 stainless steal braided lines part numbers(fuel line)First  < 1 2   Last
Plex
3761 posts [89%]
Suisun City CA
I'm just running the stock FPR and a rubber line to the factory hard line
Summa Cum Laude Graduate, AE86 University Class of '02
JU1CE
219 posts [99%]
 Re: What I ened up doing... » Reply  Edit
OK guys here's what I got for the fuel set up... and its FOR SURE FIT...
2X FCM2240 one for top of fuel Filter and the other at end of Rubber fuel line before the Hard line in the back by the tank.. 14MM X 1.5 flared to -6AN make sure its the flare end to a -6AN
1X 991945ERL for the bottom of filter adapter 12MM X 1.25
1X 807691ERL SS line -6AN to Banjo 12MM X 1.25 goes to the fuel Rail you can omit the damper (the thing that looks like a regulator)
3X FMC4032 Hose end to -6AN.. for the top and bottom of filter, and also the adapter for the rear line from the tank..
and last but not least the line.. -6AN SS braided line I got 20FT..
hope this helps anyone with or without the same problem I had..
Thanks...
rywats
494 posts [97%]
Kelowna BC
Which fuel filter do I want? It says one is 35 microns and one 80 microns?
Modified by rywats at 8:41 PM 3/31/2009
calicoupe
2499 posts [86%]
zanta ana ca
 Re: (ae924afdx) » Reply  Edit
Quote, originally posted by ae924afdx »
991945
809106
This are the Earls part number for both parts needed.
991945
809106
many thanks for the Earl part numbers above (works perfectly for the top of the fuel filter like you said)....but what about line going to fuel rail....we are using banjo type ones right....
thank you
__________________________________________________________
SCAMMER ALERT - "Garageed" - Eddie Penchat PHUCKFACE & his brother blowjob "Curveslider" - Joe LESBO PhuckFACE
3tcgarage.com- "TE27LIFE" - PHUCKFACE Eddie Penchat and his FAGGOT brother "curveslider"
never forget. never.
balmo
4927 posts [100%]
Brentwood CA
 Re: (calicoupe) » Reply  Edit
from the fuel filter to fuel rail, i only used these parts.
-Earl's banjo hose ends 807691ERL: x2
-~3ft -6AN ss hose
that's it.
elmerkit
351 posts [100%]
carson la
That is really a good item it will avoid leaking fuel plus the safety feature.
"On sale Itp tires and ATV tires"
morgan
6446 posts [93%]
 Re: (balmo) » Reply  Edit
thank you balmo, just bough those.
my 20v in an 86 swap guide
my mess of an 86...
*east coast toyotas forum*
AE86silverred
28 posts [99%]
pearland tx
hey i doing my silvertop swap and i dont have nothing to bolt up to on my fuel rail so two of those will solve that problem right? thanks
AE86silverred
28 posts [99%]
pearland tx
The reason i say i don't have nothing to bolt up to is because there screw or whatever you want to call it on the fuel rail .. I hope that makes sense.. That's why i ask if with two it would work fine ..
focusdriverlx20
23 posts [100%]
Sisters or
 Re: (Dr Tweak) » Reply  Edit
just wondering, how much would it be for a complete fuel line? shipped to oregon?
some overworked honda chewer
new: project pinky http://forums.club4ag.com/zerothread?id=75057
bigkahk
183 posts [100%]
Long Beach CA
has anyone tried this out??
http://www.techafx.com/content...ength
zlidewayz
2193 posts [99%]
CenCal CA
 Re: stainless steal braided lines part numbers(fuel line) (jdmflavor510) » Reply  Edit
big ups
"Living the ae86 life" ...what other way to enjoi driving then to drive zidewayz
Thumbs up to Eric at RhysMillenRacing
Also in need of super clean Driver and Passenger Fenders email me
BEST FORM OF CONTACT= zmanae86@yahoo.com
rc.square24
326 posts [100%]
Vancouver BC
If I assemble a hose into an end say a straight AN6 swivel but decide to switch the fitting to a 90 swivel can I just unscrew it and change the fitting or do I have to remove the hose and chop off the old section and refit it all over?
morgan
6446 posts [93%]
 Re: (rc.square24) » Reply  Edit
the fittings "dig" into the rubber part of the hose when tightened, to seal it properly. you would probably want to cut off about 1/2" to be sure it seals proberly when changing the fitting, so you dont end up with a gas leak. the part that seals, is a circle, that cuts into the middle of the hose, thickness wise(not a good explanation, but when you get the parts, and check it out, youll see and understand.)
my mess of an 86...
Alexwaltman850
384 posts [99%]
Brookings South Dakota
 Re: » Reply  Edit
great thread!
Add me on Facebook (Alex Waltman), follow me on twitter (TheCreepyJesus), and take care to spike your hair! Woo Woo Woo, you know it!
2001 Pontiac Grand Prix: Crappy daily driver
1985 Corolla GTSR5: Swap in progress
2007 K2 Attack 2.0: My bike i ride everywhere., "Can't Stop! Let's go!"
Parts for sale: http://forums.club4ag.com/zeropost?id=23&cmd=fshow
man0lantern
188 posts [96%]
Scarborough Ontario
so what's the thread pitch for the bottom/top of the fuel filter??? 12x1.25 or 12x1.5? i'm getting mixed answers lol sorry
If I just replied to your thread, email me instead! j.peralta89@hotmail.com
Thanks =)
morgan
6446 posts [93%]
 Re: (man0lantern) » Reply  Edit
check the very first post, M12x1.25
my mess of an 86...
man0lantern
188 posts [96%]
Scarborough Ontario
 Re: stainless steal braided lines part numbers(fuel line) (meme) » Reply  Edit
sorry to bring up old thread, but what kind of F.I hose did you use? 5/16?
Thanks =)
morgan
6446 posts [93%]
Quote, originally posted by JU1CE »
Quote, originally posted by balmo »
-~3ft -6AN ss hose
my mess of an 86...
alexrotor
1 posts [100%]
Sanford NC
 Re: What I ened up doing... (JU1CE) » Reply  Edit
I am glad i ran in to this information I have to replace the fuel line. Thanks a million.
mase86
399 posts [100%]
Fayetteville NC
 Re: What I ened up doing... (alexrotor) » Reply  Edit
anyone use the teflon fuel hose. If so which one have you used. I'm looking at the ones buy aerquip and also the ones on the Pegasus there 811 PTFE.
http://www.racerpartswholesale...nHose
https://www.pegasusautoracing....NFLEX
Was also looking at this site as well. Any pros and cons?
http://www.side2sideracing.com..._id=2
Modified by mase86 at 9:48 AM 12/29/2012
 First  < 1 2   Last
