 Reference: Spark Plug Wire Alternatives
karate_crimson
8227 posts [89%]
Southern CA
 Reference: Spark Plug Wire Alternatives Reply  Edit
post any cross reference wires you have seen that work with either 20v blacktop or silvertop.
I know some people try to keep info like this to themselves, but why keep useful information to myself? I know there are people in the same situation as me so I would like to help.
As far as spark plugs go, I found that the NGK Platinum Plugs part number BRK6EP-11 are a great match that I am running now on my car.
I also found that the 1993-95 4 runner 4WD (4 cylinder model) wires fit perfectly for the silvertop even down to the clips that clip into the distributor as well as the coil. i bought them from autozone for $33. saves you $80+ shipping for OEM. The only difference between them structurally is the stalks of the 4runner ones are shorter, but because they dont have a shroud cover like the oem ones, you can slide them right into place. you may want to run your spark plug cover to prevent dust from getting in.
The Autozone part number is 9023
Here are pics:
eage8
214 posts [99%]
MD
 Re: Reference: Spark Plug Wire Alternatives (karate_crimson) » Reply  Edit
If you want to run copper plugs, I did some cross-referencing and you can get NGK BKR6E but you have to re gap them from 0.9mm to 1.1mm. Everything else about them is exactly the same.
'89 RX-7 TurboII - SSM class auto-x - Megasquirt-3 beta tester - 270 rwhp
'89 Corolla SR5 - SMF class auto-x - 4AGE ST 20V, 6 Speed, LSD, Megasquirt II, Koni Race dampers + GroundControls, GT-S Rear discs
'01 Impreza 2.5 RS - SA class rally-x
For Sale: AE92 GT-S Front strut bar
Flowisode_Zero
2784 posts [99%]
Glendale AZ
This is a definite sticky. There is a new topic every week about which plugs/plug wires to run. People can find out easily enough by using the search function, but no one ever does. This has all the info they need so it would be a good sticky.
Why do noobs call their hatch a HATCHI, but no one calls their coupe a COUCHI?
karate_crimson
8227 posts [89%]
Southern CA
 Re: (Flowisode_Zero) » Reply  Edit
thanks guys for the input. I also went as far to modify the top of the 4runner wires, by cutting my oem top hats and running them onto the new wires, that way the cylinder holes are still covered.
here's what they looked like after:
and on my car (mind you its just a mock fitting):
karate_crimson
8227 posts [89%]
Southern CA
bump for sticky perhaps?
andrewl
705 posts [100%]
socal ca
i use the msd 8241 coil pack and use the v8 thunderbird wire 94-99 they are too long still trying figure out how to shorten them but the boot seals nice over the plug.
my ms unit will kick your a$$
Flowisode_Zero
2784 posts [99%]
Glendale AZ
Bump for a sticky!!
corolla55
6 posts [100%]
ocala florida
how you put this car map sensor
Hachiroku_desuyo
124 posts [100%]
LONG BEACH Tokyo
 Re: Reference: Spark Plug Wire Alternatives (corolla55) » Reply  Edit
buy a AE111 BT 20V 4AG-E
'85 3dr 20v PANDA; need new friends
'07 YARIS 3dr DD
ICEanLU
250 posts [92%]
thanks for the info bro!
wat about the stock 16v wires and distributor will the work?
morgan
6446 posts [93%]
 Re: Reference: Spark Plug Wire Alternatives (ICEanLU) » Reply  Edit
the ends of the wires that go into the dist are different, lengths too i believe. nothing related to the heads, swaps from 16v to 20v.
my 20v in an 86 swap guide
my mess of an 86...
*east coast toyotas forum*
John Roberts
93 posts [100%]
6057 State St. Lowville, NY
These pics you've shown were nice. Yeah,indeed the wires are of different sizes. I guess you just need to install the spark plugs wires properly.
Modified by John Roberts at 6:23 PM 6/21/2010
13133 posts [99%]
Portland
Magnecor will make you custom wires.... any length, any ends - just ask, and give them measurements
For example...
my wires, perfect fit, yet they run through the intake manifold gap to the passenger inner fender where the coils are mounted
GtsTone23
3595 posts [99%]
Chicago IllaNoise
^^^ oldeskewltoy, your valve covers look awesome!!
"Behind every Successful Man lies a Pack of HATERS,
If they aint Hating Now, They'll be Hating Later"
~GtsTone23~
Igorek
1 posts [100%]
Chelyabinsk
 Re: » Reply  Edit
Hello,
i use NGK RC-TE55 (=44$ in Russia) spark plug wire in car, 4a-ge blacktop, they are from toyota corolla levin.
Also it is possible to buy from us:
- Seiwa 50020 (=31$)
- Masuma MG-60020 (=41$).
choi0706
217 posts [100%]
TEXAS TX
what other engine uses the same seals as the 20v blacktop?
elmerkit
351 posts [100%]
carson la
oldeskewltoy, where did you bought that valve cover?
"On sale Itp tires and ATV tires"
mini 2jz
107 posts [100%]
newark nj
i have a 92 corolla with a 20v st... and im using the stock distributor internal coil from the car and wires, spark plug im using 98 supra 2jz...
zlidewayz
2193 posts [99%]
CenCal CA
 Re: (karate_crimson) » Reply  Edit
Quote, originally posted by karate_crimson »
phuckin hate Duralast Wires yeah they lifetime and yeah they do werk but they freaking suxxx.... i know i deal with duralast everyday
"Living the ae86 life" ...what other way to enjoi driving then to drive zidewayz
Thumbs up to Eric at RhysMillenRacing
Also in need of super clean Driver and Passenger Fenders email me
BEST FORM OF CONTACT= zmanae86@yahoo.com
elmerkit
351 posts [100%]
carson la
That is a good alternative but how about the caps can it be interchanged?
Hachiroku_desuyo
124 posts [100%]
LONG BEACH Tokyo
 Re: Reference: Spark Plug Wire Alternatives (mini 2jz) » Reply  Edit
is it me or do you actually have two b.o.v.'s?
'07 YARIS 3dr DD
Redfoxxx
18 posts [100%]
Tampa Fl
Get the Summit Racing Generic Spark plug wires ones and crimp on your terminals, these are cheap and 8mm thick wires, Great bang for the buck.
http://www.summitracing.com/parts/SUM-G826/
works fine on my 20V
Sk149
5 posts [100%]
Miami Florida
Just thought I should share this info was helpful last night when I bought new wires for my 20v I even did the little adapter thing you did
99 black autotragic Corolla Le - Sold
98 white manual Corolla Le - Sold
93 green manual Corolla 20v swapped - Current
runkillerrabbit
490 posts [98%]
yorba linda ca
will this work for black top dizzy and plugs?
and what about the wire between the dizzy and igniter
im totallllllly nub
