 Panda Levin - 2005 Restoration... on going projectFirst  < 2 3 4 5 6 >  Last
t.k.
1372 posts [97%]
ROFL ahaha
 Re: (apardal) » Reply  Edit
thanks a bunch!
"I love it--but its a riceburner, not supercar. Doesn't bother me if someone calls it that, I figure it is also a good $20,000 cheaper than even a cheap BMW.<G>"
~Red
Eric’sFreeAE86 on the FT86
"Yeah Toyota's been carrying this baby for like 5 years. They'll come out rusted and broken. "
"A 4cyl is all u need to scare u 5hitless in a street rolla."
~jinx
AE86 FSM
http://www.aeu86.org/index/tec...=5158
props to 84hatch
apardal
364 posts [100%]
 Re: (t.k.) » Reply  Edit
Some more work done.
Closed the throttle a little to lower the idle, installed the pipercross air filter and 40mm trumpets.
Best regards
Hatchipinoy
396 posts [97%]
Las Vegas NV
The filter looks amazing! Will you be routing a cold air pipe to the filter? Does having that brake booster line connected to the Vacuum log have any effect at all in brake assist? I always thought to have the brake booster line connected to the intake manifold for proper vacuum but if it works for you then I might do that as well.
Track day at Pahrump, NV http://www.youtube.com/watch?v=da2VJJxaFkc
apardal
364 posts [100%]
Yes, the brake booster needs to be connected to this vacuum canister or else it won't brake at all.
I'm gonna leave the filter as is. At least for now!
Best regards
joe4ag
1178 posts [100%]
wow nice job bro cool ride
Hatchipinoy
396 posts [97%]
Las Vegas NV
Quote, originally posted by apardal »
Best regards
I guess my first statement was confusing. Vacuum is still vacuum no matter where you tap into. Makes for a cleaner install as well. I was just stating that I was originally planning on connecting the brake booster vacuum line to a bung right on the intake manifold adapter for the itbs. Now it looks like I will tap into the vacuum log instead and keep it tuck it somewhere for a cleaner install.
apardal
364 posts [100%]
Hi!
Went to Estoril Racetrack this weekend.
http://www.youtube.com/watch?v=Mwti-QTCBfg
http://www.youtube.com/watch?v=iVw-vqiU7X4
GinoX
1465 posts [100%]
It doesn't pay to restore and modify cars like this overseas. Customs make everything so much more expensive...
Heheh you got that right! Overhere we pay customs like 50% over the c.i.f. value of the goods. Example: one 4AG TODA cam costs US$ 525, we just multiply that with factor 3 to get what we must pay in total in our money to get it installed in the engine. In 2002 my rebuilt "bluetop" with HKS 258/264, Group A crank and rods, ARP hardware etc also cost ~US$10K in total. In today's money it would have been like ~US$14k.
Engine only.
ronny
RnD Office - Ronny
7077 posts [89%]
Irvine CA
 Re: (GinoX) » Reply  Edit
this car, is my insperation that made me start mine.
i am about 85 percent done.
just wanna say thanks! awsome.
VOLK TE37 only....!
project plan- 86 TWINKIES - has Begun..
Basketweaving M-F 7pm plz contact superstarlevin for enrollment
:thumbup:
apardal
364 posts [100%]
Good luck finishing yours then...
apardal
364 posts [100%]
This topic is dying!
I've made some improvements.
Bought a pair of Kent Cams with 298 duration and 9.4mm of lift.
Dynoed it and this is what came out:
Lowered ignition advance by 2 degrees
Comparison between 288 (7.5mm) Toda Camshafts, stock intake and kent cams with ITB's:
And 3 days later, there I was, Estoril racetrack.
Track Day footage!!
http://www.youtube.com/watch?v=mZDo_yeBY7E
http://www.youtube.com/watch?v=vCH5eujw2Qs
Need to change clutch, fix exhaust and big brakes.
For the brakes I've already ordered:
Best regards
apardal
364 posts [100%]
Some news!!
Last saturday did a couple hundred miles with the 86 to do some data logging and get some results. I rarely drive the car on highways so I got some surprises.
5th gear went straight up to the rev limiter at 8900rpm which is 234.77 km/h regarding 4.778 R&P and 195/50R15 tires. GPS gave a reading of 240km/h (150mph).
It is neither the purpous of my car nor the most fun I get from it, but I can't disregard the fact that it is a pretty decent speed there. Never seen videos of AE86 @ Top speed.
The noise from the new exhaust is almost bareable but it is no car for highway driving.
http://www.youtube.com/watch?v=srYolEsn7Gs
People say the car sounds nicer from the outside.
Some pictures I took:
Best regards
ga_goosh
2498 posts [100%]
far enough to require shipping HTX
wow exelent build looks good and with all of your goodies i bet it drives as good as it looks
I <3 my AE86
Kouki 86-87 Service Manual
4AGE Diagnostic Manual
Toyota Wiring Repair Manual
20V Blacktop fsm
.......USE THEM!!!.......
TEXAS 86 Forum
http://www.86garage.com
Grant
3656 posts [86%]
San Jose ca
Did you ever solve the vibration problem????
I have the same symtoms that you were describing. I think the engine mounts aren't supposed to sit on the chassis with the metal flange touching the chassis.
My problem only occurred after replacing engines.
Let me know if you found out what the problem was.
I've got the same deal, bad vibration when decelerating in gear around 3K....
Stand Alone ECU tuning. Message me for details.
Looking to buy a corolla manual rack and a TRD 3 gear transmission.
*also wtb 4 point roll cage/bar for ae86 coupe
Grant
3656 posts [86%]
San Jose ca
170 CV at the wheels or at the flywheel?
apardal
364 posts [100%]
 Re: (Grant) » Reply  Edit
Flywheel power.
The vibration problem was solved in the rear differential. It's not perfect though.
Grant
3656 posts [86%]
San Jose ca
...that's odd then. B/c the only thing that has changed for me was the engine and mounts. Differential remained the same. The search continues...
OK, so....I have a blacktop, which is supposed to be rated at 165 or 170 PS, and it's no where near that fast. I think I'd hit 130mph if I was lucky. Sigh.
apardal
364 posts [100%]
A few more pics from recent mods.
Quaife Quick Steering Rack:
Exhaust:
Soon, Brembo brake upgrade
Best regards
apardal
364 posts [100%]
More upgrades.
A friend of mine is helping me to do somethings left behind in my car.
Tried to assemble the brembo brake kit that seb sold me but there were some issues. I have to use 7mm wheel spacers and the adapters he made weren't very accurate.
Bought some heatwrap to lower the temperature in the engine bay.
Some pics:
Fuel pressure was raised and changed the injection to sequencial. More mapping to do.
I also found a throttle linkage from a silvertop that didn't came with my itb's.
Finally, my friend gon setup the megasquirt to use the ECON/PWR lighs as a shiftlight.
Some pics from the brake kit soon.
Best regards
apardal
364 posts [100%]
Yesterday I got the Brembo kit installed.
First impression is satisfying. Good brake feeling and power.
Against: Not plug and play and it turns out expensive. You'll need to use wheel spacers and work the calipers to fit the smaller rotors.
Best regards
Plex
3761 posts [89%]
Suisun City CA
Amazing build.
Summa Cum Laude Graduate, AE86 University Class of '02
apardal
364 posts [100%]
 Re » Reply  Edit
Went to an event organized by Drivers Legion at go kart track last saturday, the day before the portuguese annual AE86 meeting.
http://www.youtube.com/watch?v=9cCT3dXuWEk
You can watch it in HQ.
The car is simply great. True pleasure to drive.
The big brake kit upgrade feels nice and the suspension is great. gon made some tire pressure adjustments throughout the event that made the difference.
Best regards
apardal
364 posts [100%]
 Re: Re (apardal) » Reply  Edit
Hi!
Great debut at the new racetrack in Algarve
Some photos to keep this topic up to date.
http://www.youtube.com/watch?v=TpmnGzJG3UA
http://www.youtube.com/watch?v=nUavOS2Br4M
Some repairs to do after this last track day.
Have to try and find a possible air bubble inside the brake lines, change 2nd gear synchro and eliminate gearbox's input shaft vibration.
At the end of the day, it is awesome to think how good this car goes on the track. True pleasure to drive.
Best regards
ME_86
34 posts [100%]
last pic thumb up : you deserve for that brother..
very nice builds.
Hate those new vehicle!!suck!!like piece of s##t.
my toys lined up:
BSA WM20 1942
NORTON DOMINATOR 1957
LANDROVER SRIII SWB 1979
TOYOTA STARLET EP70 1986
TOYOTA TRUENO AE86 1986
MyRolla
55 posts [100%]
Woodhaven NY
envyy
http://myrollaae86.blogspot.com
http://ectoyotas.com
East Coast Toyotas Forum
ritzblitz
22 posts [99%]
Quakertown PA
Perfect.
Fluffy Bunny Feet
1544 posts [96%]
Fresno CA
what rear muffler is that if you dont mind me asking
apardal
364 posts [100%]
 Re: (Fluffy Bunny Feet) » Reply  Edit
It is an Apexi WS Universal.
Joey F.
29 posts [100%]
AE86 FL
 Re: (ritzblitz) » Reply  Edit
Quote, originally posted by ritzblitz »
Perfect.
I agree.
Great job !
http://www.tuningspl.com
pholife
3691 posts [100%]
Laguna Beach CA
 Re: (Joey F.) » Reply  Edit
Quote, originally posted by Joey F. »
I agree.
Great job !
ditto
http://www.torparts.com
The WORLD Leader in OEM+Plus Reproduction Parts.
Get on facebook...torparts corollla for updates and discounts.
