 SR5 with 2RZ-FET swap..
rzt86
5 posts [100%]
Lihue HI
 SR5 with 2RZ-FET swap.. Reply  Edit
Hello, Just registered.
I bought a red 86' SR5 about a week ago in Cheyenne WY. 93k original miles with about 1500 on the motor.. It has a 2RZ swap from a 1996 Tacoma and is turbo. When i first test drove her she had ALOT of power till about 4 days later she doesn't want to pass 3k at WOT. but at about 30% of throttle(reading from SAFC2) it'll rev pas 3k. Check my plugs and it's running rich, I don't remember adjusting anything in the motor for this to happen. tried playing with the SAFC and no luck. I'm hoping someone on here can help me out..
Running 4lbs of boost on a 2rz motor, red line is ~5,500, I tried to reset the ECU, changed plugs just last night. I'm stumped..
any help is much appreciated
-Corey
Mikealike
356 posts [100%]
Jacksonville Fl
 Re: SR5 with 2RZ-FET swap.. (rzt86) » Reply  Edit
you might wana take it to a tuner so they can retune it on the dyno.
Performance Unlimitied
Luzunaris99@gmail.com
Ghost Rider
644 posts [99%]
Belgrade MT
 Re: SR5 with 2RZ-FET swap.. (Mikealike) » Reply  Edit
Sounds like a sensor possibly. But details are kind of vague man
***WTB levin Headlights, a r&p without a whine, and a pair of celica supra's***
bryantrn
18 posts [100%]
San Diego CA
 Re: SR5 with 2RZ-FET swap.. (Ghost Rider) » Reply  Edit
might be the TPS. on my 4ac the engine hits a ceiling where it dies back if the sensor isn't connected. can we see pictures of the engine?
rzt86
5 posts [100%]
Lihue HI
 Re: SR5 with 2RZ-FET swap.. (bryantrn) » Reply  Edit
I'll try to get one up soon, Been busy with school n such..
thats what im hoping, a TPS, and not the MAF. or anything expensive..
only thing its got is a T3/T4 turbo and the engine is stock, its got a SAFC2 hooked up but the settings are flat(nothing adjusted, it makes no difference when adjusted)
dominicaneddy
152 posts [100%]
danbury ct
post engine bay shots please
rzt86
5 posts [100%]
Lihue HI
 Re: (dominicaneddy) » Reply  Edit
pogipoints619
1115 posts [100%]
San diego / Murrieta / Pampanga CA
Did you do any fuel injector work recently? An incorrectly seated injector with vacuum leaks may give you the same symptoms.
Also check all your vacuum lines/hoses for leaks, from your pictures the intake piping and turbo plumbing dont look too secure, its very easy to develop leaks when your boosting even at low psi.
Club4ag heads beware of your transactions with *miander*
aka:
Micheal Anderson
miander@rocketmail.com
aka
Tiffany Sizemore
t_sizemore@rocketmail.com
Elvin
12134 posts [100%]
Elvin Wes Your California Importer
any update on this car?
westtoyconnection@yahoo.com
» Return to Cars - RWD - (AE86, TE, KP, RA, TA)
