posts [89%]
Southern CA
for those looking for a throttle position sensor the part number is the same for the 2JZGTE, 3RZFE, 2RZFE, 5VZFE. IM currently using one from a 1995 tacoma with the 2rz engine.
And as far as spark plug wires go, you can use the 1994 4runner 4 cylinder model plugs. Even the coil wire fits right up. i lost the picture somewhere of someone who used them just fine.
kitsune
There is no charge for AWESOME
3808 posts [100%]
Seattle WA
Can you even use those part numbers and order them through the dealership?
Mike
choncifier1
137 posts [100%]
Calgary Alberta
 Re: (kitsune) » Reply  Edit
I am doing a complete rebuild of a Blacktop and the only part I could get from Toyota is the Transmission seal and gasket kit. They told me they weren't allowed to sell any of the other parts. I am buying all the parts from Pass Racing as soon as I know what bearings to order.
kitsune
3808 posts [100%]
Seattle WA
I wonder if Toyota Canada policy on ordering parts differ from Toyota USA.
Mike
HASportAE86
IE Gutter Trash
4096 posts [84%]
Loma Linda CA
Quote, originally posted by kitsune »
Mike
I've looked up JDM part numbers at our Toyota dealer and what it will display is that the part is at the warehouse and that's about as far as it will go. I'm not quiet sure what dealers like Cabe Toyota and Northridge Toyota are doing to get these? They are on a V.I.P list of people who can get them from the US warehouse in Torrance? or they order from Japan and have them shipped over like everyone else?
muythaibxr
1035 posts [100%]
This thread would be a good sticky.
Ken
choi0706
217 posts [100%]
TEXAS TX
thanks.. anyone know if the BT20v VVT solenoid is interchangeable with US cars?
also what about the tensioner?
abbeylives
295 posts [100%]
Clearwater FL
anyone know about the fuel injector plugs? I figure their the same as some other recent toyota, but was hoping for input.... one of connections was bad and I messed up de-pinning the connector
jspexae102
1141 posts [91%]
Union City CA
 Re: (abbeylives) » Reply  Edit
Quote, originally posted by abbeylives »
You can get them either from a electronics store - cheaper option [Sumitomo p/n 6189-0573]
or from Toyota [p/n 90980-11285]
Memoryfab.com
M-F 10A - 6P PST
Sat by appt. only
510.489.5866
abbeylives
295 posts [100%]
Clearwater FL
thanks, now i have to find an electronics store in the area that sells/stocks that product - sadly the sumitomo website didn't list retailers.... any ideas on stores?
If not I'll try calling the company monday
jspexae102
1141 posts [91%]
Union City CA
Now that you mentioned it none of my usual digs (mouser electronics & digikey) carry sumitomo either.. best to call them directly.
FYI that connector has a MSRP of $5 on the Toyota EPC..
Memoryfab.com
M-F 10A - 6P PST
Sat by appt. only
510.489.5866
abbeylives
295 posts [100%]
Clearwater FL
yep just spoke to local toyota parts department, $5... I asked them about getting the pins and the guy was clueless any idea what I should specify for two of the pins in the connector with some wire.....
jspexae102
1141 posts [91%]
Union City CA
you can get them here..
http://www.bmotorsports.com/sh...9_110
they also have "nippin denso injector connector kits" one of them should work, not sure which one tho.
Memoryfab.com
M-F 10A - 6P PST
Sat by appt. only
510.489.5866
abbeylives
295 posts [100%]
Clearwater FL
awesome site- thanks - how'd you find that place?
jspexae102
1141 posts [91%]
Union City CA
I think Doug aka mr2oc mentioned it a while back and I bookmarked it for future reference. came in handy
Memoryfab.com
M-F 10A - 6P PST
Sat by appt. only
510.489.5866
thruthefence
45 posts [100%]
Bossier City La
anyone know the p/n of the VSS (speed sensor) that will work with the 20V ST?
jspexae102
1141 posts [91%]
Union City CA
speed sensors are found on the tranny. Are you using the C52/C56 FWD transaxle that came with your engine?
Memoryfab.com
M-F 10A - 6P PST
Sat by appt. only
510.489.5866
thruthefence
45 posts [100%]
Bossier City La
No, this is a swap, the engine is mated to a 1970 Lotus Europa. I'm trying to accomplish 2 things: talk to the 20V M/T ECU, and drive an electric aftermarket speedometer.
thanks
espguitarist33
55 posts [100%]
west chester pa
 Re: (thruthefence) » Reply  Edit
I have an electric speedometer gear from a silvertop transmission i put in my mr2 (analogue gear setup) i could sell u
mrfuzzy
1513 posts [100%]
Did you turn it off and back on
Are the gaskets the same BT to ST like the oil pump and rear main gaskets?
Learn It To Earn It! Garage.SoCal86.com
~>SoCal86.com<~
->KSDEngineering.com<-
ICEanLU
250 posts [92%]
 Re: (mrfuzzy) » Reply  Edit
do you have BT 20v flexpipe/downpipe?
serious buyer ill take off hand tonite
email me iceanusn7777@yahoo.com
Toyboy805
1762 posts [99%]
Oxnard ca
 Re: (ICEanLU) » Reply  Edit
non us parts arent in the toyota system
1993.5 supra turbo 6 speed
1991 nissan nx 2000 sr20det
1990 toyota ae92 corolla levin 4age high comp
1989 nissan rhd sil80ty sr20det
1986 ae86 gts high comp 4age
1984 ae86 coupe sr5 4ac soon 4agze
Hachiblue
392 posts [100%]
Seattle WA
 Re: (Toyboy805) » Reply  Edit
http://www.toyodiy.com
Great Toyota parts catalog site for North America, Europe, Japan and more. Really handy when looking for OEM parts on my blacktop and 1JZ
HASportAE86
IE Gutter Trash
4096 posts [84%]
Loma Linda CA
 Re: (Hachiblue) » Reply  Edit
Quote, originally posted by Hachiblue »
ewwwwww.....yeah.....about that
Honoturtle
541 posts [100%]
Honolulu HI
 Re: (HASportAE86) » Reply  Edit
Quote, originally posted by HASportAE86 »
Such a shame.
Thanks for posting some great numbers, looking for an 02 sensor.
Coupe Sprinter. Precision. Style. Strength. Toyota.
Hachiblue
392 posts [100%]
Seattle WA
Yeah, no more diagrams But still one of the best online parts reference sites. Organized almost exactly the same as our parts catalog we use at Toyota.
 First  1 2 3 >  Last
