 Panda Levin - 2005 Restoration... on going projectFirst  < 2 3 4 5 6 >  Last
HOTDAM
207 posts [100%]
ca
 Re: (pholife) » Reply  Edit
this is and incredible build. especially love how you drove the car broke something and built it better each time.. its like i story i never get sick of.. keep up the good work and keep taking this thing out to track days..
efficiency is key !
apparently im to mean to people on here. do better work and I wont make crude comments. :thumbup:
apardal
364 posts [100%]
 Re: » Reply  Edit
Thank you for all your comments and input.
You make me feel proud of what I've accomplished!
assassin10000
Teq
4959 posts [100%]
Northern CA
 Re: (Grant) » Reply  Edit
Quote, originally posted by Grant »
I think I'd hit 130mph if I was lucky. Sigh.
Really? With my old 16v I hit 125... and it was still accelerating when I let off.
Nice build tho.
Andrew
p.s. I don't recommend or condone trying it... do as I say, not as I do . Unless your on a race track, then go for it!
p.p.s. Sorry about the response to such an old post... didn't realize the date until afterwards.
Grant
3656 posts [86%]
San Jose ca
For what ever reason, I think my blacktop is only giving about 140 at the crank. I am dropping some cams in very soon so hopefully I will at least be up to what the engine is rated at from the factory.
Stand Alone ECU tuning. Message me for details.
Looking to buy a corolla manual rack and a TRD 3 gear transmission.
*also wtb 4 point roll cage/bar for ae86 coupe
mini 2jz
107 posts [100%]
newark nj
very nice job....
kaneeyez
27 posts [100%]
Brooklyn ny
 Re: Panda Levin - 2005 Repair and further tune up (apardal) » Reply  Edit
good **** bro
apardal
364 posts [100%]
Not for the quality of it, but for what it shows, this is the best picture ever taken of my car in action.
It was taken early last year at Palmela Go-Kart Track.
apardal
364 posts [100%]
Some other older pics I had laying around...
apardal
364 posts [100%]
And a video I made recently.
http://www.youtube.com/watch?v=Mmm8hJSFZaw
The Sprinter
988 posts [99%]
Miami FL
Great Vid !! :-)
So you want to run a F20 or F22 swap? Always remember what HASportAE86 said:
It costs alot.
It's very fast.
Don't do it if you drive at an amatuer level. Honestly. You'll just suck...or crash...or suck and crash.
Fluffy Bunny Feet
1544 posts [96%]
Fresno CA
is your "econ" light your shift light?
apardal
364 posts [100%]
Yes, that is correct. Both ECON and PWR lights were made to function as shift lights with the megasquirt.
They light up at 8500. The rev limiter is at 8900.
Modified by apardal at 11:15 AM 1/20/2011
zacko9000
14 posts [100%]
Tulsa OK
Awesome build, love the Levins.
kraz3y
420 posts [97%]
Union City CA
nice build! how did you fix your detonation issue?
apardal
364 posts [100%]
 Re: (kraz3y) » Reply  Edit
I installed longer duration camshafts
Grant
3656 posts [86%]
San Jose ca
that's crazy!
What has your fuel economy been like? Is it much worse with such large cams?
I don't know if you saw it, but a company in the US is making a tall 5th gear for the t50..... .734 vs .87 stock. If this would be good for you look in the "general tech" section of this forum.
apardal
364 posts [100%]
Well, I have no worries regarding fuel consumption because I rarely drive the car. But it isn't as bad as it sounds, because I have my megasquirt tuned with closed loop for TPS below 40%. That way, I can get good mileage for long journeys. 9 Liters per 100 Kilometers which is around 26 mpg.
That said, the tall 5th gear makes no sense, because this car's use is mostly at the track.
Best regards
Floyd
4 posts [100%]
Zlin CR
 Re: (apardal) » Reply  Edit
wow, amazing build
Still using stock bluetop rods and crank (40/18) when rev to 8900?? no upgrade in this area??
apardal
364 posts [100%]
 Re: (Floyd) » Reply  Edit
Almost everything stock within the small block.
Only Wiseco Pistons and ARP Bolts. Stock conrod and crankshaft.
Let's hope it holds!
runkillerrabbit
490 posts [98%]
yorba linda ca
 Re: (ronny) » Reply  Edit
ronnys car was my inspiration... so technically this car is my inspiration also!
i spent about 14k on mine tooo i just gunna assemble it now
ive got 2 motors though .. your lucky you dont have to deal with the california smog laws.... i gotta engine swap every 2 years but you got the customs to deal with!
im totallllllly nub
AK 47
911 posts [97%]
very nice!
dangina
461 posts [97%]
lethbridge ab
spent the time going through the build looks great! Looking at your latest photos I think you should get a higher spring rate or bigger front sway bar...
Build Thread!
http://forums.club4ag.com/zerothread?id=75666
apardal
364 posts [100%]
 Re: (dangina) » Reply  Edit
Why do you say that dangina??
dangina
461 posts [97%]
lethbridge ab
in two of your pictures you can see the heavy body roll of your car - one of them the front tires is coming off the ground! I dont know what springs rates or sway bar your running but i would say try a bigger sway on the front to keep both your tires planted and maybe up your rates a notch to even out that roll ..
Build Thread!
apardal
364 posts [100%]
It is my belief that you have to find a compromise between body roll and suspension stiffness to maximize grip.
I've got greddy coilover kit with 8F/6R and stock sway bars.
I don't think I'll benefit from uprating the suspension stiffness because I think I'll lose grip, and body roll I got doesn't seem so bad. At least I find the car a joy to drive as is.
Thank you for your input though.
Best regards
Grant
3656 posts [86%]
San Jose ca
stiffer front sway bar will make the wheel lift worse, not better.
I'm of the belief that if the car is balanced, there isn't much to be gained by having the front wheel just slightly on the ground vs off it....
trd-hachi-roku
700 posts [94%]
the only thing that is "wrong" is droop travel no? I mean the suspension at full extension still can't reach the ground...that or he just bounced off the curb when someone snapped the pic...hahahhaa
apardal
364 posts [100%]
 Re: (trd-hachi-roku) » Reply  Edit
The wheel in the air is something common on live axle RWD's.
It's been always like that and as Grant said... there's not much to gain from having that wheel on the ground.
children
148 posts [100%]
SoCal
Bravo! I wish I had that money&techic to build one!
Rex
695 posts [99%]
Monterey Park CA
YOU ARE BEAUTIFUL!!
