 The 7age thread? Info wantedFirst  < 4 5 6 7 8 >  Last
orangekid
3249 posts [87%]
please, no pictures...
cut the existing metal tube in half, then just run a piece of hose with some clamps...
te51levin
811 posts [100%]
Pacific NW
 Re: (86Chris) » Reply  Edit
Quote, originally posted by 86Chris »
te51levin, On my 7age setup I am having trouble sourcing a water bypass valve that will span the expanded distance now created by moving the upper coolant intake(?) on the head further away from the where coolant exits/enters in behind the water pump on the block.
My setup is in an MR2, which is simpler than an AE86 as far as the cooling system goes. I'm not sure exactly what you mean by "water bypass valve" but I'd be happy to take a look at any pictures you can post of the problem area and see what can be done.
Visit SV3Power.com for 4AGE and MR2 exhaust components.
New for September: dual pattern 16V/20V 4AG header flange. Introductory price $27.95
86Chris
13 posts [100%]
sacramento ca
 Re: (te51levin) » Reply  Edit
[quote=te51levin] I'm not sure exactly what you mean by "water bypass valve"
Maybe it's not be applicable in an MR2 cooling system, depending on how the coolant system is configured in that car? (I'm not certain of this) It's the metal tube that runs vertically from the housing where the upper radiator hose feeds into on the head, (& the coolant sensor(s) are mounted) down to the housing for the thermostat directly behind the water pump. It has an o-ring on both sides where it meets either housing.
I was running a metal tube that had been cut & extended with a hose as orangekid suggested, but it has leaked occasionally & I wasn't sure if there was a coolant setup I could piece together or modify (maybe different housings or a metal coolant tube from a different engine) that would remedy this.
te51levin
811 posts [100%]
Pacific NW
OK, I'm with you now. MR2s do not have that pipe but I do remember it from my old AE86.
Rather than try to clamp a rubber hose to a steel pipe with no bead, I would consider extending that pipe by 15mm or so. IIRC the pipe sits on an angle and you would have to weld the extension in with that in mind - i.e. you'd want to cut the pipe in half, then insert each half in its home and cut/fit a piece to go between, rather than just adding a straight piece on the bench.
86Chris
13 posts [100%]
sacramento ca
te51levin, I like your idea and am going to give that a shot. My only concern is any potential obstructions that might be created inside the bypass tube as a consequence of welding in an extension (I'm not knowledgeable or experienced in welding and am not sure about the likely hood of this happening).
At this point, your suggestion looks like my best option. Is it worth the extra trouble, you think, to find a tube/pipe just slightly larger than the diameter of the bypass tube to fit the two halves into and weld the three pieces together from the overlap where the extension tube/pipe would hypothetically be? Not sure, but I'm thinking this might minimize the chances of creating any obstructions inside the tube caused by welds/welding.
Thanks.
te51levin
811 posts [100%]
Pacific NW
I think you are solving a problem that does not actually exist. Over-thinking little issues like this runs the risk of paralysis by analysis, which is absolutely crippling.
That bypass pipe does not need to slow a huge amount of water, and certainly not any specific figure. Flow must simply be "adequate".
Use any convenient steel tubing that is similar in size to the existing pieces, and from it, cut a patch piece to go between the ends. If the person doing the work is reasonably careful (i.e. not an absolute chimp) they will not fill the repair with junk. The tubing is also thin-walled enough that brazing is a viable option.
Find a friend, co-worker , or sympathetic local shop who can do careful work at a reasonable price and it'll be just fine. If they are skilled and experienced, they will know several appropriate ways to perform the task without worrying it to death.
dugballs
1 posts [100%]
Pasig City NCR
Hi guys, I am currently building a 7AGE using a blacktop (BT) cylinder head.
Everything fits nicely except for the BT AC bracket because the tensioner of the BT AC bracket hits the 7AFE oilpan. any ideas? I don't want to use 7AFE accessories, I really would rather just slap on my old BT accessories onto the 7AFE block. Makes my life so much easier.
86Chris
13 posts [100%]
sacramento ca
[quote=te51levin]I think you are solving a problem that does not actually exist. Over-thinking little issues like this runs the risk of paralysis by analysis, which is absolutely crippling.
te51levin, I think you were right about me over analyzing a problem that didn't exist. I can't weld, or find anybody reliable in my immediate area to weld for me, so I used orangekid's method for the time being and so far it has held up fine unlike my previous attempt to cut & extend the bypass pipe.
Two weeks and counting so far. Orangekid and te51levin, thank you for your help.
te51levin, all your 7age information & input has definitely helped me with my 7age build, and maintenance, this past year.
Toy86
354 posts [100%]
Crestview FL
Sup everyone, I have a 8-6, and going to be putting a 7age in it.
Flywheel/Clutch set up- Do they make after light weight Flywheels/ clutch set ups, for this engine, or any compatible ones from a differt car? Is a light weight flywheel a good option?
Heads- I have two of them. I have a regular Blue top head, and i have a JDM Red top head. I have matching pistons from the Blue top 4age; what would happen if i used the Red top, with blue top pistons for the 7age?
ARP Head Bolts- Won't ARP Head bolts of a 4age work for the 7AGE? Even though the block hight has changed the height the from the head to the block hasn't, so wouldn't the ARP 4age head bolts work for the 7age?
Those are pretty much the only questions i have so far for this build. Thanks guys for the input.
Evo_lucian
1584 posts [95%]
Saint Lucia, West Indies
 Re: (Toy86) » Reply  Edit
Quote
there are a few lightweight flywheels available for 7af/4af. It depends on who you ask but i think its a good mod for n/a 7ag
Quote
Heads- I have two of them. I have a regular Blue top head, and i have a JDM Red top head. I have matching pistons from the Blue top 4 age; what would happen if i used the Red top, with blue top pistons for the 7 age?
Use small port head. Blue top pistons have 18mm wrist pins and 7afe rods have 20mm wrist pins so they won't fit.
Quote
ARP Head Bolts- Won't ARP Head bolts of a 4 age work for the 7 AGE? Even though the block hight has changed the height the from the head to the block hasn't, so wouldn't the ARP 4 age head bolts work for the 7 age? Those are pretty much the only questions i have so far for this build. Thanks guys for the input.
Yes they should fit but they are not necessary. We broke 3 sets of 4age flywheel bolts on one of our 7age 20v , currently replacing last set with ARP flywheel bolts.
Dwight
(\__/)
(")_(")
A$s¤ho£€ since 1986.
The only thing in life worse than being talked about is not being talked about
my site
http://budgetracer.webs.com
matt dunn
50 posts [100%]
 Re: (dugballs) » Reply  Edit
The 4age blacktop sump etc will fit the 7a block.
7AGTE 20V Turbo
475hp atw
Toy86
354 posts [100%]
Crestview FL
Dwight, thanks for the info.
"there are a few lightweight flywheels available for 7af/4af. It depends on who you ask but i think its a good mod for n/a 7ag"
Do you have any websites or brands that you guys have chosen for your 7ag's?
"Use small port head. Blue top pistons have 18mm wrist pins and 7afe rods have 20mm wrist pins so they won't fit."
Do you have any recommendations for pistons to go with a red top hi comp head?
"currently replacing last set with ARP flywheel bolts."
Do you have a part # for the ARP Flywheel bolts you guys are going to be using? Also what about the Con rod cap bolts, i've read that you can get ARP ones for those as well?
Also looking for some aftermarket con rods. I read Argo makes them but they run for $1050 for the set. Any other manufacture out there like Crower make replacement rods that have the same specs, but a cheaper price as the original 7afe?
My project is going to be 16v head i'm probably going to be using the blue top cuz i have the matching manifold for my carbs, webber side drafts, I'll probably shave the head and block some to raise the compression to compensate. This project is going to be a N/A, I'm not planing on boosting, and i'm not planning on building hi rev engine, nor a crazy horse power one. I don't need to worry about smog, cuz i live in FL. I just want a strong well built engine.
Thanks a lot of the info.
Danny
matt dunn
50 posts [100%]
Quote, originally posted by Toy86 »
Use the 4AGE ones and end up wih two spares.
part # 203-2802
Not for the standard 7A rods as they are too different to anything else.
They are bolts that screw into the rods rather than studs and nuts like the 4AGE ones.
They are also reduced shank so have a look at one when it is out and you will see
how weak they look.
I do run the ARGO ones myself but we got them on a special deal.
They have been fine even at big hp,
but there are other options,
like
http://www.spoolimports.com/co...S.asp
http://www.belfabracing.com/
etc.
Matt
7AGTE 20V Turbo
475hp atw
Toy86
354 posts [100%]
Crestview FL
Matt,
Thanks for that info man, that really helped me out. I'm probably going to go with Belfab, if they're out of stock, i'll go with Spool. Either way you go, you'll end up with a better product than the stock tooth pic con rods.
Thanks
Danny
Evo_lucian
1584 posts [95%]
"there are a few lightweight flywheels available for 7 af/4 af. It depends on who you ask but i think its a good mod for n/a 7 ag" Do you have any websites or brands that you guys have chosen for your 7 ag's?
I'm on my phone now so can't really search right now but good quality flywheels aren't hard to find.
Quote
High comp (small port pistons) will give you a nice c/r .
Quote
Again don't have part number now but we got arp flywheel bolts for the 4age. 8 bolts, you will have 2 spares. We have had zero rod bolt problems in the past 5 years on neither of or 7age 20v. Stock rods and bolts on 75 shot nitrous.
Quote
Also looking for some aftermarket con rods. I read Argo makes them but they run for $1050 for the set. Any other manufacture out there like Crower make replacement rods that have the same specs, but a cheaper price as the original 7 afe?
Have been on stock rods for 5 years. IMO unless you gonna run some serious boost then stock rods will be just fine. Save the $ for something else.
Quote
My project is going to be 16 v head i'm probably going to be using the blue top cuz i have the matching manifold for my carbs, webber side drafts, I'll probably shave the head and block some to raise the compression to compensate. This project is going to be a N/A, I'm not planing on boosting, and i'm not planning on building hi rev engine, nor a crazy horse power one. I don't need to worry about smog, cuz i live in FL. I just want a strong well built engine. Thanks a lot of the info. Danny
Bluetop and redtop have identical combustion chambers. Before you go about shaving head or block, you can always try a 7afe head gasket its almost half a mm thinner than 4age. Will give you a nice bump in c/r.
Dwight
(\__/)
(")_(")
my site
Eric'sFreeAE86
2589 posts [100%]
Chattanooga TN
 Re: (Evo_lucian) » Reply  Edit
Really great info here. I'm really close to deciding to do one of these.
GinoX
1465 posts [100%]
 Re: (Eric'sFreeAE86) » Reply  Edit
Quote, originally posted by Eric’sFreeAE86 »
You won't be sorry....
Eric'sFreeAE86
2589 posts [100%]
Chattanooga TN
 Re: (GinoX) » Reply  Edit
Having the worst trouble finding a 7a bottom. Junk yard said they have one, I went down there and we looked for 3 hours and couldn't find it. Hopefully the tornadoes moved the motors around and it'll turn up.
Has anyone done a carb'd 7AGE? Because I'm converting from a 4AC so mine is two builds in one!!!
Evo_lucian
1584 posts [95%]
Canadianae92 has a carb 7ag . He posts a lot of info on the " ignition option for carb 4ag " in the 16v forum.
Dwight
(\__/)
(")_(")
my site
Eric'sFreeAE86
2589 posts [100%]
Chattanooga TN
I did finally find a great donor 7afe! I'll pick it up Tuesday and tear it down. It was a timing belt replaced sticker from the dealership, so I'm sure it's well serviced. I forget how many miles, i'll get that later.
But anyways, I'm sure i'll have questions about the cooling system. I can't think of any reason I couldn't reuse my 4AC water pump, i'll mock it up Tuesday and see. The 4age head I have has a smaller water neck at the front of the head than a 4AC and I thought all 4A's had the same size, just different shaped necks for FWD RWD SR5 GTS. I reckon I just need to have everything in front of me.
MartinS
178 posts [100%]
Zurich
I did summarize the built from a friend on our blog:
http://www.speed-industries.ch/wordpress/?p=3213
Check it out, any comments on the topic are appreciated! I hope it's enought first hand information, how he did it to achieve the result!
Cheers!
Eric'sFreeAE86
2589 posts [100%]
Chattanooga TN
Ok I got my motor today. I took the flex plate and backing plate off. I laid the backing plate on my GTS bellhousing and it doesn't line up. The top two bolts do, but nothing else does. My bellhousing is for a T50, this backing plate is off an automatic though. Why no match?
Oh and I stripped the motor down to just a short block.
Eric'sFreeAE86
2589 posts [100%]
Chattanooga TN
Here's my donor motor. The 4AC water pump does bolt right up to it. Any suggestions for the stubborn crank bolt? I don't have an impact handy.
And once I got the head off, I can see why you wouldn't want to use the 7AFE pistons! Talk about a deep dish, that's crazy low compression with a 4AGE head!
te51levin
811 posts [100%]
Pacific NW
With the head attached, feed some rope into one of the spark plug holes with the piston at the bottom of the power stroke (valves closed!), then turn the bolt with a breaker bar. The rope will prevent the piston from rising back up the bore all the way and will stop the crank from turning.
I measured the dish at 20.5cc on 7AFE pistons. Stock bigport 4AGE pistons are very close to 4cc net dish.
Eric'sFreeAE86
2589 posts [100%]
Chattanooga TN
That's a good idea. The head is just sitting on the block, so I can toss some in and bolt the head back down. Then I can yank the front off and pull the crank and stuff.
What about bolting up to a T50? I laid the 7AFE back plate on my bellhousing and only the top two bolts line up. Everything else was off. Do the bottom two big bolts not go through the back plate?
te51levin
811 posts [100%]
Pacific NW
You did something wrong (back plate upside down?) and/or are misreading it. If the starter is on the opposite side, reuse the back plate and starter that match the transmission you are using.
Eric'sFreeAE86
2589 posts [100%]
Chattanooga TN
That's what I figured. I should have stuck the bellhousing to he engine before putting it on the stand. But it is a 7AFE though, correct? The guys at the junkyard swore up and down it was a 1.6 until I found the original dealer invoice that said 1.8 and all the VINs matched.
te51levin
811 posts [100%]
Pacific NW
It's a 7AFE. The two piece oil pan gives it away.
Eric'sFreeAE86
2589 posts [100%]
Chattanooga TN
That's what I thought. I got the crank bolt out this morning before work. Then I flipped it upside-down down and found a nice dent in the bottom oil pan. I took all the bolts out and it's RTV'd together like crazy. I'll have to cut it off.
Cylinder walls look good, all still show crosshatching. I'll get some more pics when I get the pans off and look up her skirt.
Eric'sFreeAE86
2589 posts [100%]
Chattanooga TN
I took both pans off before the rain came. I think it's been apart before because the RTV in between the upper and the block was very uneven. And there was no gasket between the two pans, just more RTV. So here are my questions for today lol:
1) what size are the 12-point rod bolts? I think 12mm cuz they look bigger than the head bolts. I hate not having my tool chest anywhere near me
2) those stupid Allen head bolts, can I use regular hex head bolts in the places only accessible with a wrench?
3) the numbers stamped on the bottom of the block, is it common to be all different? These are bearing sizes right? I have 21122 and 3122
A real good sign, despite the high mileage, is the pistons are still full of oil. That tells me the walls and rings are sealing well enough that no oil is seeping through.
» Return to Engine - Other Toyota engines and off brand powerplants.
