 stainless steal braided lines part numbers(fuel line)First  1 2 >  Last
jdmflavor510
1099 posts [99%]
Newark ca
 stainless steal braided lines part numbers(fuel line) Reply  Edit
To often do i see posts asking for what parts are need for making a stainless steal braided lines from the fuel filter to the fuel rail,well here it goes:
Earls part number
991945ERL qty2
Aeroquip part numbers
FCM4032 qty2
With these part numbers you will also 2.5 feet of Stainless steal braided lines
stainless steal braided line qty 2.5 in -6. I bougt 3 feet which was way to long i think 2.5 should be enough.
here are pics aswell
Modified by jdmflavor510 at 7:17 AM 12/3/2008
http://www.jdmflavor.com
CHECK OUT MY FOR SALE THREADS:
ARC Induction Box
http://forums.club4ag.com/zerothread?id=35699
gtapex
26 posts [100%]
meath meath
 Re: stainless steal braided lines part numbers(fuel line) (jdmflavor510) » Reply  Edit
nice one.
any links to where i could buy the bits?
HASportAE86
IE Gutter Trash
4096 posts [84%]
Loma Linda CA
you mean from the Fuel filter to the fuel rail?
Mods please sticky! We need more helpful info stickied.
Email/Paypal "heyvanilladan@hotmail.com"
SwangBiz Chassis Products
http://forums.club4ag.com/zero...age=1
MFactory Longer T50 5th Gear Group Buy
http://forums.club4ag.com/zerothread?id=113077
Loud Pipes Save Lives -Swangbiz
Honda Master Technician/ASE Master Technician
Plex
3761 posts [89%]
Suisun City CA
 Re: stainless steal braided lines part numbers(fuel line) (gtapex) » Reply  Edit
Quote, originally posted by gtapex »
nice one.
http://www.anplumbing.com/shop...minum
Summa Cum Laude Graduate, AE86 University Class of '02
jspexae102
1141 posts [91%]
Union City CA
I did mines a different way.. i'll post it after I take some pics
Memoryfab.com
M-F 10A - 6P PST
Sat by appt. only
510.489.5866
ae924afdx
2319 posts [98%]
Somewhere NC
 Re: (jspexae102) » Reply  Edit
991945
809106
This are the Earls part number for both parts needed.
Email: jose_centeno_perez(AT symbol)hotmail.com
meme
1145 posts [97%]
here is a pic of mine. basicly the same. i ran mine from the gas tank.
aesthetics82
1118 posts [99%]
Oceanside CA
This hooks up the fuel filter to the fuel line near the firewall, correct?
piso86
254 posts [97%]
greensboro nc
 Re: (aesthetics82) » Reply  Edit
whats the thread pitch on the banjo bolt that goes to the fuel rail??
jspexae102
1141 posts [91%]
Union City CA
m12X1.25
Memoryfab.com
M-F 10A - 6P PST
Sat by appt. only
510.489.5866
KungRolla
353 posts [99%]
San Francisco CA
1. why did you guys choose the swivel fitting over the banjo fitting that OE uses?
2. do the lines need to be pressurized to a specific psi range? does different hose sizes change the psi? i'm running pretty much stock and the shop guy told me that i should use -4 instead of -6 AN hose.
3. what are the fittings you guys used for the inlet on the bottom of the fuel filter?
thanks.
meme
1145 posts [97%]
 Re: (KungRolla) » Reply  Edit
i used the swivel cause i had a few sitting around. plus you dont have to mess with crush washers.
different hose size might make your pump work harder to keep the system pressureized. i use -6 cause im going to be modifying the cams and other parts later on.
i think the bottom of the filter is 14x1.5 to -6AN . the fitting on top of the filter is 12x1.25 to-6an
jspexae102
1141 posts [91%]
Union City CA
some people find the little hole in the banjo bolt too restrictive, upgrading to a swivel AN fitting help keeps up with fuel needs in future modifications that have increase fuel needs.
AN 6 seems to be the industry standard fuel feed line size. Just make sure the fuel pressure is within specs and you'll be fine.
Memoryfab.com
M-F 10A - 6P PST
Sat by appt. only
510.489.5866
jdmflavor510
1099 posts [99%]
Newark ca
Quote, originally posted by KungRolla »
thanks.
i just told the guy at the parts counter what i needed to make and he gave me those parts lol....
ARC Induction Box
Dr Tweak
678 posts [100%]
The size of the line shouldn't effect your pressure, but it could effect the flow of fuel. I would definitely not go down to a -4, I normally run -6 on just about everything.
By the way, I keep all of this stuff in stock including the metric to AN adapters, if anyone needs some just let me know. For that matter, if you want to measure the length of the line that you need, I can make it here for you and ship it ready to install.
-Doc
-Dr Tweak, Toyota Engine Swap Wiring Expert Extraordinaire
Email us at sales@tweakdperformance.com or visit us at http://www.tweakdperformance.com/
KungRolla
353 posts [99%]
San Francisco CA
any tricks to putting the fittings and the line together? this is my first time doing it and i don't want any leaks. thanks.
Dr Tweak
678 posts [100%]
I like to have some general purpose grease on hand and I use that to lube up the line to help with the install.
When you put the stainless line into the fitting, make sure that it's been pushed in all of the way. Then, when screwing the second part of the fitting into the first part, make certain that it doesn't start pushing the stainless line out.
The fitting should be screwed down all the way, note that the fitting shown in the pic in the first post has not been fully installed (either it was being mocked up or it was not installed correctly). The lines should look like this:
http://www.phoenixtuning.com/f...&t=86
KungRolla
353 posts [99%]
San Francisco CA
 Re: (Dr Tweak) » Reply  Edit
i knew i was missing the aeroquip lube... does wd40 work?
Dr Tweak
678 posts [100%]
I would recommend general purpose grease. You can get it from any parts store cheap.
-Doc
jdmflavor510
1099 posts [99%]
Newark ca
Quote, originally posted by Dr Tweak »
your absoultly right i forgot to mention the grease....thx dr tweak.
ARC Induction Box
jspexae102
1141 posts [91%]
Union City CA
http://www.youtube.com/watch?v...edded
This is a great instructional vid for assembling AN hoses
Memoryfab.com
M-F 10A - 6P PST
Sat by appt. only
510.489.5866
KungRolla
353 posts [99%]
San Francisco CA
oh, great instructions! i already put together the lines before watching the video though. it would have put away my worries if i watch the video before hand. this is turning into something that should be stickied. thanks!
JU1CE
219 posts [99%]
any of you guys have any pics of the lines coming from the filter to the rail? also the size of the -6AN adapter @ the rail? or is a banjo bolt used?
thanks
fisqual
270 posts [89%]
Columbus OH
Thanks for the contribution -
---BUT since I'm a total smarta$$ I have to bring it to your attention that steal = theft. Steel is shiny metal.
JU1CE
219 posts [99%]
 Re: stainless steel braided lines part numbers(fuel line) » Reply  Edit
another noob question.. Ok so the line from the top of the fuel filter goes to the rail.. can I get the banjo bolt 12mm x1.25 part # 809691 to replace the damper? and how much will it affect the flow without the damper anyone tried with and without the damper?
thanks..
Plex
3761 posts [89%]
Suisun City CA
 Re: stainless steel braided lines part numbers(fuel line) (JU1CE) » Reply  Edit
What dampner? lol
jspexae102
1141 posts [91%]
Union City CA
no man, the damper are in your suspension!
Memoryfab.com
M-F 10A - 6P PST
Sat by appt. only
510.489.5866
JU1CE
219 posts [99%]
The damper is the regulator looking like thing that holds down the banjo fitting. well that's what they called it.. listed on the blow up pics.. with part number (23270) but anyways.. what did u guys use on the fuel rail side of the line when you converted it to SS braid? -6AN to a banjo fitting? and still use the "damper"?
thanks much....
Plex
3761 posts [89%]
Suisun City CA
Nope... ditch it...
rywats
494 posts [97%]
Kelowna BC
What about the other side of the fuel rail. Whats needed for that?
 First  1 2 >  Last
