 Useful 20v ReferencesFirst  1 2 >  Last
Barry
Moderator - 9,500RPM club
6232 posts [100%]
hellaNORCAL
 Useful 20v References Reply  Edit
20v coolant flow configurations:
http://www.toycrazy.net/tech/rwd20v.html
20v parts cross reference guide, sensor information, and how to clean the ISCV:
http://4age20v.blogsome.com/ca...umber/
Modified by jondee86 at 1:06 AM 9/4/2011
-barry
9500RPM Club...4AGE
wtb: AE86 16v intake box and arm.
LOTS of parts for sale, tools, AE101, AE86, jubride, RSR, TRD:
http://forums.club4ag.com/zerothread?id=86969
BrasilianPimpin
75 posts [100%]
Broward County, Florida,
 Re: Useful 20v Reference's (Barry) » Reply  Edit
A great site for finding and cross-referencing part numbers can be found here:
http://www.toyodiy.com
Sam_Q
579 posts [99%]
Australia vic
http://www.rollaclub.com/board...14024
my lousy article on using a 16v water pump in rwd form, I am currently rewriting the article
s-86.com
SkillaKali
1399 posts [98%]
San Diego CA
20 valve manual
http://www.locost7.info/mirror/4age_blacktop.php
I saved it on my computer for future projects.
Barry
6232 posts [100%]
hellaNORCAL
i have verifed, all 4AGE and 4AFE thermostats are compatible.
i am currently using a bluetop 4age 16v thermostat on my 20v engine.
-barry
9500RPM Club...4AGE
jspexae102
1141 posts [91%]
Union City CA
 Re: (Barry) » Reply  Edit
Quote, originally posted by Barry »
weird, my 16V thermostat was too small for my 20V housing. I had to use a SW20 thermostat.
Memoryfab.com
M-F 10A - 6P PST
Sat by appt. only
510.489.5866
20v102
278 posts [100%]
Winnipeg MB
I used a 4afe thermostat on my silvertop.
Thermostat 90916-03090 All 4A
Maybe you have some weird housing or you mixed up the two thermostats?
Modified by 20v102 at 8:02 AM 4/6/2009
Barry
6232 posts [100%]
hellaNORCAL
 Re: (jspexae102) » Reply  Edit
Quote, originally posted by jspexae102 »
make sure you are using the correct rubber o-ring gasket. that is probably whats giving you issues.
i'm not sure if they offer it aftermarket, go with OEM for the seal if it isn't the one that slips over the thermostat lip.
-barry
9500RPM Club...4AGE
Barry
6232 posts [100%]
hellaNORCAL
http://forums.club4ag.com/zerothread?id=49130
Quote, originally posted by Roadster_fan »
Hey Jason,
The Silvertop's belt has 111 teeth the Blacktop has 110 teeth (counted 2 times each to make sure). I also tried to put on the BT belt on the ST engine just out of curiosity doesn't work. I did the same for the ST belt on the BT and it works but looks like the hydraulic tensioner won't extend far enough to put tension on the belt. So to answer your question they will not work for each other.
-barry
9500RPM Club...4AGE
karate_crimson
8227 posts [89%]
Southern CA
i like this site. i found it and it talks about cutting and welding the 20v water kneck to make it like 16v:
http://www.my-acoustic.com/Car...r.htm
gudluvin7
32 posts [96%]
Makakilo Hawaii
the BT and ST housings are different...BT is bigger, forgot the part number but its a V6 camry thermostat
choncifier1
137 posts [100%]
Calgary Alberta
 Re: (gudluvin7) » Reply  Edit
Valve seals from 2004 echo can be used in blacktop.
90913-02092 ex. Valve seal
90913-02093 int. valve seal
Front & rear seal for blacktop same as 7AFE 94-99 Celica
90311-70007 rear
90311-32018 oil pump / front seal
Thrust washer & main bearings for blacktop same as 7AFE 94-99 Celica
11011-15020 Thrust Washer
11704-16010 Main bearings U/S .25
jspexae102
1141 posts [91%]
Union City CA
a larger o ring woldn't have been enough to make up for the size difference. I used a SW20 MR2 thermostat and it fits perfectly.
Memoryfab.com
M-F 10A - 6P PST
Sat by appt. only
510.489.5866
apex diff
239 posts [100%]
irish sea
has anyone got the toqure settings for main and big ends for a ae111 20v thanks
Plex
3761 posts [89%]
Suisun City CA
 Re: (apex diff) » Reply  Edit
Quote, originally posted by apex diff »
Its in the manual....
Summa Cum Laude Graduate, AE86 University Class of '02
jspexae102
1141 posts [91%]
Union City CA
20vBT Thermostat Left, 16V Thermostat Right
Memoryfab.com
M-F 10A - 6P PST
Sat by appt. only
510.489.5866
Barry
6232 posts [100%]
hellaNORCAL
wow, i guess everything on the blacktop is bigger or lighter.
-barry
9500RPM Club...4AGE
apex diff
239 posts [100%]
irish sea
 Re: (Plex) » Reply  Edit
tanks
AE86Bill
324 posts [95%]
NJ
Silvertop 20v uses 16v thermo
Blacktop 20v uses SW20 thermo
86 Corolla GTS - AE86
83 Corolla Sedan - AE71 (Sold)
fisqual
270 posts [89%]
Columbus OH
Actually when I bought my water relocation kit it came with a thermostat. The thermostat it came with was TOO BIG FOR THE RELOCATION KIT. It fit in the blacktop stock place, but NOT the kit itself! haha...
I put my SR-5 Thermostat in the water kit. (I had just replaced it like 3 months before I did the swap, couldn't handle the winter anymore, lol)
fisqual
270 posts [89%]
Columbus OH
 Re: (fisqual) » Reply  Edit
Oh and for the love of god, no apostrophe is necessary in References. This better not be a sticky until that's fixed.
<3
toyotaman15
91 posts [100%]
Aurora IL
Does anyone have a link to the silvertop manual???I am looking for some torque specs and such.
Thank you...and yea i used the search tab first
Barry
6232 posts [100%]
hellaNORCAL
you can use the same specs for everything as stated in the blacktop manual.
the silvertop manual was never published in english.
-barry
9500RPM Club...4AGE
Sam_Q
579 posts [99%]
Australia vic
I have a few articles people may find usefull on my website:
http://s-86.com
Modified by Sam_Q at 7:48 PM 11/3/2009
s-86.com
Grant
3656 posts [86%]
San Jose ca
Not super useful, but on this page I have the pin out for the chassis firewall C harness. My car is an 86 GT-S with A/C and PS.
http://www.vems.hu/wiki/index....iring
Stand Alone ECU tuning. Message me for details.
Looking to buy a corolla manual rack and a TRD 3 gear transmission.
*also wtb 4 point roll cage/bar for ae86 coupe
morgan
6446 posts [93%]
heres a link to a large pic of the silvertop wiring diagram. it helped me tremendoulsy during my swap.
http://media.photobucket.com/i...m.jpg
pics of all the pigtails
http://padandwheels.com/mr2/bl....html
my 20v in an 86 swap guide
my mess of an 86...
*east coast toyotas forum*
morgan
6446 posts [93%]
alternate timing belt for Silvertop is a Buick Skylark belt
GoodYear #40081(can be cross-referenced to another manufacturer at your local auto parts store)
it costs about $20
20v Ignitor/Coil assembly is the same part number as a 1990-1995 Toyota 4Runner. make sure the ignitor says "201" on it though, in green.
my mess of an 86...
Sam_Q
579 posts [99%]
Australia vic
 Re: Useful 20v Reference's (cmorganae86) » Reply  Edit
well I am happy to hear you found that pic useful, it had been around before but I stitched it together before uploading it.
A Lada Samara also has a compatible timing belt as a silver-top. It is a gates code T811
s-86.com
morgan
6446 posts [93%]
 Re: Useful 20v Reference's (Sam_Q) » Reply  Edit
i think i found that after googleing the diagrams. at first all i found were the 2 pieces, which were illegable when zoomed in on. either way, that diagram is great!
my mess of an 86...
The Knobs
5 posts [100%]
oxford
I need an oil pump gasket for a silvertop 20v in the uk. Can anyone tell me where and what part number, and if any other toyota ones fit ?
 First  1 2 >  Last
