 Useful 20v ReferencesFirst  < 1 2   Last
morgan
6446 posts [93%]
 Re: Useful 20v Reference's (The Knobs) » Reply  Edit
should be the same for other 4age's. did you go to the dealer? i got mine for about $15usd
my 20v in an 86 swap guide
my mess of an 86...
*east coast toyotas forum*
AS17
7 posts [100%]
Lusaka Lusaka
 Re: Useful 20v Reference's (Barry) » Reply  Edit
hi,
i am new to this forum. can some one please tell me if there is no complications in changing from auto transmission to manual transmission. i have a 20 valve sliver top and intend to do the conversion.
Asif
Fujii86Trueno
74 posts [100%]
Rochester NH
 Re: Useful 20v Reference's (AS17) » Reply  Edit
For those of you looking for an aftermarket Ignitor module for the Silvertop 20 Valve engine (and possibly the BT20V) look no further.
89621-12050 OEM Toyota Ignitor
Toyota Price: est. $302.00
CBE603 BWD (Borg-Warner) Ignitor
Available at Advance Auto Parts: $176.00
BWD Application is for a 1992-1995 Lexus SC400 with 1UZFE 4.0 V8 works perfectly for the Silver/Blacktop.
....vaughan....
6 posts [99%]
brisbane qld
does anyone know if i can use a 16 valve 100kw ecu in my 20 v silvertop
20vAe86GTS
2 posts [100%]
Houston Texas
 Re: (cmorganae86) » Reply  Edit
would that goodyear timing belt work with a 20v bt?
morgan
6446 posts [93%]
 Re: (20vAe86GTS) » Reply  Edit
no, BT is different and there hasnt been a suitable substitute found yet.
my mess of an 86...
morgan
6446 posts [93%]
found this over the weekend. theres a cheap replacement oil filler cap by Stant, p/n-11113. cost me $7 at Pepboys and it works just like it should. heres a link, wish i knew this earlier(i used a 2j off a sc300, but it says 5w-30, and the seals old.)
http://shop.advanceautoparts.c....html
also did a write up on replacing the valve seals
http://forums.club4ag.com/zerothread?id=82126
Modified by cmorganae86 at 10:17 AM 10/26/2010
my mess of an 86...
plogibear
1 posts [100%]
Antipolo Rizal
Guys, i need help. is it ok to put a cone type airfilter on a 4age 20v silvertop directly after the MAf/MAP sensor or should i make changes first?
morgan
6446 posts [93%]
 Re: (plogibear) » Reply  Edit
^ i think you completly missed the point of this "useful references" thread. start a new topic. but the filter should fit on the AFM with an adapter.
my mess of an 86...
runkillerrabbit
490 posts [98%]
yorba linda ca
theres 3 water temp plugs
for the ecu
for the gauge cluster
where does that last one go?
picture says (radiator)
will that effect start up?
would this be contributing to the no start status of my engine?
im totallllllly nub
morgan
6446 posts [93%]
 Re: (runkillerrabbit) » Reply  Edit
electric fan relay switch
Quote, originally posted by runkillerrabbit »
....................no^
my mess of an 86...
gts_dude
10 posts [100%]
does anyone know if the front main seal for a silver top the same as the 16v?
rc.square24
326 posts [100%]
Vancouver BC
 Re: (gts_dude) » Reply  Edit
Yes, front oil pump seal.
20v silvertop
28 posts [100%]
longisland ny
 Re: (rc.square24) » Reply  Edit
do you know where i can get the two hoses for the isc valve cause i brought a hose at tinkers but when i had to bend it the hose kinked
xtux
21 posts [100%]
Manila NCR
informative thread
trdslut
583 posts [96%]
does anyone know what other car i can hunt at the junk yard for a new coil and ignitor for my 20 v...help!!!!!!!!!!!!
morgan
6446 posts [93%]
 Re: (trdslut) » Reply  Edit
Have you looked thru this thread?
Quote, originally posted by morgan »
alternate timing belt for Silvertop is a Buick Skylark belt
GoodYear #40081(can be cross-referenced to another manufacturer at your local auto parts store)
it costs about $20
20v Ignitor/Coil assembly is the same part number as a 1990-1995 Toyota 4Runner. make sure the ignitor says "201" on it though, in green.
Quote, originally posted by Fujii86Trueno »
my mess of an 86...
trdslut
583 posts [96%]
 Re: (morgan) » Reply  Edit
thank you so much man, im off to the junkyard.
trdslut
583 posts [96%]
sorry to bug you morgan but do you know what tps i can use, my car turns on now but the motor sputters now when i try to rev it and i checked the timing and it fine.
morgan
6446 posts [93%]
There's something on 4agblogsome.com about cross referencing to some USDA motors like the 2j n/a motor, but I've read stuff about them rotating in the opposite direction.
my mess of an 86...
zlidewayz
2193 posts [99%]
CenCal CA
 Re: Useful 20v Reference's (morgan) » Reply  Edit
what happened to the second informative thread 4age20v.blogsome is it no longer hosted or available... everytime i click on the link i get nothing
"Living the ae86 life" ...what other way to enjoi driving then to drive zidewayz
Thumbs up to Eric at RhysMillenRacing
Also in need of super clean Driver and Passenger Fenders email me
BEST FORM OF CONTACT= zmanae86@yahoo.com
morgan
6446 posts [93%]
 Re: Useful 20v Reference's (zlidewayz) » Reply  Edit
been wondering the same thing, was trying for the past week...not sure what happened.
my mess of an 86...
D-TouFF
2 posts [100%]
Saint Hubert QC
 Re: (SkillaKali) » Reply  Edit
somebody know if the engine specification of blacktop are the same that silvertop, thanks !
 First  < 1 2   Last
