 Toyota Part Numbers for 20v'sFirst  < 2 3   Last
morgan
6446 posts [93%]
 Re: (Sk149) » Reply  Edit
they are the same, contact yversion on here. he works for K1 motor sports aka the old Pass Racing.
my 20v in an 86 swap guide
my mess of an 86...
*east coast toyotas forum*
Sk149
5 posts [100%]
Miami Florida
 Re: (morgan) » Reply  Edit
Thanks man ... And how do I contact him? hate to ask a noob question but I dont know to pm on this forum lol
99 black autotragic Corolla Le - Sold
98 white manual Corolla Le - Sold
93 green manual Corolla 20v swapped - Current
morgan
6446 posts [93%]
see the icon below my screen name, and yours? it says "IM" inside the bubble? press on that under his name in a post of his, OR search under member list, click on his screen name and his profile pops up. theres a "send an instant message to..." on the right of his info.
my mess of an 86...
Billy_Andrea
1321 posts [100%]
San Francisco CA
Anyone have a part # for valve spring keepers ?
Rasteirinho
24 posts [100%]
 Re: (Billy_Andrea) » Reply  Edit
Hi,
According to toyodiy.com the locks P/N is 90913-03026
gotzoom
961 posts [99%]
Silicon Valley CA
 Re: (Rasteirinho) » Reply  Edit
Billy, if you need one or two, I have a few extra. PM me if you want to hook up
Bay Area Autocross Forum
85 Corolla GTS Mild mannered road car
86 Corolla GTS Time Attack build in progress
99 Sport Miata CS #94
02 Miata daily driver chick car
Billy_Andrea
1321 posts [100%]
San Francisco CA
Thanks very much for the #. I checked the DIY site & couldn't find it.
Billy_Andrea
1321 posts [100%]
San Francisco CA
 Re: (gotzoom) » Reply  Edit
PM sent. Thanks !
Candunguito
124 posts [100%]
Chicago IL
I need this parts for my FWD 20v BT AE111
1.Clutch Release Bearing
2.Pilot Bearing
3.Drive shaft Tranny Seals
wrenchdad
339 posts [100%]
Natchez MS
 Re: (Candunguito) » Reply  Edit
Pilot bearing? FWD do not use a pilot bearing.
What transmission are you using? Seals are different for certain models of transmissions, such as the SuperCharged version that has the larger axles.
I have also seen two different sized release bearings due to the input shaft of the tranny being different sizes.
Is this the orginal engine/tranny combo? There is a site where you can get Toyota part numbers for the 20V Japan cars......www.toyodiy.com
Going with a 1996 BT with a 5 speed, I came up with this # 31230-12170 for the release bearing and for the seals, I "think" these are the correct numbers for the non-SC version axles.
90311-34028 Seal, oil, transmission case (LH axle seal)
90311-34016 Seal, oil, # 2, transaxle case (RH axle seal)
hope this helps, later wd
" Second place is just the first loser" the late Dale Earnhardt
dre' from barbados
2 posts [100%]
queens new york
 Re: Toyota Part Numbers for 20v's (HASportAE86) » Reply  Edit
hi i'm new to this page just checking to see if i can get the error codes for the toyota corolla Ae100--101-114;
smokin-kp61
37 posts [100%]
jackson nj
 Re: Toyota Part Numbers for 20v's » Reply  Edit
ok so i got cam seals for the 4age 20v st i used 16v exhaust seal(timkin #1987-s) and i found one that was a hair bigger for the intake cam seal and it worked doesnt leak (timkin #2012v)
 First  < 2 3   Last
