 SR86 "How to"First  < 2 3 4 5 6 >  Last
rywats
494 posts [97%]
Kelowna BC
Ok guys, someone has to have some info on wiring these things in here? Why is it everywhere I have looked, no one has included merging the two harnesses.
rywats
494 posts [97%]
Kelowna BC
 Re: (rywats) » Reply  Edit
bigt92604
1075 posts [99%]
if anyones wants to upgrade to a killer rearend to handle the sr power i got a celica supra rear with the sr to celica supra drive shaft
Rusty87
56 posts [100%]
abingdon md
What do you mean merging the harnesses. If you want to know how to wire the sr motor harness to a gts body harness I can tell you how to do that. I didnt use the ae86 alt harness I used the sr's and wired a few wires to the corolla's alt harness
rywats
494 posts [97%]
Kelowna BC
 Re: (Rusty87) » Reply  Edit
Any info you have would be amazing. Any wiring you did would be awesome. Was yours an s14? Please email me r-Watson@hotmail.com
thumper
51 posts [100%]
TORONTO ON
How about you post up what you did. It may help alot of other people who are doing this or looking at doing this swap.
I have not started my wiring yet, I have looked at some wiring diagrams and have a idea on what to do, but if yours is already running. I would be interested on how yours was wired as well.
Thanks
84 Toyota Corolla SR20
87 Toyota Corolla GT-S
09 Dodge Caravan 25th Anniverasary
98 Honda Cr-v
89 Nissan 240sx Drift Car, Currently being parted
superfreestyle
106 posts [91%]
Brookhaven MS
I would highly recommend not posting up wiring info... you guys need to email/facebook/pm eachother about your wiring...
rywats
494 posts [97%]
Kelowna BC
 Re: (superfreestyle) » Reply  Edit
And why is that?
mr john
3496 posts [100%]
san diego ca
Google "sr20 wiring into anything" there's a great diagram floating around. I have it saved on my home computer.
JSP http://www.jspfab.com
custom fabrication, custom tig welding applications
turbo manifolds, headers, exhaust systems
stand alone ecu wiring, custom wiring harnesses, and wire harness tucks
2588 progress st suite 3
vista ca, 92081 619-788-3415
by appointment only
thumper
51 posts [100%]
TORONTO ON
 Re: (mr john) » Reply  Edit
^^I have that one saved as well. A lot of good info. I got it from 510realm.com
That is how I am going to wire my car. I am interested in other ways people do it.
98 Honda Cr-v
rywats
494 posts [97%]
Kelowna BC
 Re: (thumper) » Reply  Edit
Got mine all done! Going drifting tomorrow!
rywats
494 posts [97%]
Kelowna BC
sr5 rear axle went toast.
mikesr86
188 posts [100%]
boston ma
time to upgrade...speak to spence from weirperformance...he built my rear end...
rywats
494 posts [97%]
Kelowna BC
 Re: (mikesr86) » Reply  Edit
I'm going with a 7.5 from a Toyota Van LE
slideshow240
9 posts [100%]
anyone using a 45 degree oil return fitting off the block for oil return line off the turbo?
-Two40sx-
17 posts [98%]
houston tx
rywats- im lookin into different options for my rear end. its been a b!tch to locate a mk1. let me kno how this goes or do a possible write up.
-Stay Golden PonY Boi-
Rusty87
56 posts [100%]
abingdon md
For Those who need it I am working on a wiring write up should be up this weekend. Its going to be a helpful guide
-Two40sx-
17 posts [98%]
houston tx
hell ya thanks bro!!
Rusty87
56 posts [100%]
abingdon md
Its posted up like I said any questions feel free to ask. SR86 WIRING- Helpful Guide
Billy_Andrea
1321 posts [100%]
San Francisco CA
John,
Do you have a service where a GTS could be dropped off for an SR20DET conversion ?
My engine is a little smokey & I am trying to decide on a build 4AG, 20V, SR or F20
Thanks.
Rufio_86
222 posts [100%]
Santa Clarita CA
 Re: SR86 "How to" (superfreestyle) » Reply  Edit
How much can you say the cost was in the end?
"I'm a Lightweight DD"
My Garage
DD - 86' AE86 Red =)
Track - 92' R32 GTS-T ;)
Wifes Garage
03'AP1 GPW Hybrid 2.2L
phatrueno
134 posts [100%]
sacramento ca
hey bro.i did a same swap.i just have a few question about the engine.i use the same motor mount from jsp for my swap,i have a problem about my swap and just want to see if any body could help. the problem i have was with the swap was wen my engine is not in high rev, it rattle my whole car.its normal for that or is there something wrong.
also about the dakota chip for the tek, where to buy them and how to install.
Ae13/sr86=Drift wanted!
mr john
3496 posts [100%]
san diego ca
 Re: (phatrueno) » Reply  Edit
Check the clearance between the driverside steering rack bracket and the bottom of the engine. You may need to grind away some of the bracket to clear.
by appointment only
chorie
308 posts [92%]
phoenix az
i was wondering what you use for motor mounts on the sr. also can you post some pics
AE86SR20
327 posts [100%]
Santo Domingo DN
so, how does it behave with the SR in its stock form?
phatrueno
134 posts [100%]
sacramento ca
 Re: (chorie) » Reply  Edit
go to this website for the motor mount (http://jspfab.com/catalog/i60.html).this is where i got my motor mount from.it a good motor mount and a affordable price.
AE86SR20
327 posts [100%]
Santo Domingo DN
what sort of mods have u dont to the motor?
im curious to see vids of a stock sr on the 86
rywats
494 posts [97%]
Kelowna BC
 Re: (AE86SR20) » Reply  Edit
It's unreal, it steps out with no effort and take very little throttle to control. The sr5 rear end ratio is garbage with it though.
RWD Yota
11 posts [100%]
Escondido CA
"so the sr has a electric speedo... and the rolla has a cable speedo... problem solved... mechanical speedo from a 280z... the sr doesnt need a speedo signal... but the rolla cluster does send an electronic signal if i need to hook it up"
Two questions:
1.What year is your 280z speedo sensor. The reason I ask is because there is a 280z and then theres a 280zx which is the newer model, I just wanted to clarify which one you used before I got one?
2.Also do you know how many teeth your sensor had the guy I was going to buy one off told me this is crucial in making this work because there is a15 teeth, 16 teeth and one other number of teeth sensor?
No it is rear wheel drive, yes toyota made it that way ;)
phatrueno
134 posts [100%]
sacramento ca
 Re: SR86 "How to" (RWD Yota) » Reply  Edit
i got a speed sensor from a 280. after i install it, i took it for a run but it doesnt work.does it matter what year i got it from.
» Return to Engine - Other Toyota engines and off brand powerplants.
