 RoCo's v8 ae86First  1 2 3 >  Last
RoCo_v86
45 posts [98%]
newbridge kildare
 RoCo's v8 ae86 Reply  Edit
well guys starting the thread on the new build, Europe's First V8 ae86. now some people will like the idea some will hate it, but ive always had a thing for the v8 engine and the ae86, so why not combine the two? this is my build over the last few weeks, getting ready for Prodrift/D-rift, and time attack, + hopefully a few rounds abroad!
basicaly starting off with a trueno ae86,
1uzfe 8cyl, 32v Quadcam, have to keep her toyota!
4 stud s13 rear axle, to keep same wheel fitment
supra w58 gearbox.
this is what i started off with.
started to trip her down back in january 08, to see what i have to work with?
then cut up the back end, choped the floor and the chasis mount for the panhard rod!
"Racing is life. Everything else that happens before or after is just waiting." ~Steve McQueen [Le Mans -1970]
RoCo_v86
45 posts [98%]
newbridge kildare
 more » Reply  Edit
the s13 rear axle.
recond the axle, and new pollybush kit, new custom solid diff welded machined and balanced and new rear brake setup!
new custom belhousing for w58 to fit the 1uz.
RoCo_v86
45 posts [98%]
newbridge kildare
new custom flywheel. to fit 1uz, but to take a 3sgte clutch.
new stage 4 racing clutch:
new tension rods
RoCo_v86
45 posts [98%]
newbridge kildare
i havent worked on it since febuary 08, but i took it out there in september and got stuck in. so heres the update.
Right huge update, this is how I left it in febuary!
starting to mount the s13 rear axle, just lining it up.
RoCo_v86
45 posts [98%]
newbridge kildare
measured and set the front mounts and welded on the plates.
started to measure rear end mounts.
then fabricated rear u beam mount. And fixed to chasis
welded in gussets to chasis leg for extra strength.
Modified by RoCo_v86 at 4:54 PM 2/26/2009
RoCo_v86
45 posts [98%]
newbridge kildare
axle mounts nearly finished.
also gusseted the front mount plates to the sill and inner leg.
rear end mount finished and primed black
RoCo_v86
45 posts [98%]
newbridge kildare
new rose jointed rear arm set.
RoCo_v86
45 posts [98%]
newbridge kildare
bolted up s13 rear axle, fits sweet.
turned her right way up and started on the engine.
RoCo_v86
45 posts [98%]
newbridge kildare
the itb’s arrived
the engine, what I started with, a old v8 out of a soarer.
and what I made of it, built up on stock internals, new belts and gaskets,
ae101 itb’s, custom manifold adaptor, stainless exhaust manifolds, and I polished
the rocker covers, pretty standard but good for 300+bhp.
RoCo_v86
45 posts [98%]
newbridge kildare
itb’s, pure sex,,,,,,
throttle linkage
custom flywheel, with auto ring gear. Takes 3sgte clutch kit.
now to mount the engine, at first glance it doesn’t look like its gona fit
but when we measured her up, its pretty tidy. i didn’t cut the bulk head, we bet it back a few inches which was more than enuf, just cut the tunnel,
RoCo_v86
45 posts [98%]
newbridge kildare
The cut tunnel for the big supra box.
I then fabricated the cross member,
test fit with lotus box, have a better box coming from England
new ls400 front mounted baffled sump.
a few late nights but it’ll be worth it.
jdm_john
8 posts [100%]
anaheim ca
wow!!! very nice!
hachiroku87
80 posts [100%]
Palm Coast FL
wow thats going to be badass
seanperia
1944 posts [99%]
Annapolis MD
that ITB set up for the V8 is sexy. Are you planning to do any work on the engine itself?
High Comp + High Rev v8 is crazy
RoCo_v86
45 posts [98%]
newbridge kildare
thanks guys,
yeah ill be upgrading next year. i have a spare engine, so the plan will be to build up that, with cams, valves, springs, retainers. 5 face seats. ported and flow tested head, ported inlet. and increase rev limit to about 8500-9k. should be good for 500ish. for the moment ill make do.
RoCo_v86
45 posts [98%]
newbridge kildare
engine in, at last,
I used mounts similar to the mk2 escort, to make
things easyr and cheeper to replace, also stiffer,
now to fabricate the tunnel. I decided to make it out of one piece sheet metal,
just to keep it looking neat
Tacked in place
and finished
RoCo_v86
45 posts [98%]
newbridge kildare
seem welded the whole shell, underneath, inside, and in the engine bay, also patched up any rust, and gusseted the chasis in a few places for strength,
right, had big problems with the rear suspension, my original idea was to get ae86 coilovers so I wouldnt have to fabricate turrets in the rear, and I could change the end to suit the axle, so I bought a set, but when fittling them I relised they didnt fit???, it turns out they were for a turreted ae86.. Like ??? ???. Anyway, in the end if I was going to have to turret the rear end I was going to do it properly, so I orderd set of s13 rear coilovers, and got to work.
Big hole
RoCo_v86
45 posts [98%]
newbridge kildare
the finished product, my sexy new turrets,
coilovers bolted in, lookin sweet. Man the more I do on this the more I wana drive it,
zenkicoupe
3412 posts [77%]
dirty fontana so. cali.
nice, i saw this on aeu86. sick bro..i can't wait till you finish it.
http://zenkitrdcoupe.blogspot.com/
email grnrolla86 at yahoo dot com
AE86STALKER
223 posts [95%]
Indianapolis/Portales IN/NM
thanks for posting it up here man
RoCo_v86
45 posts [98%]
newbridge kildare
Since I have the s13 rear end, which gives me about 30mm extra track each side,
I have decided to put the s13 front end in aswell. Lca’s, hubs, brakes, coilovers, and using the ae86 top mounts, and ae86 tension rods. Makes for about 40mm extra track each side on the front end, and a very big upgrade in brakes. Also the s13 steering arm is about an inch shorter, but with a ae86 manual rack and the extra track, you get a whole lot of lock.
Striped down the front end ready for new set up.
here you can see the difference in length between the two lca’s, and the length of the steering arm.
massive difference between the brakes, huge vented rotors and much bigger callipers.
RoCo_v86
45 posts [98%]
newbridge kildare
mounting the s13 lca. And hub assembly.
New coilovers and new adj tension rods.
Steering lock first attempt.
few minor adjustments
And now I am very happy with the angle of lock.
Elvin
12134 posts [100%]
Elvin Wes Your California Importer
Wow
westtoyconnection@yahoo.com
dual carbs
1139 posts [85%]
South Eastern WA
hmm and tie rods?
RoCo_v86
45 posts [98%]
newbridge kildare
next is the cage, thanks to wayne from swrc.
for bending the tube with his new benders, top guy.
Main hoop, front legs
rear x brace
DASH BAR
RoCo_v86
45 posts [98%]
newbridge kildare
Triangulating the front end out to the turrets.
started on the door bars, and triangulated rear end
RoCo_v86
45 posts [98%]
newbridge kildare
x cross braced the door bars.
started on the passenger door bar.
RoCo_v86
45 posts [98%]
newbridge kildare
rear triangulation bars.
rear harness bar
RoCo_v86
45 posts [98%]
newbridge kildare
started to mount the steering rack and pedal box
off the dash bar, I decided to put the box over the
rack, and not on the floor. Less room but will
look a lot tidier.
RoCo_v86
45 posts [98%]
newbridge kildare
primed the full shell with anti rust/chip zinc primer
Welded in and ground the door bars flush, took ages to
Do right, but im happy with the outcome, looks sweet.
 First  1 2 3 >  Last
