For reference only, all new posts and communications should be posted in the new forums at
 4ac ignition timing
gagg maggot
11 posts [99%]
Tucson AZ
 4ac ignition timing Reply  Edit
my timing is WAYY advanced, so far that i cannot retard it enough to even register on the crank pully, id guess 20-25* advance.
The cars O2 sensor is not hooked up... don't ask me why, I just bought the car
Is this a slipped timing mechanism... or is it the fact that the O2 isn't hooked up? (wires are missing)
1146 posts [100%]
Sounds like you have the distributor gear inserted at an angle.
Fully Restored 1985 Corolla GT-S
1987 328ci SR20DET Drift Car
1989 Honda Civic Si-R Current Project
2002 Corolla CE Daily Driver
gagg maggot
11 posts [99%]
Tucson AZ
 Re: (F0Bman) » Reply  Edit
I checked the timing belt, its fine.
Replaced the O2, runs better but timing is still like 20-25 advance.
I did try moving the distributor gear a tooth, and it made no difference. Should it? Should I try more than one tooth? At TDC where should the rotor tip be?
Will it do this if a water temp. sensor is bad? Is the car stuck in cold start mode or something?
494 posts [97%]
Kelowna BC
 Re: (gagg maggot) » Reply  Edit
You might have moved the tooth in the wrong direction. I think stock timing should be 5btdc. I had mine at 10btdc and it ran good.
» Return to Cars - RWD - (AE86, TE, KP, RA, TA)
