 Distributor block off plate?
turbo4ag
258 posts [99%]
Henderson NV
 Distributor block off plate? Reply  Edit
does anybody know where i can find one for the 16v?
SYM
3697 posts [100%]
 Re: Distributor block off plate? (turbo4ag) » Reply  Edit
custom make it from your local machine shop
Simon @ P.A.S.S Racing
http://www.passracing.com
148 S.8th Ave, Unit-F
City of Industry
626-961-7711
SYM@passracing.com
ae924afdx
2319 posts [98%]
Somewhere NC
... Easy.. UNIVERSAL RUBBER FREEZE PLUG.. from autozone. I have seen it before on a 3sgte without any problems..
Email: jose_centeno_perez(AT symbol)hotmail.com
turbo4ag
258 posts [99%]
Henderson NV
haha thats funny... i just got one yesterday
dorimaster
942 posts [100%]
Charlotte NC
 Re: (turbo4ag) » Reply  Edit
There is a toyota i think a paseo or camry that has a plug where its distributor used to be, which fits perfectly as the engine has switched to DLI. OR you can get the FA plug from hasslegren for about $15, which is a nice billet piece with new o-ring!
What management are you running with no distributor? thanks!
Pete
turbo4ag
258 posts [99%]
Henderson NV
megasquirt with edis4
rix86
3680 posts [98%]
Tacoma Wa
about a 1999 or 2000 camry 5sfe has a plug where the distributor went on older models.
PERFECT fit.
ej86
5502 posts [100%]
Las Vegas NV
Heat Shield? I got 2 one from a 85-87 supercharged 4age and a regular 4age.
dirtdilla
690 posts [98%]
Miami FL
what size universal rubber freeze plug did you get?
because there are a couple sizes....
35mm 40mm 42mm... etc...
Turbo AE92
dirtdilla
690 posts [98%]
Miami FL
 Re: (dirtdilla) » Reply  Edit
Bump... any help?
I dont have a micrometer or telescoping gauge to measure the distributor hole bore.
Turbo AE92
hachi-go-luckee
938 posts [100%]
m c
38-40 for the rubber plug
dmottaway
1196 posts [100%]
if yoy have a decent parts guy, you buy one of each and return the ones you don't need.
dave
dirtdilla
690 posts [98%]
Miami FL
 Re: (hachi-go-luckee) » Reply  Edit
Quote, originally posted by hachi-go-luckee »
No. It was in fact the 34-38mm. The 38-41mm I first bought was far too big. Luckily the parts dealer did it as a 30-day warranty exchange as your not allowed to return those once they are opened.
So in final conclusion the 34-38mm Universal Expansion (Freeze) Plug is the one you will need to get. It costed me $2.89 + tax.
Turbo AE92
hachi-go-luckee
938 posts [100%]
m c
hmm..... it was was a tight fit, but i muscled it in there. i didn't want to use the 34-38 as the size of the dizzy diameter is almost a 38 so i didn't want to take any chances of having it leak on me.....
dirtdilla
690 posts [98%]
Miami FL
Well the 34-38mm is as snug as you will ever need it. Took the car out for a quick spin to make sure and it does not leak one bit.
I dont have the washer perfectly flush with the distributor bore, so it leaves 1mm or less to actually see the rubber part expand, and it clearly overlaps the lip on that bore showing it can go much further if needed. So I'd guess its about 37mm or 37.5mm.
Turbo AE92
neil85ae86
526 posts [98%]
I just used a small piece of 1/4 mild steel plate, then measured and drilled, it's worked perfectly... but I'd definitely go with the freeze plug if I'd known about it back then
Neil
Uber D.I.Y. Zenki Turbo
Squirted since spring '03
» Return to Engine - 4A-GE 16V
