 Compilation of 20v nonoem plug and pin part numbers
mr220v
1246 posts [100%]
Atlanta GA
 Compilation of 20v oem and nonoem plug and pin part numbers Reply  Edit
Here are most of the 20v's (and many other toyota's) nonoem part numbers. There are 3 main manufacturers involved:
Yazaki:
Igniter 7283-1056-30
knock 7283-1015-10
coil 7283-8226-30
airtemp 7283-1224-10
vvt 7283-7526-40
recepticle tab/terminal 7116-4025
seal 7157-3646
Sumitomo:
evap 6189-0249
injector 6189-0573
map 6189-6912
camposition (will update)
O2 (will update)
Tyco:
12pin ecu plug 917978-1
16pin ecu plug 917981-1
22pin ecu plug 917989-1
26pin ecu plug 917992-1
tps plug 178399-2
watertemp 178392-6
ecu recepticle tab/terminal small 175265-1
ecu recepticle tab/terminal large 175269-1
So there's 90% of the connectors and parts in a 20v harness. Other toyota harnesses have a lot of this stuff in common.
Most of these can be had from various suppliers around the internet. I'm working with a supplier who will provide them all at once to simplify things. I really don't want to be in the electrical supply business. Basically it will allow a "new" option with my harnesses. Of course, with this info, even a Diy'er will have "new" capabilities.
Some of these connectors are readily available in the junkyard. For example, the map and iat plugs can be found on nearly any toyota that used a map sensor.
Modified by mr220v at 3:18 PM 4/16/2009
Modified by mr220v at 4:22 PM 4/16/2009
Modified by mr220v at 4:42 PM 4/16/2009
Modified by mr220v at 10:31 PM 4/16/2009
Modified by mr220v at 4:00 PM 4/28/2009
Email questions to mr220v@gmail.com
ura86
1931 posts [98%]
Central FL
 Re: Compilation of 20v nonoem plug and pin part numbers (mr220v) » Reply  Edit
Now anybody can make a new 20v harness . Thanks for your contribution to the community.
"Foro para la comunidad de AE86 de Puerto Rico http://ae86pr.com/ "
Starlet KP61 Forum http://www.kp61.com
kameleon
33 posts [100%]
Jackson MS
 Re: Compilation of 20v nonoem plug and pin part numbers (ura86) » Reply  Edit
That is what we are here for! I personally have been lurking for a while but be on the lookout for more from us in the very near future.
Kameleon
http://www.side2sideracing.com
mr220v
1246 posts [100%]
Atlanta GA
For those of you wanting to order directly from toyota, here's the OEM list:
Add prefix 90980- to all plugs:
vvt 90980-11162
injector 11285
tps 10711
map 10845
knk 11166
evap 11156
starter solenoid 11400
Idle control 11145
water temp 10737
camsensor/dizzy 11150
airtemp 11163
coil 11246
igniter 11232
22pin ecu 11392
16pin ecu 11391
26pin ecu 11390
o2 11028
Modified by mr220v at 5:02 PM 4/28/2009
mr220v
1246 posts [100%]
Atlanta GA
bump
Hachi_Drifter
104 posts [100%]
Atlanta Ga
 Re: (mr220v) » Reply  Edit
i know its off topic. but is there an usdm car that has the same spark plug wires as the 20v
mr220v
1246 posts [100%]
Atlanta GA
 Re: (Hachi_Drifter) » Reply  Edit
Not the exact same set, no. There are a few sets that can be adapted to fit, but the boots and wires are too long.
You can order a 20v cap and wire set directly from toyota. Just call Aaron at lithia toyota. It only costs a little more than other toyota wire sets.
Hachi_Drifter
104 posts [100%]
Atlanta Ga
oh cool. but what about aftermarket wires ?
Jan Pedersen
531 posts [100%]
Anybody know the PN for the plug for 1ZZFE cop's?
'86 Euro Levin Project
mr220v
1246 posts [100%]
Atlanta GA
Magnecor makes, or made an aftermarket set. From what I remember it was pricey though.
I can look up that 1zz coil plug number when I get home.
Modified by mr220v at 6:10 PM 5/18/2009
Jan Pedersen
531 posts [100%]
I would appreciate that!
kitsune
There is no charge for AWESOME
3808 posts [100%]
Seattle WA
YES I would like the PN for the 1zz COP as well as the plug harness too.
Mike
mr220v
1246 posts [100%]
Atlanta GA
The part# for the 1zz cop plug is 90980-11885
mr220v
1246 posts [100%]
Atlanta GA
You can buy the terminals and seals here cheap:
http://www.bmotorsports.com/sh...9_110
mr220v
1246 posts [100%]
Atlanta GA
Pricing on a completely new set of 20v plugs from toyota comes to $125. So if you want a harness made with new plugs, just add an additional $125 to my normal $350.
So anybody wanting to go that route because they don't have a harness, let me know. With my service, I provide brand new terminals and wire much of the time anyway.
Another option for those who don't have a 20v harness, but want a little bit cheaper alternative to ordering the connectors, I allow people to substitute 93-97 4/7afe harnesses in place of the 20v harness. I have done this on a number of occasions with great results. The 4/7afe harness has 85% of the same connectors that the 20v harness has. I have the missing ones on hand, which I supply as part of the service.
93-97 corolla customers don't have to send me a 20v harness at all.
mr220v
1246 posts [100%]
Atlanta GA
Anybody wanting toyota cop plugs, just add $20....though I may add this to ae86 harnesses automatically at some point.
jdm86gtz
711 posts [100%]
Waterford Ireland
Where did you find the plug part # as I have looked through the EPC and couldn't find them. Thanks for sharing ++
mr220v
1246 posts [100%]
Atlanta GA
With the majority of toyota plugs, there's a little number printed on them. Add the prefix 90980- and there's your part number.
This works on most plugs made since 1990. Prior to 1990 you have to refer to the toyota wiring harness repair manual for part numbers. Basically, you have to identify your plug.
s14 2510s
207 posts [100%]
m MN
Mr220v how much would you want to build a jumper harness for a greddy emanage. bt 20v. Im going to pick up the harness you built for my prizm today. Im never around when they drop off our mail so I have to get it from the post office.
mr220v
1246 posts [100%]
Atlanta GA
 Re: (s14 2510s) » Reply  Edit
Email sent
mr220v
1246 posts [100%]
Atlanta GA
Pricing on a new set of 20v plugs from toyota is around $115. Prices on individual plugs are all around $5.
Corolla 86
433 posts [100%]
CA
how much you charge for 7afe harness covert to 20v in a ae86? thanks for sharing!
mr220v
1246 posts [100%]
Atlanta GA
 Re: (Corolla 86) » Reply  Edit
Same price as the normal 20v service. Generally $350+$30 return shipping.
choi0706
217 posts [100%]
TEXAS TX
can you make a harness between a bt20v with EDIS and MS2?
NIXmx1
1892 posts [94%]
Las Vegas NV
A lot of these replies should either be PM'd or on another topic. Let's keep this about connectors.
I see on the website (Ballenger Motorsports) they you can buy with or without pins/ seals. Do the OEM kits come with the seals and pins too? Thanks.
~If the links to my images are broken, please send me the URL of the thread so I can fix them. Thank you.~
10 トヨタ so far...
GearCalc :: A Guide to Posting :: 4AC Powered - Get your single cam love
mr220v
1246 posts [100%]
Atlanta GA
 Re: (NIXmx1) » Reply  Edit
Ballenger motorsports is a great place to get small (or large) quantities of this stuff.
Oem connectors don't have terminals or seals. It's just a housing.
VitriumGTS
4730 posts [96%]
San Jose/San Diego CA
What if I needed a Tyco Electronics connector off a toyota yaris? I've been looking all over for a single unit of 82824-52330 (tyco number 175964-1) and dealership says they can't order it despite it having a part number...
.Patrick.
130 posts [99%]
Clearwater FL
 Re: (VitriumGTS) » Reply  Edit
I'm looking to make a plug and play for my standalone to my stock harness. Anybody know the part number for the ecu plugs (ecu side, not harness side)?
i believe theyre the male connectors.
WTB: TRD, swift, or similar rear springs. spring rate somewhere between 4.5 - 5.5kg/mm, preferably uncut.
mr220v
1246 posts [100%]
Atlanta GA
If you want to order a plug from the dealer, there's usually a number printed on the plug. Take that number down and add the suffix 90980, and there's your part number. Toyota plugs are usually $5-7
gotzoom
961 posts [99%]
Silicon Valley CA
The connector for most of the late 90's and 2000's coil on plug coil packs is part# 90980-11885 which is the connector with pigtail wiring.
Bay Area Autocross Forum
85 Corolla GTS Mild mannered road car
86 Corolla GTS Time Attack build in progress
99 Sport Miata CS #94
02 Miata daily driver chick car
